Question about Frymaster Dean SR42G Deep Fryer
Thermostat temperature control thermostat out of order. where can Iget the part?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 107 Answers
Go online to parts town
Posted on Apr 19, 2012
    Scholar:
  • 81 Answers
By e-mailing me with M3 & S# at capt_rick1912@yahoo. I would be able to get that right out to you.
captrick
Posted on Jul 29, 2009
I have a 2006 Buick Lucerne V6 code po128 comes up. What does it mean?
P0128 BUICK P0128 BUICK - Engine Coolant Temperature Below Thermostat Regulating Temperature Repair Importance Level: 3/3 Repair Difficulty Level: 2/3 help.jpg Share facebook.png twitter.png linkedin.png google-plus.png sep.png print.png pdf.png share.jpg 3 comments.png ' Add Comment xicon.jpg http://www.autocodes.com/p0128_buick.html Forum Code Possible causes - Leaking or stuck open thermostat
- Low engine coolant level
- Insufficient warm up time
- Faulty engine coolant temperature sensor
- Engine coolant temperature sensor harness is open or shorted
- Engine coolant temperature sensor circuit poor electrical connection
help.jpg What does this mean? Tech notes If cooling system is not leaking and the fluid level is OK, replacing the thermostat usually takes care of the problem.
help.jpg What does this mean? When is the code detected? If the Powertrain Control Module (PCM) detects the calibrated amount of air flow and engine run time have been met, and the Engine Coolant Temperature (ECT) has not met the minimum thermostat regulating temperature, the code P0128 will set. Possible symptoms - Engine Light ON (or Service Engine Soon Warning Light) P0128 Buick Description An Engine Coolant Temperature (ECT) sensor monitors the temperature of the coolant. This input is used by the Powertrain Control Module (PCM) for engine control and as an enabling criteria for some diagnosis. The air flow coming into the engine is accumulated and used to determine if the vehicle has been driven within the conditions that would allow the engine coolant to heat up normally to the thermostat regulating temperature. If the coolant temperature does not increase normally or does not reach the regulating temperature of the thermostat, the diagnostic that use ECT as enabling criteria may not run when expected.
Read more: http://www.autocodes.com/p0128_buick.html#ixzz3vprh5jzz
Regarding which thermostat to use, I am guessing it depends on where you live.
Ask these people when you order the thermostat.
http://www.autopartswarehouse.com/shop_years/buick-lucerne-thermostat-2006.html
Dec 30, 2015 | 2006 Buick Lucerne
Fridge and freezer will run to proper temperature and will not restart
The thermostat is suspect. The thermostat is usually linked to the freezer compartment temperature control. Do you have to unplug he unit in order to restart the Fridge?
May 12, 2015 | Samsung Refrigerators
Problem with thermostat
Try this. Do as you already did above, but this time turn the thermostat slightly clockwise till it comes on again, and leave it at that setting for a while. Does it control now?
Jan 01, 2014 | DeLonghi Heating & Cooling
Replacing a thermostat on a dishwasher
you are most likely referring to item 16 in this diagram. You can order the part and replace it. This is the limiting thermostat which protects the unit from overheating.
However the heater thermostat is item 41 in this diagram. this controls the heater temperature.
Oct 30, 2011 | Maytag MDB7100AWB Dishwasher
Need to know what obd code PO446 AND PO128 for a 2002 Daewoo Nubira means
P0128 - Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
This means that the engine's PCM detected that the engine has not reached the required temperature level within a specified amount of time after starting the engine. The intent of the P0128 code is to indicate a faulty thermostat. Similar codes: P0125
In determining the engine did not reach a "normal" temperature, it takes into account the length of time the vehicle has been running, the intake air temperature (IAT) sensor reading, the engine coolant temperature (ECT) sensor reading, and the speed of the vehicle.
P0446 - Evaporative Emission Control System Vent Control Circuit Malfunction
Evap vent valve has only one purpose. It closes in order to seal the vent so the EVAP system can pressurize and ensure there are no leaks. Evap vent valve is usually supplied Batt. voltage with key on. The ECM's driver controls the ground, and when grounded, activates the valve (closing it). If the ECM detects a short to ground, and open,or a short to battery voltage on the control circuit, P0446 will set. Code also may refer to ECM detecting that EVAP system is unable to achieve or maintain vacuum during test.
Hope this helps.
Sep 29, 2011 | 2002 Daewoo Nubira
Ice on the back wall; temperature went from 58 degrees to 34 degrees; had to shut off regrigerator
hi,
Wine cabinets work off of cycle defrost, so in order to built frost your temperature sensors are not working properly. I would look for corrosion on or in connections to be the fault or problem. Sensors report information to control unit and thats there only job. Its the control unit that dictates function. Look for corrosion to be the problem, clean connection and seal with RTV when connection a corrected.
Good Luck
Sep 10, 2011 | Transtherm Ermitage Wine Cooler
Our coleman fireplace insert starts to warm and then shorts out
Not sure if you have an electric fireplace or a gas fireplace. But, from the way you worded the description of your problem, I'm going to assume that it's electric. I'm also assuming that all the other features of the fireplace work, but the heater doesn' t. If that is the case, below is what the Owners Manual recommends doing.
5. Flame effect operates, but heater does not blow warm air
The TEMPERATURE button is a thermostat control for the heater. Each preset temperature setting has a different thermostat setting as shown to the right:
The heater will NOT activate if the room temperature is above the thermostat setting. If the ambient room temperature is 78° F the user will need to select Setting 3 in order for the heater to be activated. It is normal in warmer climates and in rooms with higher ambient temperatures for the heater to not activate on the lower settings due to the thermostat control. 5a. Try increasing the temperature setting. See drawing:
temp-control-fig.jpg 6. If unit heater does not function, but Power and Heater switches are in the "ON" position and thermostat is set on "HI" 6a. Turn all switches to the "OFF" position and unplug the unit from the wall outlet for 5 minutes. After 5 minutes plug the unit back into the wall outlet, and operate as normal.
Mar 01, 2011 | Coleman Heating & Cooling
Carrier Comfort Zone II Smart Control in one zone frequently cycles unit (every 20-30 minutes) even when temperature in the room does not change significantly and the indicated thermostat temperature does...
sounds like your zone control tstat needs calabrated or maybe replaced,in owners manual there should be a section on calibration if not you may have to replace it
Sep 09, 2009 | Heating & Cooling
Programmable thermostat intermittent problems...
Some tstats control humidity as well. Temp will over shoot set point in order to reach humidity s
Jun 24, 2017 | Honeywell Programmable Thermostat Heater
Model X1 overheat
I had the same problem with my Francis Francis X3 overheating. I'm certain the thermostatic controls are similar and I suspected that as the problem. I did not want to pay the roughly $180-$200 to send it in for repair so I opened the X3, located the thermostat and discovered that it was a Prodigy Italiana TR/86 30C-120C adjustable thermostat with the temperature control knob removed and the "P2" wire-lug removed. I could not find one online, but later discovered that Chris' Coffee Service sells it for the Zaffiro here: http://www.chriscoffee.com/products/home/isomacparts/zaffirothermostat.
You should probably open your X1 and confirm the thermostat(s) before ordering. Ironically, I ordered the thermostat, put my old thermostat and machine back together so I could try to use it for a few more days while I waited for the new thermostat to arrive, and all of the jostling apparently freed up the thermostat in my machine so that it started working properly again. The new thermostat arrived and it is an exact match, so I have set it aside for when the orginal one permanently fails, and I know it will. Good Luck!
Mar 24, 2008 | FrancisFrancis! X1 - Stainless Steel...
Frymaster Dean SR42G Deep Fryer Logo
97 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
