Question about Whirlpool Water Heaters
It will work for few days then goes out. I reset the pilot light
Mine is propane it works for few days then goes out i reset the pilot light and it will work for a few days
    President:
  • 1,273 Answers
Hi. Some of the whirlpool water heaters are notorious for having plugging problems on the air inlet screen. They are the air slots under the burner. Clean the slots with a brush and re-light. You may need to clean them regularly.
Hope this was helpful!
Regards, --W/D--
Posted on Jul 14, 2009
My 30 gallon water heater works sometimes its only 4 years old other times we have to keep lighting the pilot sometimes up to 4 or 5 times it will come on run about 3 minutes shut off the the pilot light...
I have had a similar issue with my Reliance heater. The safest thing to do is replace the entire gas control. You will need the model no. and the serial no. to find the correct one. May have one in stock at some place like Ace Hardware, I found mine on the internet after getting the part no. from the Reliance web site parts dept. May be $75 and up. if you are on propane, there will be a setting in the new control to set for propane The orifices in the burner etc. are already set there. Be careful, it is gas. To change the control is easy, you will need a large pipe wrench to wrap around the whole thing and unscrew it. Drain the heater first, open a hot water faucet to aid in this. And be sure to flush the water heater before you re- light. Lots of videos on the internet on the proper steps. And of course turn off the water supply and the gas supply before you start.
Feb 21, 2011 | Reliance & 30 Gal LP Gas Water Heater
Bosch AquaStar tankless natural gas water heater pilot goes out periodically--after a few hours or a few days, whether weather hot or cold, whether windy or not. This condition has been the same from day...
I had a similar problem with mine and it turned out to be a plugged air vent sceen. This is the small dome like sceen on the gas valve. I vaccumed out the unit and have not had the pilot go out in over a year.
Nov 27, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
My pilot light goes out irregularly it's a reliance 606 propane water heater
If you still have your owner's manual, you will need to call the manufacturer. They will need the model # & serial #. This particular brand has a fine mesh filter screen on the bottom (below the burner) that gets clogged and causes irregular pilot outages. They have a recall in which they will send you a new burner assembly with a reset switch built-in to it. They will send it to you for free, but you will need to hire your local propane co (at your expense) to install it and also clean the filter while they have the burner assembly out. Good luck. Douglas
Oct 01, 2010 | Reliance Water Heater #6-50-DJRT 50GAL...
My refilled 60 # propane tank leaked and then stopped flowing.
Rick, if the tank is normally plumbed for a horizontal position, and you have it standing vertically, then you are feeding liquid propane to your pilot light, hence the frosted hose etc., and a tendency for the pilot light to go out as it has too rich of a fuel to burn. There should be no vent to allow air in as propane is pressurized, and only attains zero pressure at 40 below zero farenheit. The valve you speak of should have been the liquid vent valve which is used during filling only, and is closed during any other use. Your supply valve should be in the wide open position. The pressure relief valve is only operational when the tank has been overfilled or overheated. You should have a pressure regulator between the tank and the appliance you are trying operate. Hope this helped. Marvin
Jan 04, 2010 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
After a few minutes of burner heating the water, gas shuts off.
A couple of things to check:
If possible, remove the pilot gas assembly and clean the gas jet and thermocouple - they can get carboned up and stop working properly. Make sure the pilot flame and deflector is aimed properly and making the thermocouple glow red hot. If the problem persists, you may want to replace the thermocouple and also check the propane regulator.
Apr 20, 2009 | RTO Atwood Water Heater - 6 Gal LP
PILOT LIGHTING BUT CANNOT TURN ON WITOUT IT GOING OUT
change the gas valve, if the thermocoupling works and the piliot stays lit then it has to be the gas valve check to make sure the screen is clear also,, you said it's propane, check to make sure it is all the way turned on, and has the right pressure it might have a bad regulator on it, but will let other things in the house run good luck
Feb 25, 2009 | Bosch 1600H-LP Liquid Propane AquaStar...
Bosch tankless hot water heater 1600H
it sounds more like the ignitor thats messing up, if you are able to remove it and get a new one that would probobly do it for you
Nov 07, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
Water Heaters Logo
73 people viewed this question
Top Whirlpool Water Heaters Experts
Donni Steen
80stech
jdthefixer
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
