Question about Whirlpool GEW9250 Electric Dryer
Dryer won't heat up
Had repair guys out three times one replacedthermostat and didn't fix it one said it was ok and the last one looked at it and said the vent was plugged because the heating element would go out after a few minutes. I ran the dryer with no vent and did the same thing it did before and checked the vent that was not plugged. the dryer sounds as if the blower cuts off when the vent is off and you can feel the thing cut out. Wonder if the blowers are malfuntioning and not moving out enough heat and tripping the thermal cut off. My duet washer was a nightmare as well I think these products are poorly built.
    Problem Solver:
  • 9 Answers
You've got an intermittent open circuit in a gas valve solenoid---for about 10 to 20 bucks you can buy a pair on line and do replace them as a pair if one is going the other will also soon.
If you keep messing with it it may stop igniting completely---then you can test the 2prong solenoid to be sure this is the problem---should have about 50ohms.
Posted on Jul 14, 2009
Dryer overheating on timed dry/no heat settings
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Mar 20, 2014 | Frigidaire Electric Dryer
Dryer won't heat
Odds are the Heating element is out. Only repair is to replace it.
Oct 29, 2012 | Maytag Dryers
Remote to tv doesn't work
Hello
Check the remote first for its infrared emission. If it is OK, the infrared sensor inside your tV is faulty. It should be replaced with same type and number. It can be located just behind the infrared window at the front panel of your Tv. You ahve to open your TV ot access it. It will have three solder terminals, and will look somehat brownish black in colour. Will look like this.
Nov 14, 2011 | Televison & Video
How do i find and test heating element?
I suspect the THERMAL SWITCH on the element case
but not enough tech info in question to pinpoint problem, so I'm including this website to help in your repair
http://appliancehelponline.com/index.html
I'm also including my article on dryer repair. If you read it very carefully you find a generic answer
Here it is:
DRYER REPAIR,PSYCHOLOGICALLY
This is NOT a manual for step by step instructions. This is a manual to learn the correct way to approach any repair. Yes I said ANY repair. I think you will be amazed at your own abilities after using my techniques!
What I want to impress on you is that you have STARTED. Psychology, right?
Most of my repairs, I repeat MOST of repairs are usually so simple that you probably won't have to move the appliance. But I want you to know that you have STARTED,
again. Why do I keep repeating this silly affirmation. Because you are striving hard to
think of some reason to abandon the repair.
Your mind is desperately trying to abort any attempt to reason. YOU WILL PROGRAM YOURSELF TO FAIL. It's really quite simple. You are conditioned to fail by many of societies warnings, such as: "Call a qualified Repairman" or "Do not attempt to repair" or "Only qualified repairman should attempt repair." Completely ignore those warnings. They are just an excuse for you to terminate the repair attempt. (but use some common sense like unplugging the appliance before any attempt at repair) And you may have to learn some rudimentary form of electricity before you tackle the electrical plug.
I repair hundreds of appliances yearly. It's your appliance and you can take a hammer to it if you decide. (some have) and you can surely attempt to fix it if you want.
Once you accept the concept that you will start to repair (your dryer, lets say) I
want you to stand in front of it and say under your breath: Now that I have STARTED
I am 60% finished. Cool. You didn't know you were that good. But that generally is
absolutely true! Again, MOST failures come from NO self-confidence! I cannot emphasize this enough.
Materials Needed:
Ohnmeter,Phillips Screwdriver,5/16 and 1/4 in. sockets,Pliers,sidecutters,Determination
1. Overcoming your worst enemy-Procrastination!
Most of my Service Calls come from customers who won't even take a look at the
appliance in question and most repairs are very simple. ( I have even made calls more than once to plug the service cord from the washer into the wall) Most ovens have a
timed bake set by a clock You guessed it, I reset the clock and am then an instant hero.
On many occasions I just reset the breaker at the breaker box and the dryer starts
humming like new. Gosh. We've just covered about 20% of a repairman's day and you
really haven't done any work yet. Let's see about the other 80%.
As I have said most repairs are fairly simple (but not all will be as easy as plugging the
cord into the outlet, although not much more complicated.)
Let's go back to standing in front of the appliance muttering (intelligent muttering)
where you are 60% finished. Let's repair that dryer that won't heat with the other 40%
effort.(while thinking of what to do with the cash saved on this repair, since "qualified
service calls alone without any labor or time or parts added, runs from 29 to 90 bucks a pop.
Let me run through my personal "diagnosis check" just to see if there is any thing that you can't do. I stand in front of the dryer and talk to the owner.(that would be your wife or your husband whichever case it may be) You need to know the exact complaint.(in thiscase, there's no heat.) Once the problem has been pinpointed, I look behind the appliance,
(still without moving it, I am thoroughly trained to look for something SIMPLE)
Is the cord plugged in? Is the vent squashed against the wall preventing free flow of the exhaust? (this is very common, then it's a simple matter of moving the dryer out a few inches)
2. Setting your mind
O.K. now you are 75% through with the repair. Still AMAZING, right? And you haven't done any complicated work yet! Do you see why I insist that repair is psychological, because you will have repaired 75% of inoperative dryers (or most any appliance) if you just check the obvious first. I know what I am talking about from experience.
Check the breaker(no work), check the cord into the wall(no work), check the vent hose(well, you do have to lean over to see behind the dryer, very little work) Do you see anything that you or most anybody else can't do! and you will have "repaired" the appliance 75% of the time!
But you say what if it's some thing "serious" like electrical wiring or the motor orsome part that I know that I know nothing about. Yet I have to remind you again and again that it's PSYCHOLOGICAL!
3. Actually Doing it when you set your mind
First, electrical wiring problems are almost non-existent as a serious problem and if it is then it usually exceeds the cost for an economical repair.(Even an electrical engineer with years of college would not be able to repair those kind of problems without consulting electrical diagrams, charts, running wiring diagram checks.) How much do you think you would pay for that! More than the appliance is worth! Not even the "qualified" repairmen attempt very many "electrical wiring" problems. You just assumed they did. Right?
And that's not to say that we don't repair "electrical" problems. In making excuses to yourself of reasons not to attempt a repair, "electrical wiring" is the chief excuse. Well, it should be the least excuse since electrical wiring problems comprise less than 1% of repairs. (unless you include the plug-ins at the end of the wires that plug each wire into a part such as the element, but these are easily seen and are easily repaired.)
O.K. we are 75% through with this dryer(keep in mind that this includes washers, air conditioners, refrigerators or most any appliance or most any kind of repair since we are
speaking of Psychology rather than knowledge.
If I didn't "repair" it already with the simple steps above, I will unplug the dryer and lean it toward me(still without moving it). See any thing you "can't do yet?
And then I remove the vent hose and six screws that hold the back panel.(most dryers are accessed this way, although some are accessed by removing the FRONT panel which is even better because you only remove usually TWO screws and you don't even have to lean it forward or move the dryer at all except to unplug it!(most dryers have a panel front an back depending on what area you need to access)
Any thing I have mentioned that you can't do yet? I accessed the back panel because this is where most dryers "heating element" is located and since our "example" dryer doesn't heat, this is what we want to check.
Now you will see lots of wires going in every direction! Don't let that intimidate you!
Remember we are still looking for something simple. Ignore all the wiring and you will
look for the element. It's usually very obvious and has two terminals plugged into it(the
element terminal wires are usually always RED!
Now I have to get technical(not really) We have to check the element. If you don't know how to use a volt/ohmmeter (very simple) unplug the two wires to the element(you can't plug them back wrong) unplug the two wires from the thermostat on the element
(some have two more wires to a fuse on the element)
After removing the wires, then remove the element(usually one to three screws) and take to the appliance parts dealer who will check it for you while showing you how with a volt/ohmmeter.(I pay 8.95 for a cheap volt/ohmmeter which has many other valuable uses other than appliance repair such as checking wall outlets, etc.
After checking the element on the dryer(without removing it) I replace it(by only removing one to three screws), repl install the back panel, install the vent hose and lean the dryer back in position. See any thing that you can't do, yet! Now you're 100% through with that previously intimidating repair. Now all you have to do is accept praise and wait eagerly for the next "challenge".
Remember, I didn't give the step by step instructions to fix the dryer as "how to" but
entirely to impress upon you that it's not complicated at all!
Leo Ponder
imufo2
imufo2@sbcglobal.net
TO GET THE REFRIGERATOR REPAIR ARTICLE GOT TO MY TIPS AND TRICKS
Aug 13, 2011 | Amana NED7200TW Electric Dryer
I have a MAYTAG MDE6000AYW Series Dryer. It does not heat up, it makes no noise, tumbles, and the lights work, what can I do to solve the no heating problem with the dryer?
the heating coil needs fixing you can fix it yourself but try a repair man first allot of them come too your home and fix them so choose your repair guy wisely...
Apr 12, 2011 | Maytag MDE6000 Dryer
Hello I have a whirlpool dryer model #LER7648KQ2 It is only 5 years old and it never went off last night I think the timer is broken and now it is not heating so is that a fuse or the heating element
Mine had the same problem. A repair guy (overcharge me) replaced a thermal fuse by opening up the back of the dryer, took 10 minutes. I can do it next time and save $125. Well lesson learned.
Dec 28, 2008 | Dryers
My gas dryer stoped heating. When ever the lint filter gets to full then that is when we have to call the repair guy. this has happned before but this time we want to fix it ourselves. could you give...
First you need to clean the lint filter more often. Now with that said you probably over heated the thermal fuse and that needs to be replaced, Take your model and serial number and google parts for your dryer and purchase a thermal fuse.
Unplug the dryer, safety first!
remove the dryers backpanel, on the rear of the dryer venting is the thermal fuse, replace as needed, if you can use a VOM meter check to see if it is open? now with the dryer moved out of the way make sure to clean and or replace the venting as needed, The dryer needs to breath and if it cant it will take another thermal fuse out.
One last thought, how old is your dryer? 12 to 15 years and has done a load of clothes every day for your family of ? it may have worn seals and I would suggest its time to look for a new dryer.
Jul 03, 2008 | Whirlpool Dryers
Whirlpool GEW9250 Electric Dryer Logo
180 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
