My fan isn't working
The fan on my ac unit doesn't appear to be working. it makes noise but no cold air is blowing
    Master:
  • 613 Answers
You need to be clear on the problem. Not blowing is different from not cooling. The condensing unit (outside) creates the cooling. The indoor fan blows and circulate the cool air.
Posted on Aug 22, 2013
  • 146 Answers
Well there not enough data here to make a fairly good solution. but if all the fans are running! and no cool air then it is the compressor.
Posted on Jul 14, 2009
3 Suggested Answers
SOURCE: my ac works inside, fan comes on and blows fine
Hi, normally when your freon is low, system won't work, look for filter dryer, follow high pressure tube from compressor to condenser, filter dryer normally have sight glass where you can see freon moving in system, if there's bubbles, you need freon, freon should be charge until glass get clears, hey remember to always charge from low or liquid side of system.
Posted on Aug 02, 2009
  • 13 Answers
SOURCE: My outdoor AC unit is
check power to outside unit, check if it has a fused disconnect, if you have power and no blown fuses it could be a blown capicator that starts the fan and compressor...............
Posted on May 10, 2011
Only the fan works no ac and a pf code appeared
at first check fuses (internal) and if in use the internal filter.
Oct 19, 2014 | Heating & Cooling
My goodman unit (1994) makes the loud noise, like a buzzing noise. The unit works, the blower blows air into the house, the air is cold, but the outside fan that blows across the condenser piping isn'
you need to replace your condensing fan motor. the noise you are hearing is the compressor working against a lot of pressure because the heat is building up in you condensing unit. Prolonged operation without an operating condensing fan motor will cause your compressor to burn up, and then you will have the cost of a compressor changeout to the cost of a condensing fan motor.
Jul 06, 2014 | Goodman CLQ36AR49 Air Conditioner
'97 Jeep Grand Cherokee AC "Works and Stops"
Make sure your fan clutch is working. No fan, no cooling of the condenser, no heat dissipation, no cold air. Start the truck and make sure you feel air movement, a lot.
Aug 11, 2012 | Jeep Grand Cherokee Cars & Trucks
My 5000 BTU GE window AC is making sporatic loud popping or cracking sounds when the compressor is on and running. It has stopped blowing air! When I put my hand in front of the air vent I can feel cold...
Fan inside blower unit stuck or seized. The compressor noises are because liquid refrigerant is coming back because it's not picking up heat from the room. Check/ clean the filters and spin the motor of the fan WHILE SWITCHED OFF. If it spins, it's probably the fan capacitor. If it doesn't, get a new fan
Aug 07, 2012 | Heating & Cooling
Car blows warm air when idling
It sounds like your AC unit could be overheating or even damaged.
AC units have a sensor that will turn them off automatically to prevent damage from overheating. If there is an insufficient amount of air flow, the unit will heat up, and then eventually turn off.
When the car is moving, more air is forced over the unit, likely keeping it cool enough to run, however, when the car come to a stop, it loses that air flow, and quickly heats up. Thus, the AC would work while the vehicle is in motion, and overheat and stop when the car is stopped and idling.
However, the AC unit could be completely blown. The cold air while moving could be just a case of air being forced into the car. Think of a house fan, the fast the wind blows on you, the cooler it gets.... Thus, it could be an illusion that the AC is working when car is in motion, when it really isn't.
Hope this helps.
Jun 09, 2012 | 2004 Lincoln LS
My outside Kelvinator central ac unit will not turn on. I hear a faint humming noise coming from it so it appears that it is getting power but won't turn on. My fan in the house will turn on and...
Its possible that the contactor that closes to start the outdoor unit is not pulling in and passing power. You are hearing the coil humming since it is getting control power. Also first check that breaker for outdoor unit is not tripped
Jun 22, 2011 | Heating & Cooling
My outdoor AC unit is not coming on. Air is blowing out of my vents inside but the snowflake symbol on my thermostat is blinking and the air isn't cold. The fan on the unit isn't even running. Any...
May 09, 2011 | Heating & Cooling
My AC unit is not blowing cold. I have two. One small and one big . I just noticed that My upstairs was not cooling off. So I turned both units on and went out sid to check them. The small one is running...
The start capacitor is in question and the fan appears to be overheating, That is where the water camre into it. You may need a HVAC tech to make your repairs. Good Luck _Ned_
Oct 18, 2009 | Heating & Cooling
Heating & Cooling Logo
168 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
