Nintendo GameCube Console
Problem for Nintendo GameCube Console
Gamecube, output problem.
By irketk on Jul 14, 2009
My Cube is a slightly newer model,
it has two outputs for both the analog and a digital on the back.
It was working fine. I played it one morning, then I turned it back on later that evening and I got a blank screen. I triple checked all the connections. The cube has power(bought a new power cord and tried other working ones from friends) the light turns on as normal. I've tried 4 different cords ( 2 new) that plug into to the TV all made my Nintendo.
The disk is spinning, and the familiar whine of the cube when it loads a game sounds normal.
however, blank screen(not a TV problem Already checked,I have several other consoles that work on multiple TVs). My guess is that the cube switched its output to the digital cable, witch I have looked for at stores but never found one.
I need some step by step instructions on how to switch it from the digital output to the normal analog output. any help?
Solution #1
posted on Aug 20, 2009
Not Rated)
jdensonjr
Rank: Guru
Rating: 87%, 13 votes
There is no way to switch this back and forth, if the rca jacks work and the fr jack doesnot there is a problem extending from the game unit itself which works on a certain amount electrical current to maintain signal which is not required for digital/rca. check your rca connections, if they work then your problem is in the rf converter and it should be replaced and or just purchase a cheap switching unit that splits between the rf and the rca on channels 3 or 4. Good Luck and let me know what happens.
Fehdi
Was this helpful?
Yes
No
Popular Solutions for Nintendo GameCube Console
Questions and Unsolved Problems for Nintendo GameCube Console
Do you recommend Nintendo GameCube Console?
Answer
Answer
I get a screen, but it won't start the program.
Answer
my gamecube won't start up. what should I do. I am one of those people that opens up their systems... (More)
Answer
game cube says error when turned on any ideas how to fix
Answer
when I turn my gamecube on and I have the game in it. it say's to turn off and read the instrution... (More)
Answer
I put my AV inputs on the AV 2 slots. Every thing Thing is connected in the Wii. I have an Insignia... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
