Question about Bendix King Radio Communications
Kx 125 nav com radio. I accidentially applied reverse power after reverse charging my battery if you can believe that's possible. It now acts like it has no power.
  • 137 Answers
Reverse power can burn out the end tuner in these devices.Probably that is what happened.Take it to a radio shop for repair.
Posted on Jul 14, 2009
My alcatel onetouch phone isnt powering on & i even tried charging it
When charging does it display a graphic logo on the screen to indicate charging is happening? One of two things can be possible here. One your phone needs to be reset, or two the internal battery is beyond dead. Phone's shouldn't be charged longer than 4-6 hours typically. Leaving it longer will kill the life of the battery. It is possible after overcharging a battery the charger will act in reverse and drain the battery instead. If your phone requires a hardware reset. This is found in the manual. Typically it's a multi-button sequence pressed or held during power on. If you do not have a manual, you can either search online for it, or contact your service provider.
Aug 13, 2015 | Alcatel Cell Phones
The battery of my 2009 Ajs JSM 125 is not charging, how do I check the rectifier?
Find the rectifier. Use a paper clip (you will need two paper clips), a D battery and a single flash light lamp. Test that the lamp will light using your battery and the paper clip. Straighten/bend the clip in a manner that will allow the bottom of the battery to be connected to the side of the lamp. The solder joint on the bottom of the lamp touching the bump on the top of the battery. Disconnect the rectifier from the circuit. Put the light in each position of the four contacts using the paper clips, battery and lamp. The lamp SHOULD light in one half of the connections and should NOT light in the reverse positions. Your Bridge Rectifier is built using diodes. These diodes pass electricity one direction but not the other. Your D battery represents the electricity - the light tells if the power is passing or not. A rectifier is necessary because the Alternator on your motorcycle produces AC current. Your Battery needs DC current to charge. The diode more correctly assists in the 'creation' of rectified AC that looks and acts like DC the battery can use.
I hope this helps you.
Aug 23, 2013 | 2010 AJS JSM Trail 125
Wiil the link arm from a 2003 kx 125 fit a 2001 kx 125
Yes I do believe those are exactly the same
Jun 09, 2012 | 2003 kawasaki KX 125
Have reversed polarity and is no longer open and no longer charge the battery. You can help?
Applying a power supply with reverse polarity to your Acer will have damaged the motherboard and possibly other components. This notebook is beyond repair.
Sep 20, 2010 | Acer Aspire 1300XC Notebook
Battery won't charge
Please get it serviced through Service Center.Battery may be dead .Battery gets short circuited when wet .
Oct 28, 2017 | Samsung Eternity Cell Phone
Will a 2003 Kawasaki KX 125 motor fit 2001 frame?
Hi, Donlee73116 the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2003 Kx 125 Project Fun25
97 kx 125 frame what engines fit
Kawasaki KX125 Service Manual
OEM Parts for Kawasaki
Kawasaki kx125 1997 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 24, 2010 | 2003 kawasaki KX 125
My 1986 kx 125 clutch does not engage worked prior
possible the cable is needing to be adjusted make sure it is pulling on the pivot
Apr 15, 2009 | 2003 kawasaki KX 125
Tomtom300 gps mains charging +
1= My battery is flat, but when i put it on charge in the house it doesnt charge and no green light comes on, on my sat nav why would this be?
Could be your house charger is bad or the power connector on the back of the Tomtom is bad.
2= But when i put it in car charge it works perfect 'Y'?
You are using the "power shoe" to charge the battery. For a test unplug the power cord from the power shoe and hook it to the back of the Tomtom. If this work then the house charger is bad. If this doesn't work then the Tomtom rear power connector is bad
3= If ever i have to change battery how is this done?
You will have to remove the faceplate and disassemble the Tomtom in order to get to the battery. Or you can find a shop that repairs small electronic. Find the battery on Ebay.
Jan 12, 2008 | Tomtom GO 300 GPS Receiver
Radio Communications Logo
183 people viewed this question
Top Bendix King Radio Communications Experts
michael galang
Steve
Steve
John L radiodude365
Are you a Bendix King Radio Communication Expert? Answer questions, earn points and help others
