Question about Fujitsu Siemens LifeBook S7010 Notebook
Over heating, possible fan problem
Hello,I love my laptop so much that I have a hard time giving it up. The problem is it over heats then shuts down and I think the fan doesn't run right, is there a way I can replace the face or what do you suggest?
    Problem Solver:
  • 4 Answers
If the fan *is* the problem, it's probably clogged up with lint, pet hair, carpet fibers, cigarette tar, etc., etc. For a first step, find the vent on the laptop where the hot air enters the laptop when the fan spins. I call this the "intake port". Put your lips up to this port, creating an air-tight seal around the laptop....then blow air into the port as hard as you can. Be careful not to blow spit into the port. The air you blow into the port *should* make the fan spin, and create a soft whhhiiiiIIIIRRRR!!!!! that last about half a second. If you don't hear the fan, the bearings on it are probably seized up, and the fan will need to be replaced. Sometimes you can fix a fan with a drop of oil in it's shaft, but that's another topic. At any rate, while you're blowing into the intake port, keep your eyes on the exhaust port...the spot where hot air *comes out* of the laptop. If all sorts of dirt and lint start flying out of the exhaust port, your problem was being caused by said lint and dust blocking air-flow through the laptop's internal heat sink. You can *usually* knock all the offending matter out of a laptops cooling system by repeatedly blowing into the exhaust port.....but sometimes you have to take the laptop apart and manually pick it out. Ditto that if you can't get the fan to make the whirring noise. Some people eschew my techniques by using cans full of compressed air, though I've had better luck just blowing into the machine's intake port. Hope this helps....
Posted on Jul 14, 2009
  • 150 Answers
It sounds like a heat sink issue. This happens when dust builds up in the pc. You could go online and see just how complicated it is to open up the laptop... search replacing cooling fan/cleaning heat sink. Or I would try a can of compressed air, shoot it into the exhaust area on the pc hopefully this could be a simple inexpensive fix to your problem. But if the fan is shot it wont cool properly and it will continue to shut down to save the pc from frying. good luck
Posted on Oct 16, 2009
Auto shutdown during work
it could be that the fan of your processor stops working or not working at its full efficiency, you should check underneath your laptop unit if the processor fan that blows away the heat generated by processor and chipset during heavy load of work.
Oct 21, 2013 | Lenovo Computers & Internet
My laptop has a black screen and i cannot give it any command and have to force shut it down
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Apr 07, 2013 | HP Pavilion DV6500Z Notebook
My fan does not work. I havwe tried updating the software and it is up to date.What are my other options?
There are two possibilities:
A. Your laptop is simply not getting hot enough to turn the fan on. A lot of laptops are becoming very heat friendly with newer processors requiring less power and producing less heat. Running the fan reduces battery charge faster and all laptops avoid using it as much as possible.
B. Your laptop is over heating and shutting down when you use it. This is easy to spot as the laptop will often not boot back up for 20 to 30 minutes after the first shut down. Or it will let you restart it, but the shut down time gets shorter. If this is the case, the fan is broken or jammed.
Solution is to clean the laptop out with a can of compressed air. You can also use this to spray right on the fan to make sure it is free and will spin. If this does not solve the issue, the fan needs to be replaced.
May 09, 2011 | Toshiba Computers & Internet
My dell latitude D610 laptop gets heated up after a few minutes I the start the laptop and eventually shuts down.
  • There is a possibility that the fan of your laptop is not working. Make sure when you power on the laptop the fan is running. And if the fan is not working replace it so that your laptop will not heat up and it will not shut down.
Feel free to reply this solution if you have further questions. Thank you.
Feb 14, 2011 | Dell Latitude D600 Notebook
My laptop , acer aspire 4937 , is very high in temperature when using . Some used program become " not responding " . This programme are in small size use space on hard disk . So , what should I...
The laptop can lock up or shut down when it overheats and won't boot up again until it has cooled down. If this problem is not fixed, then eventually the CPU will fail.
An overheating laptop can be caused by a faulty fan or the fan and heat sink assembly is clogged with dust.
If the CPU fan does not spin freely then replace the faulty fan. If the fan and heat sink is clogged with dust, then remove the dust and clean the fan and heat sink with a can of compressed air.
Nov 13, 2010 | Acer Computers & Internet
Help!
Could me many things. Let's think. I installed an antivirus once that would get stuck scanning some file, the CPU-- the main processor in the latop-- would go to 100% and would get so hot that the fans would go crazy cooling it down. It could easily shut down if left on all day from heat.
Another laptop I had- I read on the support boards (it would get hot and the fans would be very loud) that the thermal last between the CPU fan and the CPU would degrade, causing the heat dissipation to decrease-- the heat of teh CPU was not being wicked away through the paste to the CPU fan. Boom- the laptops would shut down from too much heat.
Did you install any new software lately? If no, it could be a hardware problem like I mentioned above.
Third, a friend of mine had a gateway laptop that would get very hot-- he could hardly use it. It was a loose/faulty graphics card that would get very got, causing teh fans to go on, and then the computer to **** down.
Many of these hardware problems are tough to solve over email like this because you need technical knowledge. Further, most of these require the unit to be sent in to fix, really, especially in the case of laptops which are tougher even to get at than desktops.
Call the manufacturer, as they might be able to talk you through a fix or sending it in. Even if it costs $130 bucks, it's still not the 500-600 you need for a new computer...
Feb 04, 2009 | Fujitsu LifeBook N3010 Notebook
Gateway 7405 GX Fully shuts down at random intervals
It sounds like a thermal shut down when the processor over heats,one thing it might be is that the heat sink is not seated properly on the processor.When removing the heat sink make sure you have thermal paste to place between the processor and heat sink.That should give you a good starting point.
Jul 28, 2008 | Gateway 7405GX Notebook
Shut down by itself
is it hot when it shut off ?.
if yes, please check the fan and heat sink. is it dusty ?
you just need to clean it up. make sure there is air come out from heat sink door.
Apr 06, 2008 | Acer Aspire 3000 Notebook
T-20 2647 think pad
possible... run your unit in safe mode then observe it...if happens again check the memory ram... if not your hard disk is infected with virus...try scanning /cleaning drive c:
Mar 28, 2008 | IBM ThinkPad T20 2647 Notebook
Fujitsu Siemens LifeBook S7010 Notebook Logo
776 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
