I bought a farad cap, so my amp would get more power. Cause my lights were dimming and stuff. After I hooked the cap up to the amp some weird sounds started coming out of the subs. The noise is a real high pitched sound. What can I do to fix this?
I third it, check grounds and make sure you have good solid connection to metal, also what you're hearing is probably alternator noise, you might consider upgrading it, since it's obviously underpowered for your application, a cap is only a bandaid in the long run.
What settings should i have my 760 watt pioneer amp set at for amp gain and bass boost in order to...
(More)
What settings should i have my 760 watt pioneer amp set at for amp gain and bass boost in order to have the best sounding hit from the subs?
Hi there, I have rubicon 204 amp., it starts after 30 min when I turn on him and works erratic (1...
(More)
Hi there, I have rubicon 204 amp., it starts after 30 min when I turn on him and works erratic (1 sec works 2 sec doesn't work, etc...). Power led is on, as have to be. Sometimes works OK. So, where the problem is ?
ok....my amp had a couple parts that were fried...(a couple capacitors and two of those chip looking...
(More)
ok....my amp had a couple parts that were fried...(a couple capacitors and two of those chip looking things. i forgot what they r called.) anyways I was told by some tech that as long as the part num (ex. RFP50N06...which is the actual num.) are the same, the new chip would work. The amp still does not work. now the old chip has the serial num on top of another num...( H9 ) now the new chips i bought has the serial num (mentioned above RFP....etc)below another code that shows " F 1G23SF. now does that make a diff, n if it does...where can I buy the actual "chip" or resistor or whatever it is called
on my 2010bxi i accidentally touched the positive to the negative input for a split second and now...
(More)
on my 2010bxi i accidentally touched the positive to the negative input for a split second and now neither the power nor protect lights come on, but a faint blue on top does still come on. what exactly is wrong and how can i repair it?
