Question about Amana Refrigerators
The freezer motor quit running. when i emptied
The freezer motor quit running. when i emptied it, it started again. it had been off at least 30 hours. the temp was 48 when I started emptying it and an hour later it was 29 degrees
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 310 Answers
I suspect the motor was stalled due to frost build up on the evaporator coil. This condition is usually caused by defective defrost timer, heater, or defrost thermostat.
Posted on Jul 14, 2009
Why does motor quit running after 5 to 10 minutes
Check that the vent in the fuel cap is not plugged. Can create a vacuum preventing fuel getting to carburetor,
If not sure leave cap a little loose and see if stall repeats>
Mar 11, 2016 | Ariens Garden
My freezer just quit working. The power light is on but the motor isn't running. What could be the problem
Check the starting capacitor- if ng replace it. Also check compressor motor windings. If they are ok then it is possible that the motor has seized. To confirm that check for the current draw of the motor while not running. Usually on the unit there will be a rating for normal current draw and a draw when the rotor is frozen. Check your reading against the frozen motor reading. And if the motor is frozen and not running it will be hot, very hot and the clixon will kill power to motor till it cools and it will shut down again as it overheats due to non operation.
Jul 22, 2015 | Freezers
How do I Prevent ice dispenser from freezing up? Ice is in the ice bucket but will not disperse.
The ice stays in the cubemaker tray for a set time and then empties into the bucket. If the freezer was too warm the ice wasn't frozen enough when the cube maker emptied it and it all stuck together. Now the fridge is cold again empty the bucket, make sure there is no ice stuck in the dispenser and try again. If it is a Samsung fridge do the above and turn it off for 30 seconds and back on again. Sometimes the controller and display freezes and reads the wrong temperature.
Nov 18, 2014 | Refrigerators
Why are the sides of my upright freezer hot and the compressor very hot
Good Afternoon Friend,
I understand the sides of your Frigidaire freezer are hot and the compressor is very hot. I also see that the drain plug was frozen and the coils had lots of frost, which you defrosted and your freezer began running again. It looks like your freezer quit again and started up, leaving everything hot. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose and determine what exactly is causing your appliance to be hot. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire Freezers
Amana fridgerator model bx21vc
First of all you did the right thing by putting all information in print, ,any don't , Any ways sounds as if some thing was loose, And sounds like it needs more Freeon
Aug 27, 2013 | Refrigerators
1998 s10 wiper motor
If it has intermittent wipers,the pulse board on the motor
is commonly bad,just 3 screws to change it ,part is about
30 bucks
Feb 11, 2013 | Chevrolet 1500 Cars & Trucks
I have a GE side by side freezer/refrigerator. The
When you say "The items in the freezer are cold with some ice on them. I have tried emptying the ice tray, but that does not help." Is there literally ice from the ice bucket dripping on the food and refreezing, or is there a layer of frost on the food? the noise you are hearing is most likely due to the evaporator fan motor running at alternating low and high speeds. This is a variable speed motor, but there could be quite a few reasons why the motor is not rotating at regulated speeds. the fan motor itself, a faulty thermistor, you could also have an issue with your main control board, or least of all a wiring issue.
You would be wise to have it inspected by a reliable refrigerator repair service, to at least determine what the problem is for certain.
Mar 31, 2010 | GE 13.7 cu. ft. General Electric Upright...
My Whirlpool refrigerator quits working and restarts
Good day,
If it only occurs on a monthly cycle, even a service tech would not find it unless it happened while he was there.
First choice would be to replace both the thermostat and the defrost control. These are the items that turn the machine off and on and either one could hang or stick once in a while.
NOW, that is based on the fact that the machine goes totally dead during that period. If you hear something, anything running then the above does not apply.
The possibilities then, are, the fan motor in the freezer won't run (you can hear it running when you open the freezer door), the cooling fan motor behind the bottom rear cover that cools the compressor and condenser same situation, will not run.
Lastly, the start relay mounted on the side of the compressor is weak. It will not kick in the compressor, but in that situation, the fans will run.
Hope that helps. I've serviced a lot of refrigerators with that complaint, and it's always been the first 2 items.
Feb 17, 2010 | Whirlpool ET1FTKXK Top Freezer...
Freezer not freezing
Because it stopped cooling so fast, over night, I would make sure the compressor is running and the condenser fan motor that sits next to it.
Jan 10, 2009 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
61 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
