Question about Ovens
Electronic control panel display is blank. Oven door will not open. Wall outlet is energized and unit is plugged in!!!???
  • gapdaddi Jul 14, 2009
    I have a KitchenAid KGSA906 gas range. Controller display panel is blank and the door will not open. Wall outlet is energized...!!!???
  • 3,037 Answers
The control board blew and needs to be replaced unless it was in self cleaning mode, then the thermostat probably blew and needs to be replaced. Happens a lot in self cleaning mode on these units. You will have to remove the back panel to get to both of these parts.
Benjamin
Posted on Jul 14, 2009
    President:
  • 1,865 Answers
You can turn the power off for 5 minutes to reset the controller. If that doesn't work, you may have to replace the control board
Electronic control panel went blank and oven is beeping
The first thing I would do, because it is an "electronic" control panel is to unplug your stove, wait about 30 seconds, then plug it back in. Your Control panel may just need a reset and reboot.
If it is difficult to get to your plug-in, then go to your household breaker-panel box, and flip the switch for your stove to the off position for at least 30 seconds, then switch back to on. ...That's the same as uplugging and plugging back in at the wall.
Hope this helped hun ;-)
Oct 03, 2015 | Ovens
We have a Kitchen Aid KEBC147VBL03 wall oven. When we ran the self clean oven (big mistake), the oven shut off and locked. There is no display/lights on the control panel. And, the door is stuck in lo
Does the control board or anywhere of control panel have a fuse? If not beter have it service. Expect a quotation from the serv. Tech after it found how big or expensive theparts tobe replace to make ur unit operational agian
Sep 22, 2014 | Ovens
Self clean - door will not open - no display
Without the model I don't know if unit has one or two open fused which has stopped power to the electronic control this the schematic should be in a plastic packet stuck behind control panel if not then on the back side of the storage drawer if equipped.
Jan 20, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
This unit may have a door lock built in to the control unit lockout. To release it you may have to turn off the oven circuit breaker in your house circuit box. If not, it is just jammed and you will need to wobble it free.
Jan 12, 2013 | Whirlpool RBD275PVS 27" Double Electric...
We put our KitchenAid oven onto self cleaning mode, now the display is blank and the door will not unlock. It has been over 15 hours, and the oven is cool. How do we reset it?
Is this a built in wall oven or a freestanding oven/range combo?
If its a wall oven the problem is going to be a high limit thermostat that went out. If it is a older model the high limit t-stat has a red reset button that can be pushed and power will be restored to controls. If it is newer once the high limit goes out it needs to be replaced. Now heres the tricky part on wall ovens, the high limit thermostat is inside control panel and it needs to be taken apart to get to that t-stat and that can be a problem trying to get it pulled out enough to get to control panel with the door being able to open. On that i wish you luck
Thier is also a high limit on the freestanding range its going to behind the back panel and easier to get it since your not dealing with something built into a cabinet
Good Luck,
Gene
Aug 18, 2011 | KitchenAid Ovens
Electrical GFC wall outlet for oven keeps clicking off within 60 seconds of setting a bake temp. Has ES 100/105 Electronic Oven Control. I suspect problem with Resistance Temp Detector (RTD). Stove top...
Good morning, try plugging the unit into a regular outlet. GFI outlets are notorious for tripping when used with large appliances. They are very touchy for safety reasons. A large current draw could be interpreted as a short and will trip. Hope that helps.
Jan 29, 2018 | Frigidaire Ovens
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
How to start oven in PROPANE STOVE
Print the following infore for future ref if you wish. How it works is simple tage a look at it in Motion
Component Test Procedure Results
Electronic
range control
F1−1 –Upper Oven >650°F with door unlocked.............................
F1−2 –Lower Oven >650°F with door unlocked.............................
F1−3 –Upper Oven >950°F with door locked.................................
F1−4 –Lower Oven >950°F with door locked.................................
F1−7 –Membrane switch is not responding ...................................
F3−1 –Upper sensor is shorted at (< 100 ω) or
open at (>5 K ω) ...............................................................
F3−2 –Lower sensor is shorted at (< 100 ω) or
Check actual upper oven temperature,
if > 650°F check sensor.
Check actual lower oven temperature,
if > 950°F check sensor.
Check membrane switch for connection or damage.
Check upper sensor, harness, and connections
Engineering
Test Mode
Press BAKE pad.
Enter 100°F using the number pads.
Immediately push and hold BAKE pad for appropriate oven
approximately 3 seconds.
This mode can also be entered by pressing the hidden pad
for 3 second located to the left of the lower oven light pad.
Used to view the actual oven temperature for both ovens at all
times, even when an oven function is active.
This mode will also display the current fault code for 5
seconds in the time digits.
Fault codes
accessed
through
Engineering
Test Mode
F0−0 –No fault .................................................................
F1−5 –Upper hardware failure within control ....................
F1−6 –Lower hardware failure within control.....................
F1−8 –Shorted key in membrane switch ..........................
F1−9 –Internal communication errors within control .........
F1−A –Upper latch switches ............................................
F1−B –Lower latch switches.............................................
F1−C –Upper door switch.................................................
F1−D –Lower door switch.................................................
F1−E –Sensor input not calibrated ...................................
F1−H –EEPROM error .....................................................
F1−L –Temp in ovens are the same for long period .........
F1−N –Internal voltage on control not working .................
F9−1 –Upper lock switch is not correct.............................
F9−2 –Upper unlock switch is not correct.........................
F9−3 –Control does not see upper door lock....................
F9−4 –Lower lock switch is not correct.............................
F9−5 –Lower unlock switch is not correct.........................
F9−6 – Control does not see lower door lock ...................
EE –Control cannot read E-PROM. Unit will shut down.
Default from factory
Replace control
Replace control
Check membrane connection
Replace control
Check latch wire harness
Check lock wire harness
Verify sensor is operating properly
Replace control
Replace control
Check lock wire harness, and lock switch
Disconnect power for 60 seconds. If EE reappears, replace ERC
Test Mode This mode must be activated within the first 5 minutes of
power up.
Press BROIL and CANCEL pad for approximately 3 seconds.
If oven temperature is greater than 400°F, the Test Mode
cannot be activated or will abort if active.
Press and hold individual pads for 4 seconds to activate.
Display will have dashes in all segments to indicate the mode is
active.
Upper Bake: Energizes upper bake element
Lower Bake: Energizes lower bake element
Upper Broil: Energizes upper broil element
Convection Bake: Energizes convection fan
Upper Oven Light: Energizes upper oven light
Lower Oven Light: Energizes lower oven light
Upper Clean: Energizes upper motorized door lock
Lower Clean: Energizes lower motorized door lock
Stop Time: Energizes Beeper
Cook Time: Displays error codes
Timer 1: Energizes ROM version
Timer 2: Energizes EEPROM version
Keep Warm: Cooling Fan
Clock: All display segments light
If functions do not perform as specified, replace ERC
Oven
temperature
adjustment
Push BAKE pad.
Enter 550°F using the number pads.
To decrease or increase oven temperature. Push AUTO SET
pad until negative or positive numbers appear. Oven can be
adjusted from -35° to +35° (-37.2° to + 1.6° C) in 5° F (2.7° C).
To avoid over adjusting oven move temperature -5° each time.
Push OVEN CANCEL button.
Sep 04, 2009 | Frigidaire 30 in. Electric Gallery Series...
Thermador sm272zs microwave/oven combo
You have to slide the oven partially out of the wall and there is a metal cover panel on top...remove it and you will be able to access the wiring panels, etc.
Dec 03, 2007 | Thermador SMW272 Electric Double Oven
Ovens Logo
26 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
