Linksys Wireless-G Broadband Router
Problem for Linksys Wireless-G Broadband Router
Need help setting up linksys with laptop
By JThomas702 on Nov 16, 2007
i have linksys set up in basement on desktop. I had my laptop working upstairs. laptop got stolen. I need to connect my new laptop with the router. I don't remember what i did with paperwork that had everything written down on. I am using verizon dsl
Best Solution
posted on Nov 17, 2007
Helpful)
timid
Rank: Wiz  Linksys Expert
Rating: 84%, 167 votes
do not worry about it..
if you are still online with the desktop..
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router’s IP Address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
If should ask for a user name and a passwd.. if it is not ..try with 192.168.2.1 or 192.168.5.1 if still not..
then for a dsl connection you might have changed the ip address of your router..
To check ipaddress
click start then run and in run type cmd and click ok..
you would be in a black dos prompt..
type ipconfig and press ok.. you would find the ipaddress
Step 3:
Step 4:
then press [Enter].
Step 5:
When the router’s web-based setup page appears, click the Wireless tab.
Step 6:
Look for Wireless Network Name (SSID) and if it’s still set to ‘linksys’ change it to something unique then click Save Settings. or else if the name is changed leave it..
ans below the wireless tab select the Wireless Security sub tab.in the blue bar. check for the defalt transmit key and key 1 if its already setup, then make a note of the key and go to Step 12 if not setb up wireless security first
Step 7:
Select any number under the Default Transmit Key to determine which key you’ll be using. In this example, we selected number 1.
Step 8:
Select 128 bits under WEP Encryption.
Step 9:
Type a wireless network password of your choice such as “MySecretKey”, then click Generate.
NOTE: You should come up with a password that is unique for your network and is a combination of numbers and letters up to 26 characters.
Step 10:
The result will be a string of random characters. Copy the resulting string since this will be the key to your wireless network.
NOTE: Do not give this key to anyone. This will be your wireless network’s key.
Step 11:
Click .
Step 12:
now go to your latop. right click wireless network connectios icons and click view wireless network.. (if it is xp os)
you would fine the name of the n/w try connecting to it, it would ask for the n/w key enter the 26 digit key which you have setup and click connect, you would go online with your laptop..
Was this helpful?
Yes
No
Popular Solutions for Linksys Wireless-G Broadband
Questions and Unsolved Problems for Linksys Wireless-G Broadband
Do you recommend Linksys Wireless-G Broadband Router?
Answer
Answer
My BT home hub will not recognise the ethernet connected hard drive connected to the router, how do... (More)
Answer
how do i fix my wireless router?
Answer
wireless router, wired in ports flicker on and off
Answer
My opera browser gives a download speed of 95kbytes/sec on 512kilobits/sec, can I get it more by... (More)
Answer
find or your down find it for today afternoon got it GGGGGGGGGGGGG
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Router Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
