Question about Cub Cadet Garden
Cub cadet 2130 engine starts and runs but stalls when either engage the power take off or I take off parking break? Any ideas?
  • 202 Answers
There is a switch under the seat that senses if you are on the mower or not. check it, make sure it's plugged up try replacing it. if it does not "see" someone on the seat it will shut down
Posted on Jul 14, 2009
Older cub cadet mower runs fine until blades engaged starts stalling out
Check that the battery is fully charged. If the water is below the top of the plates it needs topped up. If it is old it may not hold enough charge to drive the ignition and the electric clutch. The clutch can draw so much power the ignition falters and so your engine dies. The engine charger may not be able to cope with the draw off when the clutch first comes in.
Sep 28, 2014 | Cub Cadet Garden
Cub cadet trouble shooting
Check the "engage" switch. If it is shorted, it will drain the battery.
Jul 07, 2014 | Garden
My cubcadet 2130 will stall after running for an hour and not restart til it is cool,it will crank over, just not start til it sits for a while
hi there jrcampbell93
here is website for parts breakdown
http://www.partstree.com/parts/?lc=cub_cadet&mn=2130+Tractor+S%2FN+239%2C001+-+326%2C005
your problem sounds like a ignition armature going o/c when hot or a tank breather is not venting causing a vacuum loc in tank - check this 1st , then check out ignition armatures 2 nd
may need to place a ignition spark tester in line with each ht lead and plug, re-run machine and see which coil is going o/c get unit hot as before you will soon see which coil is doing it
once you know which one it is , replace it and reset air gap and you should be good to
cheers pauly46
May 27, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Will not move
The transmission is shot. A common problem. Mine died after 3 years and 200 hours of use. Estimate to fix was almost $2000. I scapped it and bought a better mower. There was a rtransmission design defect in the RZT series.
Jun 01, 2010 | Cub Cadet Street Sign- tractor lawn riding...
PTO clutch will not engage.
first start by turning ign on,then switch on the pto switch to on. you should hear a click in the clutch. if not use a twelve volt test light,hook aligator end to a good groundand the needle end,,,touch to the pto switchharness to see if you have power to the pto switch. if you don"t, you have to go checkfurther to your power source,(battery) if you do have power there check to see if you have power at the plugin at the end of your wire harness, just at the beginning of where your cluch connects up. you can test you clutch by conneting a test wire from positive on your battery to one of the terminals on your clutch and the other terminal to ground . It willengage if it is good .using either wire is ok as all it will be doing is completing a circuit. hope this helps.
Sep 24, 2009 | Oregon Scientific Electric PTO Clutch for...
Cub Cadet LT1018. When I go into reverse the
the safety switch on the pto lever is not activated (lever is not back all the way)
this unit should not cut in reverse
Aug 17, 2009 | Cub Cadet Street Sign- tractor lawn riding...
REMOVE PARKING BRAKE ENGINE STALLS
i have a cub cadet 2130 2000 seris but it quits when i rekwase the brake pedal
May 03, 2009 | Oregon Scientific Oregon Gator Mulcher...
Engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Apr 11, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
598 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
