Question about Pantech C300 Cellular Phone
Car Charger Won't Charge, And Phone Doesn't Work In Most Areas, In The Woods, Northern CA
I don't know where to go from here. The works fine, if I'm in the right area, but I can't charge it in my van. The cigarette lighter works, but not the charger. I don't want to buy another and I don't know what the problem is. I'm thinking about getting a CB radio, in case I need roadside assistance. Donna
    Sergeant:
  • 316 Answers
Most car chargers have a fuse in them usually 2amp.
it is possible this fuse has blown.
if you can unscrew the end of your charger you will find the fuse
BE CAREFULL the tip is spring loaded and will shot apart so make sure yoou keep it under control
Posted on Nov 16, 2007
The car charger in my 2003 honda accord doesn't work
Could be the fuse for the cig lighter or the fuse in the charger.
Will the charger work in a different car ?
Apr 15, 2013 | 2003 Honda Accord
My accessory plugs don't work but the cigarette lighter does
sounds like the power end of the GPS is faulty.
Oct 10, 2017 | Kia 2008 Sorento LX
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
When I attempt to charge my moto q via an power outlet or car charger the charge powers the phone but not the battery. when I attempt to charge it by computer it there is normally a 30% chance it will...
I have the same problem with my iPhone. The only real way and best way to get a charge on a phone is through a wall charger. Car chargers and computer/usb to charge doesn't actually do anything but "top off" the battery. They don't produce enough power to give the batter a strong charge like the wall can.
That's my best advice. Charge from the wall when at home. Use the car to top off when your on the go.
Oct 20, 2011 | Motorola Mobility Moto Q
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
My Garmin nuvi 265 was working fine until 2 weeks ago. We got a screen message saying that the XM traffic was not supported, and then noticed that the unit no longer could be charged using the car...
The traffic receiver is in the car charger cable. The charger should have a red light on if it is getting power. If the light is on and the unit is not charging and you have no traffic, the charger cable is bad. If the light is off, then either the fuse did not fix the problem, blew again, or is somehow not sitting properly in the charger. Another thing you can check is by using the unit in another vehicle. If it works fine there, then the charger is not making good contact with your vehicle outlet for some reason. You will probably have to buy a new traffic receiver charging cable.
May 04, 2017 | Garmin nuvi 265 Car GPS Receiver
Lg viewty wont charge
Ok, there`s 3 things that could be wrong.
1.battery
2.charger
3 phone fault.
Your best bet is to go to where you bought thephone.
Tell them whats happened, ask to try a new battery,if that doesn`t work (using your charger), try with a different charger,if those two don`t work then it will be a phone fault.
If you have a warranty use it for an exchange in my opinion. Hope i`ve been of help.
Dec 14, 2009 | LG KU990 Viewty
Wont charge
Try a car charger. If the car charger works, then it is either
A) Your power outlet
B) Your wall charger Power Supply unit
C) The phone connector on your wall charger.
If it doesn't work on the car charger, then it is most likely your phone charging system or the connection for charging on your phone. Either way, you will most likely need a new phone. Sorry.
Sep 23, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
LG Venus does not charge with the car charger,does w/home charger
Hi friend, if you have any problem with Phone repair Solution and repair tools,or car issue, please read on www.vipprogrammer.com. all of phone repair tools, and you can find it. or add whatsapp: +8615767956655, all the help is free, and we have high quality phone repair tools with Lifetime Warranty and we are China Brand Universal Programmer Online Shop, reply me to know more:)
Sep 26, 2017 | LG Venus VX8800 Cellular Phone
Pantech C300 Cellular Phone Logo
655 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
