Question about Garden
Craftsman Edger Pops while running
Hello, I have craftsman edger with a 3.8HP Tecumseh. I have rebuilt the carb, changed gaskets on noth sides of manifolds, and cleaned off flywheel pickups and coil, then set gap to .016. It seems to run decent, but under no load, it pops and breaks up a bit. I am pretty sure the carb is fine and even tried a known good carb, with the same issues. The plug seems a bit white to me, but it doesn;t have much run time (new plug). I also tried raising the float height a bit and lowering a bit, no difference, if anything a little worse each way. I have it set now where a #4 drill just fits between float and carb body (float is about parrellel to carb body) Any suggestions what to try next?
  • 155 Answers
Hi you have your float set about right but your air gap should be at .010 , The other thing you can check is wether the flywheel key is partly sheered i have seen this a number of times and they still run.
Posted on Aug 04, 2009
Looking for the part number of the air filter on craftman edger model # 53685648
On the Sears Parts Direct, they show no air filter. I would recommend taking the filter to a small engine shop so they can match it up or just go to Home Depot and match it up with one of their filters they may have in the lawn and garden. Lowes has a small engine section too, most of their stuff is Briggs and Tecumseh. Here is your parts diagram, with no air filter shown.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Edger-Parts/Model-53685648/0247/1503400?sid=PDVertical
Aug 13, 2011 | Craftsman Gas Mini - Tiller/Edger
I have a craftsman 536-797572 edger and i cant get the primer bulb to pump fuel. it is like it not pulling gas out of the bowl.have had carb rebuilt
You solved this one yourself. You had installed the wrong primer bulb, but after installing a different one, the machine ran great. Problem solved.
Nov 23, 2010 | Craftsman Garden
I have a craftsman edger that want crank. If I
Some have a fuel cutoff valve between the tank bottom and the carb..Is it on?Also carb may need cleaning or stuck float.RICHARDM69
Aug 24, 2009 | Craftsman Garden
Craftsman mini tiller starts good but will not idle nor run fast
i'm having the same problem. cleaned carb but didn't help. I found that if I spray starting fluid on the gasket between the carb and the motor it speeds up. I'm going to try to find a new gasket, I can't tighten it anymore.
Good luck
Jun 30, 2009 | Craftsman Gas Mini - Tiller/Edger
Craftsman 2.5 hp edger stalls
it sounds like the the carb. either it needs cleaned of the float inside isnt working i would say to just get a new carb. if its possible concidering the age but try to clean the filter first im sure it has one sry but thats all i can think of
Jun 06, 2009 | Craftsman Gas Mini - Tiller/Edger
Craftsman Edger 536-797520 is leaking gas from the air filter
The needle valve is sticking open. The carb needs cleaning and diaphragm replaced. Probably best taken to a shop unless you have experience with diaphragm carburetors. Dwain
May 27, 2009 | Craftsman Gas Mini - Tiller/Edger
Craftsman 25cc edger has trouble starting. once started it will run for 5 - 10 minutes and then shut shut off. Will not start again until it cools down. Changed the spark plug , but it has the same pr
Dump the fuel in the tank, get new gas and new oil and start over. Get a carbeurator cleaner additive for the gas as your carb. is dirty resulting in the sporatic operation.
A spray carb. cleaner that you squirt into the air intake by removing the air filter will also work for you. In fact, when you are getting the carb. cleaner get a new air cleaner and a new spark plug. get back and let me know how u make out.
May 20, 2009 | Garden
Garden Logo
85 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
