Question about Samson G-TRACK USB RECORDING MICROPHONE Microphone
Desktop Stand I am having trouble setting up the desktop stand. Did anyone else have difficulty with the screws or is my product just faulty?
    New Friend:
Took the little piece out of the part that screws onto a standard mic stand including boom: it's a little piece of rubber about the size of a penny that comes out and thus allows it to be used with mic stands
Posted on May 30, 2013
Use a penny to unscrew the ***** that's inside the adapter. Now you will be able to fit the aluminum tube into the adapter =)
Posted on Mar 10, 2008
Basically the swivel peice doesn't fit on the included stand unless you 'back-out' the little adapter that's screwed into it already. It comes with this adapter pre-installed, which makes it fit smaller stands. If you look in the top you can see a notch on the shiny silver adapter hidden inside.. just unscrew it.
Posted on Mar 08, 2008
I'm also having trouble fixing up the desktop mic stand. the swivel part that holds the mic cant seem to fix onto the aluminium stand...does anyone have any solution?
Posted on Jan 06, 2008
Mine wouldn't fully screw down into the base, but I didn't want to force it and it seems stable enough, so I'm not worrying about it...
Posted on Dec 17, 2007
Remove stand of dell monitor lcd stand
Set the face down on a soft surface (pillow). Look at the back of the stand and you'll see a round plastic plug. Using a small pointed tool, pop out the plug. Tilt the stand all the way down and you'll see a Philips screw. Remove it. Wa La!
Jul 10, 2014 | Dell Computers & Internet
Desktop Stand ,any ideas ?
  • You can get a universal wall mount if the stand is no longer available or you cant find one
May 10, 2014 | Philips 190WV
Remove stand from Dell Inspiron 1
It should be connected to your case with a hexagonal screw you will need a set of hexagonal wrenches or also known as Alan keys in Australia. after removing the screw you should be able to lift the system away from the stand. I hope this helps.
Sep 04, 2012 | Dell Computers & Internet
Check the tv back cover at near around the base stand area.Lacate all screws near or at the base stand,spray some WD40 in each screws holes and wait like around ten mins.Take a Philip screw driver take out all the screws out in the srews holes.Take ur hand slicely push it foreward and pull it back.Now u should have no trouble taking out the base stand.
Dec 15, 2010 | Philips 42PFL5332D 42 in. LCD Television
Hi we have samsung lcd 22 inchess.. we need to fix it to wall and there is no backside stand .. how can we get the stand
Most electronic stores sell wall mounting brackets. There are several types. one mounts the LCD screen flat to the wall with a limited range of tilt. Another type mount the LCD screen on an arm that allows tilt and swing movements.
Jul 22, 2010 | Samsung YP-K3 MP3 Player
Monitor stand screws
More likely to be metric M4 screws, 1/2" will more likely to be long enough.
Feb 23, 2010 | Acer AL2423W LCD Monitor
LG - 32LG20 - Excellent LCD TV, but the stand is junk
there are four screw holes at the back, you might want to make use of it for anchoring. I guess these models are designed for TV-like installations and not for computer desktop monitors. The base takes a lot of space too.
Aug 16, 2009 | LG 32LG30 32 in. LCD HDTV
I want to wall mount my 26LB30QD but the stand needs to come off, there is nothing in the instuctions on how to remove the stand, please advise.
With the tv laying flat on to the screen, remove the two screws in the recessed holes. Then remove the two screws above towards the input panel, one under AUDIO-L/AUDIO-R and the one under HDMI-1. The stand should easily slide out.
Mar 06, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Removing swival base
Most LCD TV's have 4 or 5 screws attaching the stand to the set near where the stand slots in at the bottom. The screws might be covered by a plastic panel.
Hope this helps.
Jun 25, 2008 | Televison & Video
Logitech Z-5500 Speaker stand problem
The stand was held on with a nut on the inside. There is not longer a nut on the inside of the hole, so there is now nothing for the stand screw to attach to. The nut is now stuck to the magnet on the speaker. You will need to disassemble the speaker housing to remove the nut from the speaker magnet and reattach then stand. peace. Paul.
Dec 31, 2006 | Logitech Z-5500 Computer Speakers
258 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
