SOURCE: 97 Grand Am electrical problem
If you hooked the small wires that are supposed to go on the big stud onto the small stud this will keep the starter activated. Also could have got a bad starter out of the box it happens.
SOURCE: won't start, no turn over, no lights, nothing
Check the manual for the location in the underhood fuse box of the 80A battery fuse. None of your car's OEM parts will work with this pulled or blown.
SOURCE: Nissan will not start, battery good, fuses / links good
there is no further fuses iin this line. You didn't say why your car wouldn't start in the first place. Jump starting yours, shouldn't have affected his!
SOURCE: 1999 buick regal will not start,check battery
Check your Neutral Starter Switch my 95 Bonneville had same symptoms and i replaced the Neutral Starter Switch and it started like a champ
Hi. No it's not working no electrics what so ever
I would check and make sure there is voltage in the battery and then check the main fuse that is right next to the battery. If both of those are good you will need to test for voltage at the back of the switch. If you have voltage there, you will need to make sure that you have voltage out of the switch when you operate the key.
