Question about Apple iPod nano MP3 Player
Ipod 4th gen nano is frozen on the language selection screen.
I restore using select and menu buttons and it just goes right back to the select language screen. But the buttons obviously dont work because i cant scroll to select a language.
Hi
my ipod 8gb chromatic has been frozen for a week and wont turn on
it doesnt get recognized by the itunes or computer but when you do connect it the apple sign appears in the middle of the screen.
Posted on Jan 17, 2010
  • 728 Answers
That could be one of two problems: Either the cord of the click wheel has been disconnected from its socket which will be an easy fix and you only have to pay labor, or you may just need a new click wheel which should still be cheap.
Posted on Aug 05, 2009
How to wipe my used i pod nano 4 gen 16gb
Connect it to your computer, open iTunes.
Then select the iPod in the left side of your screen, under "Devices".
There will be a restore button. Press it.
Mar 13, 2011 | Apple iPod nano 4th Generation
My ipod keeps having the apple screen up. I reset it holding the middle button and menu. Then it goes right back to the apple screen. Even when plugged into computer
You'll need to restore it. Dock it, when it shows up in iTunes select Restore. If it never gets there run a search on Apple.com for iPod Rescue mode.
Dec 02, 2009 | Apple iPod nano 4th Generation
My ipod nano screen is not doing anything its like its frozen its stuck on language section i cant scroll down or anything and it says its locked but its really not
you have to hold the center button and the menu button to reset it...if that doesnt work you will have to plug it into the computer and use the restore function on the iTunes
Aug 06, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
My ipod nano is frozen the screen does not show anything and if it does it says its locked which it isnt on hold
Start by reseting it, hold down the "Menu" button and middle button for about 7-8 seconds. This will most likely work, if it doesn't, try restoring it. Do this by first plugging your iPod into your computer and starting iTunes. Then select your iPod in the list to the left, now click the "Restore" button located under the large picture of your iPod model. Restoring will probably take a little while, maybe 10-15 minutes.
Hope this helps!
Ipod using too much battery power
To turn off shuffle, enter the "Setting" menu, then select "Shuffle" use the forward/back buttons to change the value to "off". To turn off the "Shake" feature, again, enter the "Setting" menu then scroll down and enter the "Playback" menu. switch it to "off".
Mar 05, 2009 | Apple iPod nano 4th Generation
How to get my language back to english
Select your language.
If you have an iPod nano or Fifth Generation iPod (iPod with video):
  1. Scroll down to the last menu option but don't select it.
  2. Scroll up one menu item. This should be Settings.
  3. Press the Center (Select) button. This takes you to the Settings menu.
  4. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  5. Scroll up to the third menu item from the bottom one. This should be Language.
  6. Press the Center button to select Language.
  7. Select your preferred language from the list.
If you have an older iPod with color display (including iPod photo)
  1. Scroll to the fourth menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
  2. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  3. Scroll up to the third menu item from the bottom one. This should be Language.
  4. Press the Center button to select Language.
  5. Select your preferred language from the list.
If your iPod has a monochrome display (black and white):
  1. Scroll to the third menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
If the instructions above don't enable you to change the language on your iPod, try using the "Reset All Settings" option at the bottom of the Settings menu. If the Reset All Settings option does not work, you can restore your iPod back to factory condition and reselect the display language.
for more details just click the link below http://support.apple.com/kb/HT1824
rate the solution if it helps. thanks.
Jan 05, 2009 | Apple iPod nano
Frozen
What I would do is just plug it in to your computer and leave it there ,.  leave till it is fully charged and then eject it and see what happnes .,  it might work
Aug 24, 2008 | Apple iPod nano
IPod Nano 3rd Gen. Frozen on main screen. will restart (menu+select) but goes back to being frozen on main screen help asap pleaase
yes it can if it will load in to my computer? look for divce g right click and format it you will lose every thing but it should solve your problem when done use itunes to restore settings ? let me no how you get on
Jan 24, 2008 | Apple iPod nano 3rd Generation
Frozen Ipod Nano
  1. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  2. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  3. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  4. Connect it to your computer.
  5. In iTunes, select Restore to Restore the iPod firmware. This erase everything on the iPod.
Dec 04, 2007 | Apple iPod nano
Apple iPod nano MP3 Player Logo
468 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
