Question about Kenmore Elite 45986 Front Load Washer
Kenmore washer will not drain
I also have the same problem of my washing machine not draining, kenmore 41744052400. I took off the front panel under the washer door, but i do not know which part is the sump camp of the pump.
  • 5,911 Answers
Your washer does not have a cap on the drain pump. You need to remove the large rubber inlet hose from the front of the drain pump in order to access the pump impeller. This model washer tends collect debris in the large inlet hose area, so check it as well.
NOTE: If you own a wet/dry shop vac it will come in very handy to drain any residual water inside the wash tub. There's about a gallon of water that can remain in the wash tub and drain hose lines (this is normal). If you pull the drain hose from the standpipe at the wall and pull a vacuum on it with a shop vac, this will make clean up much easier. Otherwise, you will need some towels to lay down under the pump before you remove the inlet hose.
For an illustration of what I'm talking about, you can go to searspartsdirect.com and type in your model number. Look under the "Motor/Tub" heading for item 35 (drain pump) and item 41 (Inlet drain hose).
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Jul 14, 2009
My machine is not draining and I took some things out of the drain still doesnot drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 05, 2011 | Kenmore 94702 Front Load Stacked Washer /...
Kenmore fHE 2 plus front load washer does not drain and does not complete the spin and drain cycle. Error code f-21.
Means the drain is too long. Under the front lower panel is a sump filter. Remove the filter by turning ccw and clean.
Nov 04, 2010 | Kenmore HE2 Plus Front Load Washer
Have a front loader kenmore model # 41744052400 washing machine
Ours doesn't even spin. I'm trying to connect with a repair guy.
If we gets our repaired, I'll try to remember to get back to this page.
Good luck with yours.
Apr 07, 2010 | Kenmore Washing Machines
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
May 23, 2009 | Kenmore 43142 Front Load Washer
My washer stops in the middle and flashes F21?
Hi and welcome to FixYa,
An F21 error code indicate drain problem. Might you want to inspect/clean the drain system from the filter to catch basin to impeller, pump/valve and drain hose. To do this, the bottom/kick panel ahs to be removed. A bit of a messy job so pls be prepared with paper towels and other absorbent materials.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 08, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 90 washer won't drain
ckd pump traps for debris on kenmore remove front panel on samsung i think a rear approach is best
Jun 03, 2008 | Samsung WF337AA Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
444 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
