Question about Maytag Atlantis MDE6400AY Electric Dryer
I HAVE A MAYTAG GAS DRYER MODEL MD-31 BURNER GOES ON AND OFF INTERMITTENLY ANY IDEAS. THANKS JIM
    President:
  • 1,865 Answers
The burner is designed to turn on and off intermittantly. It is controlled by a t-stat and a hi and lo temp sensor
Posted on Jul 14, 2009
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
Maytag Model # LDG510 - Dryer burner will not stay lit. Electric igniter glows but will not lite gas. Igniter cycles on and off.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 10, 2010 | Maytag Dryers
I have a maytag model mgd9316aww gas clothes
sound's like silanoild's on gas valve not opening to let gas in.
Nov 15, 2009 | Juicers
I have a kenmore #110.72812101 gas dryer. the burner comes on, then goes off after 2-3 min. is there a schematic online? thanks, jim
The 2 coils ( kit ) need to be replaced on the burner valve . One of them gets hot and opens ( shorts internally ) and wont work again , until dryer cools down for a while . Pt # 279834 . You can easily replace . 2 screws hold the coil bracket on . Don't even have to cut off the gas , or pull the dryer out from wall .
Aug 29, 2009 | Kenmore Dryers
Dryer runs. No heat
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Jun 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Maytag Atlantis MDE6400AY Electric Dryer Logo
218 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
