Question about Campbell Hausfeld Garden
My high pressure 2400 psi hose blew out.
Can i cut out the bad part of the 2400 psi 1/4 hose and put in a brass double male connector with hose clamps?
  • 174 Answers
Hi cwsales:
Sorry, the pressure will be too much for a your mend to work. You will just get wet. A professional hose repair shop is your best bet, or a new hose.
Posted on Jul 15, 2009
How do I fix my pressure washer when the high pressure hose keeps blowing off.
If hose fits over a hose barb try using a hose clamp from any auto supply store Or replace the hose barb GL
Oct 08, 2015 | Karcher K 367 M 1750 PSI 15 GPM Electric...
I see hose repair parts in house and garden stores. How exactly do they work?
Hi Colleen:
Easy as 1-2-3
1- Cut off the bad fitting
2- Slip the clamp over the hose and push the replacement fitting into the hose
3- Align the clamp and tighten it.
Back to the garden!
May 21, 2015 | Garden
How to replace breakline 1998 Nissan frontier
You have two choices, either replace the whole line, or just cut the bad part out with a tubing cutter, then purchase a pre-made line the same size & length that you cut out, you can take the old line to the auto store & match it. While your there, you also need to couplers, which are female on both ends and 2 male connectors that will fit into the couplers you just bought.. Now you'll also need a double flaring tool (cheap at Harbor Freight).The brake line that's still on the car, you want to dry & either emery cloth or steel wool the ends where you made the cuts. Now slide 1 male connector on each side, then double flare each end of the tubing. once that's done you can put your new female couplers on each end, then connect the new length of tubing you just purchased to both couplers , the new tubing already has new male connectors , and is already flared for you. Not a hard job if you have the flaring tool. good luck. Don't forget to bleed the system when done.
Sep 20, 2014 | 1998 Nissan Frontier
Water hose won't come off pressure washer
release pressure by squeezing trigger then grab the brass quick connect fitting at the knurled section (at end of hose) and push it toward the pump. when properly pushed back, the hose connector will pop out.
Aug 11, 2014 | Craftsman 2700 PSI Briggs Stratton...
Karcher 3.190 breaks hose coupling connector
use high quality brass fitting, low quality brass will break also,replace male and female side with matching brands
Mar 30, 2014 | Karcher Garden
I can use my Karcher K3 jet wash as long as i hold trigger down
Most pressure washers have ball lock type fittings on the hose connections. What happens is the little steel balls get a bit of corrosion and do not lock the male fitting properly with the female coupling. Load up the fitting with some Oil or WD 40. Then connect and disconnect the fitting several times to losen up the balls and springs. Should the spring in the coupling break you will get the exact symptom your describing.
If the OIL / WD 40 does not do the trick then you may have to change out the quick disconnect coupling.
Kelly
Apr 18, 2010 | Karcher PSI Electric Pressure Washer
How Do I connect a cut rubber fuel line on a Buick Century
Ouch! call around to parts stores there is a nylon hose kit repair with barbed ends & clamps.Good Luck care around gas
Aug 30, 2009 | Buick Century Cars & Trucks
Karcher 2400: Won't stop spraying.
Dear sdadean,
I am assuming that when you said "wand" you mean the "gun". Myself I rarely service guns. But there are types that are serviceable and others that are not. If the brass elbow had 2 stainless steel pins....then this is a gun that you must replace with a new one. And putting oil, is the worst enemy....because oil damages O rings. Now the high pressure hose is fitted inside the brass part by being sealed by a black O ring and a white backing flat O ring. I do not know if these that you saw. Now if the brass has only one pin coming out from the back, this type of gun can be serviceable. Look at the brass at the place where the lance is attached. If you see a hexagon hole, this is a plug that can be unscrewed with an allen key. Behind the plug there is a ceramic seating. Then you find the valve and a spring. If the steel valve and the ceramic seating are damaged, the whole gun must be replaced.
To tell you the truth I usually change the gun and fit a new one, when the machine keeps on going because the gun does not close. I find it the best and the most safe way of solving the problem.
Regards,
Fulltech.
Apr 27, 2009 | Karcher 2500 PSI Pressure Washer
The high pressure hose has been cut. is there anyway to safely join together. IT is a 2400 psi high press water hose
There are hose kits to join the hose together. Do not try it with just a clamp as it might result in injurie. I am guessing you are not talking about a washing machine but pressure washer. A new pressure hose is not to expensive. You can get them for every brand
Jun 19, 2008 | Washing Machines
Garden Logo
170 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
