Question about Samsung SGH-D900 Cellular Phone
Document viewing on dial a phone it says that the d900 i has document viewing any ideas how to make it work or is it wrong?? Thanks
    Brigadier General:
  • 7,752 Answers
Call ur provider
Posted on Jul 04, 2008
I cannot figure out how to setup the fax that came with printer
Hi Vallarie
Verify that the phone connector on the wall can carry a phone call!
Connect a phone & prove that you can dial out.
Remove phone.
Use a short phone cable to plug in to the Printer then into the phone connector on the wall.
Put the printer in fax mode, then use the printer keyboard to dial a phone number. If that works, your almost there.
Scan a document & send to the phone number.
If that dials out... OK. Then try sending to a phone number with a known Fax machine at the other end. When the two fax machines start communicating through "tones" then the document will be sent as a Fax.
Setting Up the Hardware for Faxing on an HP LaserJet Printer Did Did you find this Helpful....
Then how about a "thanks" or Tick of Approval?
It's the only payment we get
Sep 20, 2015 | Canon PIXMA MX472 WIRELESS OFFICE...
Manual fpr Fujitsu Siemens AMILO Pro V2000 (FAP:GBR-148100-P01) PC Notebook. After download and opening the document, my Acrobat Reader gives an error message: "This page has an error. The page...
There can be nothing wrong but the document being downloaded wrong ..If the document was directly opened in the web page may not finished the download...Be carefully until it loads it full ..and after that click to save the document in the hard disk of the computer for a better view and faster opening ..When you have it physically in the hard disk ..try to see it again ..if it seam not to work ..try to reinstall adobe reader ..maybe it was a trial and expired and some features are not available anymore..
Also try another download..cause this one may be corrupted and this to be the cause for the bad view ..
Sep 11, 2011 | Fujitsu Siemens AMILO Pro V2000 Notebook
Insert the fax. Prepare the documents you need to fax. Place the original paperwork face down with the top edge first in the Automatic Document Feeder.Set up the cover page. Press the "Menu" button, and then press "2," "2," and "8." When "Next Fax Only" appears press the "Set" button. Use the arrows to select "ON" and then press "Set."Select a cover page comment. The comments available for the fax receiver to view include, "Please call," "Confidential," and "Urgent." Use the arrows to select a comment and then press the "Set" button. Input the number of pages you are sending and then press "Set" again.Enter the phone number. You can store phone numbers in your system under the one touch dial or speed dial options. Use One Touch, the key pad, speed dial, or search to enter the phone number you would like to send your fax to.Send the fax. Once the document is inserted, the cover page is set, and the phone number is entered press the "Fax Start" button located in the bottom right corner of the control panel. Your fax machine will then dial the number and proceed with sending your documents
Apr 16, 2011 | Computers & Internet
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
Hacer documentos
Create a New Document
There are several ways to create new documents, open existing documents, and save documents in Word:
  • Click the Microsoft Office Button officebutton.gif and Click New or
  • Press CTRL+N (Depress the CTRL key while pressing the "N") on the keyboard
You will notice that when you click on the Microsoft Office Button and Click New, you have many choices about the types of documents you can create. If you wish to start from a blank document, click Blank. If you wish to start from a template you can browse through your choices on the left, see the choices on center screen, and preview the selection on the right screen.
Opening an Existing Document
  • Click the Microsoft Office Button officebutton.gif and Click Open, or
  • Press CTRL+O (Depress the CTRL key while pressing the "O") on the keyboard, or
  • If you have recently used the document you can click the Microsoft Office Button and click the name of the document in the Recent Documents section of the window Insert picture of recent docs
Saving a Document
  • Click the Microsoft Office Button officebutton.gif and Click Save or Save As (remember, if you're sending the document to someone who does not have Office 2007, you will need to click the Office Button, click Save As, and ClickWord 97-2003 Document), or
  • Press CTRL+S (Depress the CTRL key while pressing the "S") on the keyboard, or
  • Click the File icon on the Quick Access Toolbar
Renaming Documents
To rename a Word document while using the program:
  • Click the Office Button officebutton.gif and find the file you want to rename.
  • Right-click the document name with the mouse and select Rename from the shortcut menu.
  • Type the new name for the file and press the ENTER key.
Working on Multiple Documents
Several documents can be opened simultaneously if you are typing or editing multiple documents at once. All open documents will be listed in the View Tab of the Ribbon when you click on Switch Windows. The current document has a checkmark beside the file name. Select another open document to view it.
Document Views
There are many ways to view a document in Word.
  • Print Layout: This is a view of the document as it would appear when printed. It includes all tables, text, graphics, and images.
  • Full Screen Reading: This is a full view length view of a document. Good for viewing two pages at a time.
  • Web Layout: This is a view of the document as it would appear in a web browser.
  • Outline: This is an outline form of the document in the form of bullets.
  • Draft: This view does not display pictures or layouts, just text.
To view a document in different forms, click the document views shortcuts at the bottom of the screen documentviewsshort.gif or:
  • Click the View Tab on the Ribbon
  • Click on the appropriate document view.
Close a Document
To close a document:
  • Click Close
Jan 04, 2011 | Microsoft Office Computers & Internet
I want to find out how to set up our Canon CFX0-L4000 fax Machine
11 UP
13 +
Keys 1-20 are speed dial keys. If speed dial is not set, message is displayed and manually entering the telephone number is prompted. Press STOP to clear.
Pressing FUNCTION accesses the menus associated with keys 1, 2, 3, and 4. After accessing a menu, the cursor keys, SET, and occasionally the telephone key pad are used for selecting options and setting values.
EG. Setting a speed dial number:
FUNCTION - DATA (01) - SET - SET - UP/DOWN to select speed dial number - SET - UP/DOWN to set number/name - SET - UP/DOWN/LEFT/RIGHT/PHONE KEYPAD to enter value - SET
EG. Setting unit telephone number
FUNCTION - DATA (01) - DOWN once - SET - DOWN once - SET - PHONE KEYPAD to enter number - SET
EG. Retransmit from memory (assumes memory light is on)
FUNCTION - MEM (04) - DOWN once - SET - UP/DOWN to select document number (LEFT/RIGHT to view associated telephone number) - SET
EG. Delayed transmission
place document into feed - FUNCTION - TX (02) - SET - PHONE KEYPAD to enter time to send - SET - PHONE KEYPAD to enter phone number - SET - SET - document is scanned and will be transmitted at set time
for full guide you will have to search and purchase one.
May 28, 2009 | Canon Office Equipment & Supplies
I dont know how we got disconnected but here is the instructions
Adjust the width of the document guides (1)
to fit the actual size of the document.
2 Insert the document (up to 10 pages) FACE
DOWN (2) until a single beep is heard and
the unit grasps the document.
L If the document guides are not adjusted
to fit the document, re-adjust them.
3 If necessary, press {A} or {B} repeatedly to
select the desired resolution.
5 Dial the fax number.
6 When a fax tone is heard:
Press {FAX/START}.
When the other party answers your call:
Ask them to press their start button. When
the fax tone is heard, press {FAX/START
To redial the last number
1. Press {REDIAL/PAUSE}.
2. Press {SET}.
L If the line is busy, the unit will automatically
redial the number up to 2 times.
L To cancel redialing, press {STOP}.
To send more than 10 pages at a time
Insert the first 10 pages of the document. Add
the other pages (up to 10 at a time) before the
last page feeds into the unit.
Pre-dialing a fax number
You can dial the fax number first before inserting
the document. This is convenient if you need to
refer to the document for the other party’s fax
1. Enter the fax number.
2. Insert the document.
3. Press {FAX/START}.
Sending from memory (Quick scan feature)
You can scan the document into memory before
sending it. To use this feature, activate feature
#34 (page 62).
1. Insert the document.
2. Enter the fax number.
L The document will be fed into the unit and
scanned into memory. The unit will then
transmit the data. If the document exceeds
the memory capacity, transmission will be
canceled and this feature will be turned OFF
automatically. You must transmit the entire
document manually.
L This feature cannot be used if {DIGITAL SPPHONE},
{TALK} or {SP-PHONE} is
To stop transmission
Press {STOP}.
Aug 27, 2008 | Panasonic Office Equipment & Supplies
Phone switches off when dialling a certain number
looks to me like maybe an update to your mobile may have gone wrong and I have a samsung 370 and nokia 5200 and my samsung freezes and turns off wen i view a picture sometimes my samsung has been damaged so that may be the problem with yours please reply... :)
Apr 02, 2008 | Samsung SGH-D900 Cellular Phone
Fax Problem
It sounds like it has a lot of jobs in it's outgoing queue. Make sure your phone line is connected to the LINE port, and see if you can get a dial tone.
Jan 28, 2008 | Sharp AR-M237 Copier
Samsung SGH-D900 Cellular Phone Logo
15 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
