Fan hums but doesn't appear to be working
Fan doesn't work alone or in A/C mode.
  • 146 Answers
Well dose it have holes for oil if not will turn if use your hand. try replacing the compactor first then motor.
Posted on Jul 14, 2009
Why doesn't my fan run.all the lights work but no fan
here is the bionaire support for your tower fan. 1-800-253-2764, if the fan is getting electric to the motor and it just hums, the fan motor may need a good cleaning or if no hum. it is a bad motor or switch. just call above number. good-day !
Jun 07, 2012 | Dryers
The motor doesn't start; just hums.
I would have to agree that the motor is the problem, but before you replace it, check the bearing and blower fan to make sure they are in good shape. If the bearing is bad or the fan is blocked it could give you the same indication.
Jan 02, 2012 | Speed Queen AES28AWF Electric Dryer
Fan won't work on heat mode
the fan has a circuit that faults with error E6 because the circuit is looking for outside condensor unit. I would like to run the fan as a stand alone.
Dec 01, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Khhc2090s trouble
The sensor errors are probably just from opening the door and interrupting the sensor cook cycle.
By the way, you should always press "Stop" before opening the door of a running microwave. Otherwise, the door switches will prematurely fail.
I would first check the door switches and their mounts. See this help file.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also download manuals, installations info, and parts lists here.
dee77f7.jpgWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Nov 25, 2011 | KitchenAid Microwave Ovens
Fan will not come on and makes a humming noise.
I'll assume you don't have electric meters. I'd first try it in heat mode if the blower runs. I'd guess the blower relay or the high speed winding is burnt out. If it doesn't run in heat mode most likely the motor is bad.
Jun 18, 2011 | Heating & Cooling
The drying function doesn't appear to be working
If water remains on the dishes after washing even when you select the normal wash modes (not ECO) then the air dryer fan is faulty assuming the water heater is working.
May 14, 2011 | Fisher and Paykel 24 in. DS-603 Built-in...
I turned my ac off before I went on vacation and now it will not turn back on. The fan will run but that's it.
Please check if any rodents have snapped the wires to the ccompressor. You have not mentioned the make/ model/ type of the set. Whatever be the type the compressor must work on swtich on, If not check for the capacitor and the relay. You will need to trace from the control box. Also check if the mode is put to A/C and not fan alone. Check the supply line to the compressor and replace if the relay or capacitor is faulty other wise your compressor motor has failed if the voltage come to the compressor motor but does not work / no hum or noise. Please check this out. Good day
Jul 10, 2010 | Heating & Cooling
Coleman rooftop a/c hums in all modes, does not start
Replace the start capacitor for the fan and compressor. Check all the wires to the capacitor.
Aug 29, 2009 | Dometic Rooftop RV Air Conditioner
Fan Not Working
either bad condenser fan motor or fan capacitor
Apr 24, 2009 | Samsung AW0503B Air Conditioner
Heating & Cooling Logo
108 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
