Us sertek scanner
I am having trouble installing my scanner. i have it plugged from the scanner hookup on the scanner to the printer port on my computer but i get the message that i am scanning at less than optimal speed and failure to adjust to adequate color balance. This shows up when it says test to see if scanner works properly. Need help.
  • jimbo39 Nov 18, 2007
    no just parrelle
    Sergeant:
    Champion:
  • 298 Answers
Does the scanner also have a usb
connection?
Posted on Nov 18, 2007
  • Eugene Merritt Nov 19, 2007
    check the manual to see if
    there is parallel port bios
    setting preference for your
    scanner spp epp bidirectional
    spp will get in runnning but
    other settings add more speed
When i try to print something computer says i dont have a printer installed
Make sure the printers usb and power leads are securely seated
the drivers for the printer might have been corrupted
you might have to uninstall the scanner restart your computer then reinstall your scanner
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow Question/exclamation ? ! mark or a red X this will mean you need to install a new driver for this device right click to update driver
select properties again you will have the similiar options also have option to troubleshoot
hope this helps
Apr 17, 2012 | Dell Photo 926 All-in-One Printer
Card does not appear to be communicating with a KodaK i840 scanner. How do I trouble shoot this?
the drivers for the?scanner might have been corrupted
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port?and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also have option to troubleshoot hope this helps
May 18, 2011 | Kofax Adrenaline 1700s (EH-1700-1000)...
I am having trouble using the scanner.
the drivers for the scanner might have been corrupted
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
hope this helps
don
Feb 26, 2011 | Canon PIXMA MX340 Wireless Office...
Can't print to Konica 7030 via Parallel
You do not have the print/scan option installed on your copier. If you did you would have an ethernet port on the machine for network access and when you press the print/scan button on the control panel you would be able to access those functions. The fact that you can not means that the machine can not see that option because it is not installed. The parallel port is common and is used for uploading of firmware into the machine.
Thank You for using Fixya.
Apr 30, 2010 | Office Equipment & Supplies
Where is the port for a computer hookup
The USB port is hidden inside the unit. For pictures see here: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000500/000057/faq000557_002.html?reg=us&c=us&lang=en&prod=mfc240c_all&Cat=2
Use the plastic tabs on the sides of the machine to lift the scanner cover up until it locks in the open position. Behind the control panel on the front, the USB cable port on the right (sort of in a ditch). Route the USB cable through the trench and out the back of the printer. Then connect the other end of the cable to the computer. (direct connections are preferred, self-powered USB hubs usually can work. Bus powered hubs often can not send the scanner data properly.)
I hope this helps.
Apr 18, 2010 | Brother Multi-Function Center MFC-240C...
Hp PSC2355 scan function inop
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aswq9
Aug 25, 2009 | HP Officejet 5610 All-In-One InkJet...
Lexmark 1270 scans but will not print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Dec 13, 2008 | Lexmark X1270 All-In-One InkJet Printer
Need help to hook up IBM color flatbed scanner
Attach one end of a parallel port cable to the parallel (printer) port on your computer and the other end of the cable to the computer port on the rear of the scanner. If you have a printer connected to your computer, you must disconnect the printer cable from the computer before connecting the scanner cable.
If you have trouble attaching a cable connector to a port, be sure that you are connecting the correct end of the cable to the correct port.
IF. . . you want to use a printer WITH your scanner, attach one end of the printer cable to the printer port on the rear of the scanner and attach the other end of the cable to the printer.
Plug in power cord and then power up PC.
Power on scanner. Install drivers. Restart PC to activate EZ Station buttons.
Oct 11, 2008 | IBM Color Scanner Flatbed Scanner
Ricoh ac204
You probably need the whole application to get it to work. Usually Ricohs use a memory resident program to control scanning functions. That way you can fax or scan to e-mail with them.
You can check on www.ricoh-usa.com to see if there is a Twain driver for that particular model.
Jun 09, 2008 | Ricoh AC204 All-In-One Laser Printer
Connecting my HP ScanJet 5200C scanner to my HP Pavilion Home pc
Rookssailor,
I don't think you can (successfully) run this scanner off the paralell port. I'm drawing on memory here but I think this scanner has serial and usb ports. If you are running Windows XP, use the USB hookup. If you are running Windows 95, 98, Milliniaum then you might want to use the serial port. At any rate the scanner software should be installed before you plugin the scanner.
If I'm completely "full of it" and you really want to use a Paralell connection then you might want to use a paralell to USB adaptor (Belkin, perhaps others make one of these).
haMAR
Apr 01, 2008 | Office Equipment & Supplies
59 people viewed this question
k24674
jasbo
jasbo
