Seals changed, with cartridge drained and all components cleaned and dry
SOURCE: front forks oil capacity kawasaki en 1500 1996
My book says "Capacity 368.5-373.5 cc dry. This is for a 1996 Vulcan 1500 A10. Should be the same.
SOURCE: I need to know the fork oil capacity for a Kawasaki GPZ750
the oil is SAE10W20 and you must put 325 ccm if you change the oil, and if you let it all drain over night 380 ccm (plus or minus 4ccm). After that, mesure the level in each cilinder of the fork. In the left one, you must have 120mm (plus or minus 2mm) of air left in the cilinder, and in the right one, 149 mm (plus or minus 2mm) .
Hope this helps. Try getting a repair manual. You will find all the answers there.
Best regards, Gabyshor.
SOURCE: Fork capacity on 1991 KX 250
SILKOLENE PRO RSF 5WT or use
SILKOLENE FORK OIL LIGHT
500-MLS OIL EACH LEG
SOURCE: I need the oil capacity for the front forks
That is something you are going to have to look up from the manuf. They don't hold much, maybe 1 pt. I just did mine, 3/4 pint in each. I bought 2 bottles at the motorcycle shop and still have some left. So look up your forks, ohlins, brembo, sachs, ceriani, showa, whatever, get the schematic for them, pull them apart in a big pan to catch the oil, and replace the seal, or whatever you are doing. You don't have to top them off if they don't show signs of a leak, if you feel the shock is gone out of them, well, that's different. Your bike is a 2005, it shouldn't have a problem in the front end. Hope this helps.
