Question about Sony KDF-E55A20 55 in. LCD Television
There is a hole in the screen on my kdf-e55a20. how can i fix this
    President:
  • Sony Master
  • 1,779 Answers
The part number for your screen is 1-788-163-11 which is back ordered from Sony. You can verify this with Encompassparts.com
Posted on Jul 14, 2009
5 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Need to reset lamp hours for KDF-E55A20
This model does not require lamp timer reset, put new lamp securely and power up TV for picture.
Posted on Jun 06, 2009
tvtek
  • 1284 Answers
SOURCE: I have a kdf e55a20 TV goes off and on. green light stays on
The first thing I suspect is the projection lamp. If you haven't replaced it in the past year or two try that first. the part number is A-1085-447-A. Please take a few moments to rate my answer. Thanks...
Posted on Nov 24, 2009
welcomejee
  • 10594 Answers
SOURCE: screen turns off and on Sony KDF E55A20
It is symptom of dying lamp and tv requires new lamp.
Existing lamp in tv has reached to end of its life span and causing that problem. If lamp has not been replaced in last 2-3 years, just put new lamp in tv to get it back in business.
Thanks.
Posted on Jul 28, 2010
toyladi3
  • 597 Answers
SOURCE: My Sony 55" 3LCD TV
The problem with the television is that the lamp is getting bad. it will get to a point where it will completely go bad.
  1. To replace the lamp, all you have to do is get a replacement lamp, then you get a screw driver, and a cup to put the screws in.
  2. Unplug the television and allow the high voltage to dissipate,
  3. Then you unscrew the compartment that is at the bottom where the lamp is, then you turn off the lamp switch and unscrew the lamp that is holding the lamp in place,
  4. Gently remove the lamp and replace it with a new one,
  5. Then you reverse the process to reassemble the television together,
  6. Make sure you turn on the lamp switch before coupling it back together.
Plug the television and turn it on.
Take care and good luck
Hope this helps!
Posted on Dec 15, 2010
Sony KDF-E55A20 55" 3LCD TV Purchased
Hi This is most likely the inverter panel that drive the CCFL's (Backlight tubes) or the backlight tubes themselves, I'm afraid I can't help with the diagnostic test or service menu.
hope this helps
Midge.
Feb 10, 2011 | Sony KDF-E55A20 55 in. LCD Television
Need instruction for KDF-E55A20 lamp replacement
Click Sony Support to download user manual of KDF-E55A20 that has lamp replacement procedure in details.
Sep 24, 2010 | Sony KDF-E55A20 55 in. LCD Television
Screen turns off and on Sony KDF E55A20
Thanks.
Jul 28, 2010 | Sony KDF-E55A20 55 in. LCD Television
Jun 06, 2009 | Sony KDF-E55A20 55 in. LCD Television
SONY KDF-E55A20
No it sounds like the thermal fuse.
Apr 14, 2008 | Sony KDF-E55A20 55 in. LCD Television
The lamp?
This unit does not contain any CRT's. This unit uses a Optical Block Assembly to produce images on the screen. There is a lamp that is user replaceable for this model (KDF-E55A20). You can find the lamp for this model listed below.
Sony KDF-E55A20 Lamp Original Replacement
Apr 11, 2008 | Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E55A20 55 in. LCD Television Logo
88 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
