Question about Ryobi Garden
The fuel line running from the pump valve to the tank came out does it plug onto something that connects it to the tank or just go into the tank. on a ryobi 31cc mdl# 766r string cutter
    Problem Solver:
  • 6 Answers
It goes directly into the gas tank.
Posted on Jul 14, 2009
Why is fuel flowing from front tank to rear tank on the truck that has duel fuel tanks and both tanks are working
I'm not sure but I remember something about a recall or tsb on the one way valve in the fuel line.
Jul 02, 2015 | Cars & Trucks
Harley troubleshooting
Engine Runs but Misfires
1. Fouled or improperly gapped spark plugs.
2. Damaged spark plug cables.
3. Incorrect ignition timing.
4. Defective ignition components.
5. An obstructed fuel line or fuel shutoff valve
(carbureted models).
6. Obstructed fuel filter.
7. Clogged carburetor jets.
8. Malfunctioning fuel pump (fuel injected models).
9. Loose battery connection.
10. Wiring or connector damage.
11. Water or other contaminates in the fuel.
12. Weak or damaged valve springs.
13. Incorrect camshaft/valve timing.
14. A damaged valve(s).
Jul 11, 2014 | 2002 Harley Davidson FLHRCI Road King...
Why am I having fuel issues with a 97' f-250 7.3 powerstroke, put new sensors on everything, new fuel lift pump, glow plugs,filter, new tank filter, cleaned all the lines from tank to the fuel bowl, s
If this situation occurs after a period of time then check the tank vent correctly at the vent valve on top of the tank. If it occurs reasonably quickly then check the fuel return lines from the injectors to the tank for obstruction ,kinks ,squashed etc preventing the fuel free access to the tank. check the pressure regulator to the pump is holding sufficient pressure to maintain pressure to the pumpin the pump
May 02, 2014 | 1997 Ford F250 SuperCab
Fuel system problems
Check that fuel pressure is up to specs. Should be a connection at fuel rail to attach gauge. Maybe try removing one line where they connect for feed from both tanks and plug it good. Something may have happened when blowing lines that is allowing one line feed to suck air at same time as fuel from the other. Perhaps check valve in line. Try both ways, with each line to see if problem cured. Low pressure reading would indicate that possibility. Check all fittings & connections for possible leak from being disturbed .
Mar 19, 2014 | 1991 Ford F150
I have a 1980's plymouth snowblower that is running on choke for a few minutes then cuts out. Can you help me?
Running with the choke on implies no fuel going into the carburetor. Remove the fuel line at the carburetor and check the fuel flow---it should run out in a thin stream. If it just drips, then there is something blocking the flow, usually a plugged fuel filter, or obstructed fuel outlet from the tank. If the flow is ok, then something inside the carburetor is blocking fuel from entering the float chamber--a sticking (shut) needle valve which the float controls or debris in the passage from the fuel line connection to the needle valve. Hope this helps!
Feb 01, 2011 | Garden
How to remove fuel tank
Run the fuel tank empty, if possible. The Jimmy's tank does not have a drain plug, but if the pump is still operating, then it is the only method of running the tank dry. An empty tank is lighter than a full one, and it makes removal easier.
Unbolt the fuel tank's protective shield by turning its hex-head bolts in a counterclockwise direction. The shield will then slide out. With it removed, the tank's bolts are now accessible
Disconnect the electrical and fuel line connections to the tank's fuel pump, located on the top center front of the tank. There are two (or three) different-sized fuel lines, and one wiring adapter plug that must be disconnected. The hoses come off by pinching or unscrewing their hose clamps, and the plug simply pulls free once its catch is depressed.
Unbolt the fuel tank by turning the bolts that hold it to the frame counterclockwise. The tank should be supported with a jack during this process, as once the tank is freed it will drop from the frame. Lower the tank out of the truck and use the jacks to set it aside to work on it.
If you going to replace the fuel pump:
Unscrew the two screws holding the fuel pump to the tank by turning them in a counterclockwise direction. Once they are out, the pump can be gently pulled upwards and out of the tank. Some residual fuel may spill out, so have a towel handy.
Replace the fuel pump by lowering it into place inside the tank, then securing its screws in a clockwise direction. The plastic fuel pump may be easily damaged by turning the screws too far, so only tighten them enough to seal the pump to the tank.
Replace the fuel tank into the truck with the jack(s), and tighten the bolts that secure it to the frame in a clockwise direction.
Reconnect the fuel lines and adapter plug. The fuel lines are sized for their nipple fittings, and should only fit onto the nipple that they were designed for. Tighten each one with a hose clamp. The wiring adapter plug should make a "snap" sound when it is properly seated.
Fill the tank with fuel and test the new pump. The pump should make an audible whine as the truck is started, and the whine should stop after a couple of seconds. The pump might make a softer sound after the truck is started--this is normal.
After two tanks of fuel has gone through, replace the fuel filter.
Good luck and hope this helps, Note the bolt that holds the gas tank strap may strip or snap. Just cut it off and replace by welding a new bolt for the gas tank strap.
Feb 03, 2010 | 1996 Oldsmobile Bravada
Bmw 325tds diesel flowing back to tank when parked
usual problem ,valves in injector worn for the fuel pump.easy quick fix this one ,fit a non return valve in the inlet pipe,check flow direction on valve when fitting and evan better as well is another in the bleed off return pipe .valves available from a motor factor or a specialist garage like bosch or lucas ,cut pipe and fit the valve with a piece of rubber pipe to connect the valve in line.or listen to the people who want to milk the golden cow and have the whole injector pump overhauled .
Dec 23, 2009 | 2001 BMW 325
My f350 1997 will not run on the rear tank . how do i go about finding what the problem is?
well, first, to find out if its the in tank fuel pump or the tank selector valve, the cheapest and probable easiest thing to do is find the selector valve under the truck and switch the incoming fuel lines. front tank to rear tank inlet, and vice versa. If the truck still doesnt run, you either have an electrical delivery problem to the in tank fuel pump or a bad fuel pump. If after switching the lines, it does run, then you need a new selector valve
Sep 23, 2009 | 1997 Ford F350 Crew Cab
Replaced the fuel pump fuel filter , no start in my 95 S10 Blazer. add gas will run, untill the gas stops pouring in by hand . new part on top of the throtle body as well, i think it controls th O2 and...
1. Does the pump actually run (key on engine off) pump should run for 2 seconds and go off and can be heard if you listen at the filler neck with the gas cap removed)
pump not running - Check relay (replace if bad) check wiring/fusese
Pump runs... go on to #2...
2. check the gas guage. is the gauge reading in the normal area it would read in or is it way way off like WAY above full or way below empty? This is a sign the electrical connection at the pump is plugged in backwards and the pump is spinning the wrong way and not picking up the fuel... (This is easy to get plugged in backwards inside the tank when installing the new pump)
3. Check for feed, return and vent lines being installed wrong where they attach to the tank... they can easily be hooked up wrong and fuel is either pumped up in to the return line or pumped in to the fuel tank vent line..
4. check for kinked or crushed fuel lines from tank to engine.
5. check fuel pressure regulator to be sure its not stuck open.
Jul 13, 2009 | 1995 Chevrolet Blazer
Garden Logo
172 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
