Question about Motorola Mobility RAZR V3m Cellular Phone
Press any button and phone does nothing
Worked fine ten minutes ago and now it acts like key pad is locked, pressing buttons doesnt do anything
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 129 Answers
Take the battery out without switching it off and put it back again it will work fine.even i used to have the same problem.after doing this back up everything and reset your phone you wont have the problem again.
Posted on Jul 14, 2009
I have a 2007 chevy tahoe with factory installed auto start. what buttons on remote or what sequence do i push to get truck running?There is a lock button an unlock button a rear glass open button and a...
To get your truck running with auto start first press the lock button and then hold down the semi cicle button for about 3-5 seconds this will start your truck
Jan 28, 2011 | 2007 Chevrolet Tahoe
On my remote the unlock is the only thing that works. my lock and remote start doesnt work. everything used to work before i got my transmission fixed and when i got it back nothing worked and i have been...
You could try reprogramming the remote: ignition on, press and release programming switch 3 times, you will hear one chirp( channel 1),press the lock button, press and release the switch 1 time ( two chirps, channel 2), press the unlock button, press and release switch 1 time ( three chirps) press green remote start button,press and release switch 1 time ( 4 chirps) press option button. Turn ignition off. test. If this doesn't work, try disconnecting the unit's power for about ten seconds, then reconnect and test.
Sep 30, 2010 | Car APS997A Two-Way Remote Start and...
A few days ago when I was on the the laptop anytime I pressed the letters mjkluio , numbers would appear instead. I tried to press the num lock button and it made no difference. Nothing would fix it so I...
The Function keys up top will not do anything when not in a program that has them set.
The num lock key on most laptops does not itself work: it must be pressed in conjunction with another key. This is normally the "FN" key at the lower left.
Please try pressing the "FN" key while you press the "num lock" key and see if this now works.
-halfs
Aug 12, 2010 | HP Computers & Internet
I have a 02 audi a4. When i press the button on my key for the central locking to open he door nothing happens and the battery is fine in it. When i put the key in the drivers door it opens and when i put...
NOTE: If key buttons operated repeatedly while vehicle out of range or batteries replaced and system becomes inoperative, proceed as follows:
Press one of the buttons. Manually lock and unlock driver's door within 30 seconds. System should operate normally after approximately 1 minute.
Jun 22, 2010 | Cars & Trucks
How to lock key pad
HI there press left side top BLUE color button & then left lower STAR ( * ) mark button. Thanks.
Apr 05, 2010 | Nokia N73 Cellular Phone
My buttons on my 2005 honda accord 4 cylinder car wont work
I assume this is the only remote you have? If not does the other have the same result? Have you changed the battery in the remote? If yes, is it installed with the right polarization?
Feb 28, 2009 | Vehicle Parts & Accessories
Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Jan 20, 2009 | Chamberlain 950CB Remote Control
Jennair dishwasher is locked. Can't get anything to work. No lights come on. 2 yr old granddaughter pressed buttons now I'm stuck.
one of the buttons may be a "lock" pad. there should be a picture of a lock next to pad. press and hold for 3 or 4 seconds and see if panel unlocks. otherwise disconnect power to D/W and reconnect after 2 minutes.
J
Jun 19, 2008 | Dishwashers
Proline locking issues
The Proline manual (comes on a CD with the player) says:
6.3.7 Key lock
This function sets a time delay from when key lock function is started or the player is switched on, after which the player will automatically stop responding to the control buttons. Pressing any button will then display the message ‘Locked’. Key lock is useful, for example if you put the player in your pocket and don’t want any buttons to be pressed accidentally. The time delay is to let you start playing the music and so on. You can choose a delay of ten or thirty seconds, one, three or ten minutes, or you can disable key lock completely. •
Press and hold the V+ button for a couple of seconds to temporarily unlock the keys.
Mar 17, 2008 | Audio Players & Recorders
Child lock
my AKAI tv is locked. All i see is a blus screen with a little red lock on the bottom left corner! the only button that works on the tv OR remote is the power button on the remote. PLEASE HELP i have tried pushing every button but nothing happens
Feb 15, 2008 | Akai CTS2550 25" TV
Motorola Mobility RAZR V3m Cellular Phone Logo
77 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
