Sound and speakers
All wires are connected properly on both the speakers and the computer but no sound is able to be produced
  • 3 Answers
Check drivers for sound card....right click my comp>properties>device mgr> see if sound card driver is working properly.
Posted on Jul 14, 2009
When speakers are connected to the computer, they produce a popping sound every second. However, when headphones are connected to the speakers the sound works fine.
these speakers are quite problematic aren't they!! From the information you have given there is either a problem with the mains trans former or the internal wiring. Neither of which are user serviceable.
Jan 07, 2011 | Bose Companion 2 Series II Multimedia...
Only voice from tweeter is coming, nothing from the mid-range and woofers. on cerwin vega v10f
bhurajiv,
Well it's a good thing that you are getting sound from the tweeter from the speaker cabinet with the problem, that eliminates one of the possible problems; your wires are connected!
If your other speaker sounds fine, the first thing to try is to swap your speaker wires with the one that sounds fine. If the problem speaker cabinet still only produces sound from the tweeter, the problem is within the speaker. If the problem goes away, the problem is from your electronics.
If the problem is within your speaker and it is still under warranty, find a authorized repair location (http://www.cerwinvega.com/service_center.php).
Problems within the speaker can only be one or more of the following: 1) The drivers not producing sound have been blown; played with either too much power and/or distortion. Distortion is created when you play your music too loud with a amp not able to reproduce what you are looking for in sound, the speaker itself can hear it before you can.
2) The speaker cabinet has a crossover inside which directs the proper sounds to the proper driver. This crossover can have components that have been broken be either #1 or from exsessive vibration.
3) There are wires inside of the speaker cabinet that have been disconnected. This can happen over time or if someone reaches inside of the cabinet through the port and pulls on the wires; like a young child or pet such as cats.
If the drivers in question just one day stopped producing sound, start with the easiest solution, #3 then #1 if you can suspect anyone could have played your speakers other than you.
To diagnose the problem, you first start by removing the woofer and confirm that all of the wires are connected and in good condition. While the woofer is removed, to eliminate that there is a problem with the speakers, temporarily connect the mid-range and woofer, one at a time, directly to the wire coming from your electontics, if they produce sound the problem is within the crossover network, if they do not produce sound, the problem is with the driver itself. Replacement parts should only be purchased directly from Cerwin Vega directly (http://www.cerwinvega.com/contact_us.php)
-Chris
Jan 25, 2010 | Cerwin Vega Cerwin-Vega V-10F Floor...
Computer not seeing Altec Lansing BX1020 speakers
go to start>settings control panel> click on system then click on device manager. Make sure that everything is working properly then in control panel click sound. if that is all working. Make sure you have the speakers connected in the right spot. You may also want to try the speakers on another computer to isolate exactly what the problem is.
Thank you,
lee
Nov 10, 2009 | Altec Lansing BX1020 Computer Speakers
Two of the speakers just aren't producing any sound. Could they just be blown, or might I be able to fix them?
not gonna lie your right chance are they could be blown. i would check the wiring or even if you feel comfortable enough unplug the speakers and check the wires on the INSIDE of the dead speaker to see if they are still soldered on there ok.
Nov 04, 2009 | Logitech X-530 Computer Speakers
I've lost sound in one speaker
Check the wire for frays, missing insulation, broken area, loose fitting, etc. It sounds like there is something that is not making a proper connection. "Fiddling" makes it better leads me to believe that a bent area, frayed wire or such has it not making a full connection. You may need to replace the wire to that speaker in order to correct the problem. If the unit is still in warranty I'd suggest contacting a Logitech repair center for this. If it is not then you can do this yourself if you are comfortable working with a soldering iron. Just make sure you use properly rated speaker wire and connect the wires properly. Hope this helps.
Sep 13, 2009 | Logitech Z-2300 Computer Speakers
All the speakers of my samsung Max-zs990 radio are not producing sound but the subwoofer does.
sir, i try connecting the wire properly. if still the problem persists then there must be a problem in the speakers itself.you should replace them.
May 28, 2009 | Samsung U3 2GB* MP3 Player - Green
No sound with Ispire A 500 & Windows vista 64 b
i cant get the little speaker to come on right now it has a picture of a speaker on my screen at the bottom of my screen but then there is a little red X on there hyow do i get that off
Jan 23, 2009 | Dell A215 Computer Speakers
Polk speakers with Windows Vista don't work
I doubt the speakers need a driver. Is there output from the soundcard? Connect the speakers to an alternate audio source, such as the headphone jack of a CD player or radio. If the
speakers produce sound, the problem is probably
with your soundcard. Recheck your soundcard
installation and setup procedure. Consult the sound
card’s manual. Check the “mute” and “volume” controls on your
soundcard or media player software and keyboard.
Are the speakers connected properly? Make sure the
plugs are securely connected in the proper location
according to their colorcoding and the diagram on th
front of this manual. Make sure the left speaker wire
with the white stripe is connected to the (+) speaker
terminal on the subwoofer.
Dec 03, 2008 | Polk Audio AMR50 Computer Speakers
Please Help!
I had the same problem: speakers worked, but clicked whenever they were on. They are actually Compaq speakers connected to a Dell computer. I solved the problem by moving the speakers about 12 inches farther away from my wireless router. Very easy!
Sep 09, 2008 | Dell A215 Computer Speakers
Channels
You've camped the speakers onto the right channel only. While the balance is on the left unhook one of your speakers and connect to the other channel it will come on the now you should have balanced speakers. Can you come back and tell me if that helped.
Sep 29, 2007 | JBL CREATURE II Computer Speakers
Computers & Internet Logo
David Payne
David Payne
