Question about Kenmore Refrigerators
The starter overload has melted!!!!! the fridge ran for 2 hours not cooling then stopped has not started since this fridge was turned off for 18 months compressor motor could survive this???
  • 585 Answers
The start relay device is known to break down and can do so without damaging the compressor. About all you can do is replace the two parts and test it. Be sure to clean the compressor terminals for good contact when replacing the parts.
Posted on Jul 14, 2009
Why is my smeg fridge not keeping anything cool
Hi...the same thing has happened to me. My Smeg Fab28 refrigerator compartment has stopped cooling. The freezer still works. There was a build up of ice on the back fridge wall, and the milk was freezing up, so I turned down the temp. After the ice melted, I heard a bang like a bunch of ice had dropped. I turned the temp back up but it steadily stopped cooling even more. I decided to defrost the freezer, and had the power off completely for about 5 hours. When I turned it back on, the freezer worked, but the fridge is not cooling AT ALL.
Did you fix the problem and if so, how?
Thank you
Bev
Jun 02, 2014 | Smeg Refrigerators
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
Electric starter will not switch off, unsure why
Sounds like you had to disconnect the battery to stop the starter from spinning.
I've had that happen quite a few times and heres what i found and did to fix the problems.
1. I had an old american bike in the shop with a low battery. I didn't know the battery was
low when i hit the start button. The starter solenoid stayed engaged, and the starter kept
turning over the motor, I pulled the battery terminal off to stop the power to starter.
I check battery and it was low, i put full charge on trickle charge and then let it sit
a 1/2 hour before i tested it with the load tester.
It failed big time, dropped all the way to bottom of the scale under a load test
Installed a new battery and fixed the problem. The solenoid, start button, kill switch, key switch all works, it was just a low battery.
2. I had a customer call me because he ran out of gas, when he got gas he turned the bike over for a long time trying to fill the carburetors with gas,
Never hold the start button down for long periods of time. He did and the wires got so hot that the positive wire from the battery to the solenoid melted and stayed engaged.
It was an easy fix, replace the melted solenoid, and only hold the start button in 5 second intervals, allowing it to cool in between starts.
Once the bowls were full again and the bike starts, then it only takes about a second for the bike to start so you normally dont hold the start button for that long.
Hope this helps
Big Al
Jul 25, 2011 | Aprilia Ulysses XB12 XT Motorcycles
My beko frost free fridge freezer has stopped cooling the fridge and the freezer has now stopped freezing.electric is working,but it makes a strange noise.tried turning it off for 24 hours but the problem...
Sorry to read about your problem. you can have many different problems.
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I suggest you call a service company.
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Refrigerators
Why is my fridge buzzing?
The compressor is trying to start. The overload kicks out and then it takes 10 min or so for it to cool enough to try starting again. It could be a bad start relay or a broken compressor.
Eric
Nov 08, 2009 | Refrigerators
I have an Amana bottom freezer fridge model ARB2517CSR the freezer stopped working I cleaned the coils and the fan was working and the fridge was making a buzzing sound. The sound stopped, so did the...
If the coils were really dirty, the compressor is probably just overheated. Let it cool down overnight then try again. If it still won't stay running it needs serviced. Could be the start relay or internal overload/overheat sensor in the compressor. If the coils were really dirty and it was used like this for a long time, the compressor could be damaged. It is almost never worth replacing a compressor in a home refrigerator.
Jul 03, 2008 | Stainless Cruise 49 Marine Refridgerator -...
Help w/ Refrigerator Compressor Overheating?
I had a similar problem yesterday (Maytag side by side unit 5 years old, however this apply to most brands). All operation seems normal other then that the refrigerator was not cooling, the air that was blowing inside the refrigerator was room temperature and not cold air. The compressor was also very hot to touch (could not touch it for more then 1-2 seconds) and didn't buzz or hum as in standard operation. I also heard few clicks from the compressor every time I plugged / unplugged the AC to the fridge. Replaced the overload/ relay device with a new one I got at a local appliance parts distributor ($30) and MAGIC. The unit went back to work as soon as I plugged the AC power. The relay/overload unit is on the side of the compressor and that?s where the electric wires are attached to. The unit turns the compressor on and off. The unit is attached to the compressor side with an "electric outlet" like three holes and three prongs. It might be held tight so you can pry gently (between the unit and the compressor body) with a screwdriver. Once pulled out, release the wires connectors that are attached to the relay/ overload unit. You might need to use pliers as they are tight fit. If unit smells like burnt or if you shake and hear rattle then it?s bad. Find a local appliance parts distributors and call to see if they have part for your model/ type. Remember to unplug AC before starting to work on the fridge and good luck.
Jun 29, 2008 | Refrigerators
RS21 DCNS FRIDGE COOLING FAULT
There is a fan behind the plastic. This distributes the cold air throughout the fridge. What happens is this fan stops turning due to freezing up. A temp solution is to unplug the samsung for 6-12 hours to allow the ice to melt from around the fan. This is a known design fault. It is easy to dismantle the plastic cover and defrost the frozen fan with a hair dryer, this way the fridge will only be off for about an hour
Aug 14, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerator not cooling.
compressor has failed. not a diy job
Apr 25, 2007 | Amana ASD2622HR Side by Side Refrigerator
Refrigerators Logo
65 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
