Bowflex TreadClimber TC20 Logo
G
Gradytene Linthicum Posted on Nov 19, 2015
ESEO message. Treadclimber stopped - Bowflex TreadClimber TC20
Tread climber starts up and shuts down in a few seconds. Starts clicking
Bowflex Treadclimber Shuts down - Questions - Fixya
www.fixya.com > Forum > Treadmills > Bowflex > Bowflex Treadclimber
Bowflex Treadclimber, shuts down related issues. ... After a few times of shutting down due to the heat. Ad ... It shuts down about 60 seconds after it starts.
Customer Reviews: Bowflex TC3000 Treadclimber
www.amazon.com/Bowflex...Treadclimber/.../B000B...
Amazon.com, Inc.The second time I used it I slowed down the speed and worked on getting the ... After researching the TreadClimber for over a year (the cost was a big factor .... We were never able to make the treadles go up and down more that a few inches. ..... a great workout However it continually shut offs while working out and Bowflex ...
Comments for Bowflex TreadClimber Problems
www.treadmilltalk.com/bowflex-treadclimber-user-comments-comments....
Oct 30, 2013 - NOTE: My comment about Bowflex Treadclimbers is also one I left in another area. ... seems like no one sprung the extra few bucks to pay for someone to put the ... In my case , after the initial startup, the machine stops EVERY time at ...nearly spine snapping shutdown at exactly 32 minutes after starting. 5.
[PDF]Bowflex® TreadClimber® 1000, 3000 & 5000 - Nautilus
download.dfxi.com/.../SM/Bowflex/BFX_TC135_SM_RevA_web.pdf
Getting error message ESEP on bowflex treadclimber
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
There is a knocking sound coming from bottom of machine when belt moves.
The treadclimber is a nonsense scam and they are the cheapest made product on the market. You are better off throwing that thing in the trash than paying to have it fixed.
Treadclimber just stopped for no reason
see the videos and proceed accordings.God bless you
Bowflex Treadclimber TC20 error messages
Dear Sir:
This is a common error in this kind of machine. You must call to the company bowflex, and claim the problem. The hardware design is defective, they will replace.
However you will the same problem, if you do not act right now.
God bless you
3helpful
2answers
Bowflex tc 1000 treadclimber
TC1000 from Bowflex, works okay for 15 mins then the speed surges ahead and stops dead with error E1
Bowflex Treadclimber Calibration Failed
Check the wire connection at the bottom of the right upright. Male Female white connectors. if they are good then check speed sensor under the left rear treadle. Must be about credit card distance from drive pulley. Remove rear covers to access. Note you will have to remove both side covers and back cover. 10 Screws.
Calibration fail message on bowflex treadclimber.....help
Unplug your machine, restart it and try to calibrate it one more time. I had to do this with mine and it did take more than one try to get it to recalibrate again.
28helpful
4answers
Error Code E1
I had the same error message E1 at 10 seconds according to the LCD display on an older Treadclimber TC1000. I called Bowflex 1-800-792-6784 and first thing they told me was to check the drive sensor on the back left corner of machine. It is two wires connected by 2 white connectors that snap together. The end of the sensor has a rubber cap that is supposed to be approximately 1/8 inch from the drive pulley. The rubber cap plugs into a small hole within the "firewall" of the drive pulley, but the end of the cap does not actually touch anything. They can email you a picture of it. If it ever gets knocked loose, the machine will register this e1 error, in some cases- hope this helps.getattachment.aspx&hm__qs=file%3d3d2f2ee0-2668-46ea-b32c-db049d56cb37.jpg%26ct%3daw1hz2uvanblzw_3d_3d%26name%3daw1hz2uwmdiuanbn%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253aimage002.jpg%254001c99c08.13bd6320&oneredir=1&ip=10.12.128.8&d=d6608&mf=0&a=01_0b590aaade5e800af268d347750ab151eca93264be20cd9ce2166e583b18cfe9
Top Bowflex Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
