Question about HP Pavilion dv9000z Notebook
HP DV9000 laptop - wireless router stopped working in computer. Won't connect - top it off I take it to computer repair shop and lost everything on hard drive - they can't tell me if its hardware related. I believe it is. Can you tell me if the wireless device on this model is on motherboard? How do I get another one and should I replace drives after losing my data?
    Sergeant:
  • 400 Answers
First I would replace the drivers, and check the device manager for any conflict with the internal router and the wireless device. then run the add hardware App and let windows Plug and Play find the device. with thye drivers re-installed it should come back, If it dont the have the motherboard replaced.
Posted on Jul 14, 2009
Why will my pavilion dv9000 only connect to public access networks, and not wirelessly to any home networks?
sounds like
a. wpa or wps needs to be reconfigured at router
b. firmware for router needs attention
c. router is truly unhappy about wireless settings
check router website for management access and adjustment procedures
not an hp issue
May 30, 2012 | HP Computers & Internet
My laptop stopped picking up wifi after a much needed modification. I have a 3 year old hp pavilion dv9000. the hinges broke so I decided to remove the monitor of the laptop and hook it up to a desktop...
That is because the WI-FI antenna wires were on the LCD panel behind the glass.
Currently your laptop base has no signal. The only solution is that you may pick up a signal with the base alone, if it is near the wireless router about 20' (3 meters).
Apr 19, 2011 | HP Computers & Internet
My hp pavilion dv9000 wireless connection stop
1>> Shut down the computer and then while restarting the computer keep tapping on F10
As you get to the BIOS screen press F9 and then Press F10 to save and exit out of BIOS.
2>>Uninstall the driver from the Device Manager (in control panel) and restart the computer, To install the driver again use the Recovery Manager
Jan 23, 2010 | HP Pavilion dv9000z Notebook
HP Pavilion dv9700 laptop, Wireless stops working at random.
It is because your wi fi network adapter not getting ip addresses from router.
For that connect your router to computer with ethernet cable then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
then go to advaced and enable DHCP .
Then save and restart router.
Then go to your laptop go to my etwork places proeprty then right click on your wi fi adapter then proeprty then tcp ip and set ip get automatic.
Then it works fine.
Let me know if you need more assistanse.
Thanks.
Sep 23, 2009 | HP Pavilion dv9000z Notebook
Unable to connect through wireless router
This is a mfg problem with the Atheros wifi cards used in hp laptops. Have a new wifi card installed at your local pc repair shop.
Sep 16, 2009 | HP Pavilion dv9000z Notebook
I own a HP DV9000 my wireless quit working
Check the Device Manager to see if the Wireless LAN device is working and enabled. If not reinstall the Wireless LAN driver.
If the Wireless LAN is OK and enabled then sometimes when you bootup the Wireless LAN card doesn't get an IP address from the wireless router. This usually has a red X on the wireless connection icon and sometime you get an error message "Limited or no connection".
To get the router to issue the wireless LAN card with a new IP address, righr click on the Wireless icon and click on Repair.
You can also power down the router wait 15secs and power up the router again then reboot the computer.
If it still doesn't work you could have a faulty wireless card, see it your friendly computer shop can test it for you.
Jun 30, 2009 | HP Pavilion dv9000z Notebook
HP DV9000 Wireless Card Not Working
Did the wireless icon from your machine light up? If no, you need to re-install your wi-fi driver. If you have the cds with you, re-install the driver then switched on your wi-fi. If you dnt have the cds, try checking on the HP site and look for the wi-fi driver.
Jun 02, 2009 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000 17" (Windows XP) lost my wireless internet
Hi there.
If your using Vista or XP, what i want you to do is right click "computer" select "manage" and then "device manager", then click on the + sign next to "network adapters" and right click on the wireless network and "un-install" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again
keep me informed please
Good luck and thanks for using FixYa!!
Apr 03, 2009 | HP Pavilion dv9000z Notebook
Need help getting wireless laptop connected to internet
1. Go to Start, Control Panel, syetm.hardware, device manager. Under network adapters make sure your wireless is there. Note: there is a recall for HP laptops including the DV9000 because they eractically lose their wireless settings. If this is the case call HP tech support.
2. Assuming your wireless card is listed (not the 1394) and there are no red or yellow check marks we can now go back to control panel, network connections.
3. If wireless connection is not listed then click the task Create a new connection. This brings up Welcome to new connection wizard. At this point you should see a line that says to connect to a wireless network in range . . . If this line is there click this then select your SSID (network name). If this line is not there and you're sure the network switch is on and turned blue then you'll need to call HP.
Mar 23, 2009 | HP Pavilion dv9000z Notebook
Wireless problem with laptop, HP DV9000
Follow the link below, read about this problem, and then call the special HP phone number. They are repairing these computers under a special enhanced warranty policy, even if the regular warranty is expired. Good luck!
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277#c01087277_identify
Dec 27, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000z Notebook Logo
198 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
