Ge model agv12abg1 window air conditioner thermal overload cut's unit off after about 2 minutes, (unit get's extremely hot on outside right upper corner of the case), but will cool in approx 1 minute and the unit will come back on for another approx 2 minutes, any ideas?
  • 534 Answers
Sounds to me as if the heater and a/c may possibly coming on at the same time causing too many amps to be pulled from the electrical box causing the overload to be tripping. You should also check to insure there is a clean coil. If there is a dirty coil or any type of blockage to the coil it will cause a compressor to over heat and trip the overload switch.
Posted on Jul 15, 2009
Do I need a new control panel if my compressor kicks off every 2 to 3 minutes?
check the outside unit is clear and has lots of air flow, try cleaning the outside with a garden hose, most likely the compressor is cutting out because it is getting too hot.
Jul 19, 2015 | Heating & Cooling
How I can fix g.e airconditioner
Motor is getting hot and going on thermal overload when it cools off it will work again replace the motor that will fix your problem
Sep 02, 2014 | Heating & Cooling
Why is my Intertherm P681S unit getting hot and the fan is is stopping?
Is the outside running? Is the outside fan running? Probably what is happening the fan outside quits running and the compressor gets hot and goes into thermal overload. need to check to make sure the outside fan is running.
Aug 30, 2014 | Heating & Cooling
Model 630516.331 not running
a possibility you haven't looked at yet, and is most likely the issue is the run capacitor for the fan motor
Jul 05, 2014 | Dometic Rooftop RV Air Conditioner
The black pull out or push in button for vent should it be opened or closed while using the air conditioner unit?
Here are some factors you can consider, when YOU DECIDE:
1.) Do you need fresh air in?-- (Like venting hot, or bad smelling air?)
Then open the vent for a few minutes--
2.) Is it hot and muggy outside?-
Then yo will be bringing in that muggy air--
OK for a few minutes, to freshen up things- but not for long term--
(For the humidity from outside, is going to overload your cooling capacity quicker.)
3.) As time goes by-- you are lowering the humidity inside the room--- Opening the vent will raise the humidity inside.
Does that help?
Mack B
Jul 04, 2011 | LG Heating & Cooling
The unit after running for ten minutes blows hot air inside the house
Service your unit completely and then check the following. 1. Thermostat setting must be minimum +3 degree from your temp. 2. Check room temp sensor 3. Check your out door unit fan motor. (If the outdoor fan runs with less rpm the compressor will get cut off by overload protector)
Dec 13, 2010 | LG LS-L1210CL Mini Split Air Conditioner
My air stops running inside before it get to the temp. Its set for but the outside unit keeps running and after a minute or two the air will start blowing inside again but the outside unit never turns off...
you have a possible thermal overload problem in your furnace blower motor dirt will cause this problem when it doesnt allow air across the windings of the blower motor if not dirt the motors going bad and getting hot use a shop vac and eliminate dirt keep your filter changed and your evaperator a coil may also need checked for cleanliness this will require cutting into plenum my advice someone qualified and remember dirt kills
Jun 18, 2010 | Goodman CKL36AR36 Air Conditioner
My carrier air con unit is a problem
There is a low voltage wiring problem. Make sure your t-stat wire is in the correct positions and that you have not removed the jumper wire at the t-stat. There should only be 2 control wires leaving the airhandler and going to the condenser unit outside. Unless it is a heatpump. One wire goes to common and the other goes to the Y terminal. W terminal is for heat. The unit will cut off if you have the unit calling for heat and cool at the same time.
Jan 05, 2009 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
111 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
