Question about Dell Inspiron E1505 Notebook
Strange faint gray/blue screen
I can get through the BIOS, then XP tries to load but the little dots running horizontally come to a stop before the welcome screen can load and the screen goes blank with just the backlights running. An external monitor shows identical scenario. I'm a little baffled. Video card, inverter and screen all check out in an identical laptop when installed there. This is a Dell e1505 laptop. I had put another hard drive in it two days ago and it bootefd through a strange boot-up slow down with many brightly colored squares. XP was jerky at the desktop and an error message said I had "no physical wireless adapter attached". Stranger still...I was online through the windows WLAN.
    Scholar:
  • 35 Answers
It sounds like there is a critical error in loading the operating system, most likely caused by a corrupted file or key in the registry. Your options are: A) Spend countless hours[days] troubleshooting and experimenting trying to repair, or B) back up your drive, wipe, and re-install. I would obviously go with option B, as it will save hours, if not days of your life. Here is the easiest route to solve. (Note: you sound like you know your way around computers, so I am assuming you've already tried booting into safe mode.)
Here are the steps to getting your files off and re-installing a fresh version of Windows 7 RC (it's free to test, remarkably stable, and will continue to work until June 2010)
1. Power off computer, unplug, remove battery. 2. Remove hard drive (here is a how-to: http://support.dell.com/support/edocs/systems/ins6400/en/sm/hddrive.htm#wp1128924) 3. On a separate computer (obviously) download and burn Windows 7 to a DVD (get it here: http://www.microsoft.com/windows/windows-7/download.aspx ) 4. Hook the hard drive you took from the e1505 to your secondary computer. It should be a SATA connection, which most newer computers i've seen contain those connections. So you should be able to plug it directly into a desktop PC. If not, dig out an external hard drive, pop out the screws, and hook up your SATA e1505 hard drive to the SATA connection in the ext hard drive, power the ext hard drive and plug the USB into your secondary computer. Either way you connect it, the computer will recognize it as a storage drive and you can simply copy the whole thing to your computer for sorting out later. 4. Once backed up, and your Win7 DVD is burned, pop that harddrive back into your e1505. 5. Turn on the laptop and put in the Win7 disk and start the install process. 6. Enjoy your fresh OS (and yes, it is compatible with windows xp programs -- just check the box for Compatibility under the right click-->properties) 7. transfer your back-up files to your e1505 8. crack open a beer and laugh at the hypothetical you that would still be beating his head in trying to figure out wtf file is missplaced or corrupted.
cheers!
Posted on Jul 14, 2009
Msi L1350d screen has tiny horizontal lines
If it works fine when you connect to your tv then you've probably got a loose cable on the screen. You'll have to strip it to check.
Mar 29, 2014 | MSI L1350D-1672US Netbook
Hi there, have a strange problem with a brand new DVD SAMSUNG SH-S223C. Installed a few days ago and running latest SB05 firmware (Even I reinstalled twice this firmware). Now on boot with my WIN XP PRO...
Start up BIOS and perhaps change default boot drive to your hard drive because i think your default boot up device is the dvd drive.... try to put that last on the list... F2 should get you to BIOS if not try F8 Just keep tapping right at beginning of startup before the logo screen shows. Once in BIOS go to boot menu and change default device :) Hope that works for you
May 04, 2017 | Samsung SHS223C 22x Internal DVD±RW...
My dell monitor screen, s2209w, is blinking and asks for password
Check in in the BIOS,(Press F2 key during the start up) if the same thing u see in than BIOS replace the monitor.
Aug 01, 2010 | Dell S2209W Monitor
On start-up, the first screen with the Microsoft flag logo has a matrix of blue square dots (about 1/8" square in size) superimposed over the entire screen. Then, when the desktop appears, about half of...
go into your bios and make sure that video memory shadowing is dissabled, Sounds like a faulty video card or damaged signal cable. I would lean more to the faulty card though, try installing a new one as I would say thats your issue if your getting artifacts on the screen before the OS has fully loaded.
OFC you could try new drivers both for your chipset of *********** board and the graphics card in the interim.
Jun 22, 2010 | Dell Dimension 4600 PC Desktop
Very horizontal faint white lines running down the screen
hi,
check if the line appears in BIOS...dont worry when i say BIOS...not sure how to check...turn the system off...restart the system and keep tapping the F2 key...you would get a Blue screen...check if the lines appear on this screen...if it appears...it could either be b'cause the display driver has gone wrong or the system might have a physical damage.....if the lines does not occur on this screen....it is a manufacturing defect...please contact the manufacturer and report the issue for solution.......
regards
Rocky
Jan 12, 2010 | Acer AL1717 17" LCD Monitor
Hello. I am on a laptop right now, but my gateway desktop is acting weird. I was playing Rome Total War, when my screen started having strange colors and the computer shut down. Everytime I boot the...
you may got infected...first run scan on the system and then reboot and see if you normally use it then try going to play again if that happen again then you need to get new video card
Nov 07, 2009 | Office Equipment & Supplies
BIOS Flash failed
if you still have the cd drivers from lennovo just put it on your cd rom and boot from it. bios flash will resotore 2 default
Jan 31, 2009 | Lenovo 3000 N200 Notebook
Laptop screen has been invaded by green and red/purple germlins
haveyou tried shutting it down and restarting it? it may just be the screen going bad
Jan 26, 2009 | JVC AV-48WP30 48" Rear Projection...
Dell Dimension E520 stops on BIOS screen
Remove all the externl devices and try to boot and load bios default setting
try resetting Ram module
Regards
Samson Ved
Dec 05, 2008 | Computers & Internet
Acer monitor AL1916W
start up windows in safe mode and see if you still get the problem. did you use the same vga cable???
Aug 26, 2008 | Gateway FPD2275W LCD Monitor
Dell Inspiron E1505 Notebook Logo
263 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
