Question about LG L1915S 19" LCD Monitor
Plugged it in, double checked all connections. won't turn on.
When my Family left for a two week vacation, they turned off the computer and screen. when we came back, I powered it all up, But the screen wouldn't respond. tried new power cords, All I would get is that when you re-plugged it in to an outlet, the light for power on the front would turn on for 2 or so seconds then shut off.
Guessing that it is the fuse. Where can I buy a new fuse? or should I just by a new screen?
  • 975 Answers
If your handy with tools , you need to open the MONITOR and check the power supply section for BLOWN FUSE and also for a visual look at the board for possible burnt or cold solder , hope this helps , AJ
Posted on Jul 14, 2009
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
1995 Lexus LS400. Car was left in garage for two weeks while we were on vacation. Upon return it won't start. Engine does turn over. Replaced fuel pump in attempt to troubleshoot. Mechanic ha
I assume the pump was replaced because it was getting power but no fuel pressure ?
Are you still not getting fuel pressure ?
Spark to the plugs ?
Normal compression when cranking the engine ?
Security light not staying on ?
Feb 09, 2013 | 1995 Lexus LS 400
2009 Pontiac VIBE won't start-left for 1 week while on vacation
Let the battery charge a little bit with the jumper cables left on the battery. Give it 20 minutes or so and them try to start.
Aug 13, 2012 | 2009 Pontiac Vibe 2.4
The computer won't turn on
You could be having any of several problems.
First double check to make sure no cords came loose - you may even want to unplug and replug the power cable both out of the computer and the wall.
If you do not have a loose cord, listen closely when you attempt to turn the computer on - is it making any noise? Do any lights come on? If not, you likely have a bad power supply.
If the computer does come to life, just no reaction on the screen, make sure your monitor is plugged in and turned on, and try unplugging and replugging the cord connecting the computer and the monitor.
If this still does not get it, you may be dealing with either a graphics card or monitor problem. If you have an alternate plug for the monitor to go - try that, or if you have a different monitor to use, try that.
This should either greatly narrow down or fix the problem for you.
Aug 24, 2011 | Computers & Internet
Turned my phone off for a weeks vacation, and now it will not turn on
The battery threshold voltage has gone BELOW the mark required to display anything on the screen. So connect the charger and let the phone charge over night as the display will come on. You can also check the voltage on the battery to confirm this and so put it on for charge.
Jun 14, 2011 | Cell Phones
COMPUTER CRASHED I NEED TO RELOAD CD BUT I DONT HAVE ACCESS CODE
There are now several versions of the basic Futura software and AutoPunch available on the market. The most current is version 1.0.0.2. To determine what version of either software you have, you will find this information around the inside rim of the CD at approximately 4 o'clock. Before loading any of the Options into your computer, check the version and then follow the steps below. The following steps will update your software so that you will now have the latest 1.0.0.2 version of the basic program and all options.
To load base software 1.0.0.0 with AutoPunch 1.0.0.0 or base software 1.0.0.1 with Autopunch 1.0.0.1
  • You must use bobbin part number 085128. This bobbin is specifically designed for the Futura CE-100 and CE-200.
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Turn on Futura machine and double left click on Futura icon to open program
  • Close program and turn off the machine
  • Install Autopunch and leave the CD in the tray
  • Download appropriate update for Windows Version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop download icon to install update
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program
To load base software 1.0.0.0 with AutoPunch 1.0.0.1 or base software 1.0.0.1 with Autopunch 1.0.0.0
To load base software 1.0.0.0 or 1.0.0.1 with Autopunch 1.0.0.2
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer- machine turned OFF)
  • Close software and turn off machine
  • Install Autopunch using Installation Wizard - leave CD in tray
  • Turn on Futura machine and double left click to open program
  • Type in Access Code from Autopunch jewel case and then left click on check mark to open program
To load base software 1.0.0.2 with Autopunch 1.0.0.0 or 1.0.0.1
  • Close program and turn off machine
  • Place Autopunch CD in tray but CANCEL Installation Wizard
  • Turn on Futura Machine and double left click to open the program
To load base software 1.0.0.1 with Autopunch 1.0.0.1 with Hyperfont 1.0.0.2 or Photo Stitch 1.0.0.2
  • Load Base software (have the machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Close program and then turn off the machine
  • Install the Autopunch program and leave the CD in the tray
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program*
  • Download appropriate update for Windows version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop icon to install update
  • Install HyperFont program - leave CD in tray
  • Type in Access Code from HyperFont jewel case and then left click on check mark to open program*
  • Install PhotoStitch program - leave CD in tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark to open program*
* Must open the program after installing each Option with CD in tray and type in Access Code before installing next Option.
To load base software 1.0.0.2 and adding all Options - Hyperfont 1.0.0.2, PhotoStitch 1.0.0.2, Autopunch 1.0.0.2 and Cross Stitch 1.0.0.1
  • Install Base software (have machine set-up for embroidery with USB connected to both the machine and computer- machine turned OFF)
  • Close program and then turn off machine
  • Install Autopunch program and leave the CD in the tray
  • Type in Access Code from AutoPunch jewel case and then left click on check mark*
  • Install Hyperfont program and leave the CD in the tray
  • Type in Access Code from HyperFont jewel case and then click on check mark*
  • Close Program and turn off machine
  • Install Photo Stitch program and leave the CD in the tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark*
  • Close program and turn off machine.
  • Install Auto Cross Stitch program and leave CD in tray
  • Download appropriate update for Windows version from the Futura-Support.com updates (Fut_sp2_Options.exe) and save to desktop
  • Type in Access Code from Auto Cross Stitch jewel case and then left click on check mark*
Dec 11, 2010 | Singer CE-200 Quantum Futura Computerized...
Tablet quit working. Left for vacation (1 week) came home plugged it in and it no longer worked. WACOM TABLET CTE-440
Had the same problem and just solved it. Very easy. Turn off your computer. Pull the power cable. Wait about 5 minutes. Plug it back in and power it back up. No more USB not working prompt in your device manager and your tablet should be back and running.
Nov 01, 2009 | Wacom Intuos3 Graphic Tablet
White LCD screen
The LCD connection may be loose or the LCD itself broken. You may need to have a service centre replace the LCD unit.
Apr 13, 2009 | Canon PowerShot SX10 IS Digital Camera
No pic on screen
Double check all of your connections. It appears the video cable is not plugged in completely. Try another monitor if possible to see if the computer is actually outputting video.
Jan 03, 2009 | Dell Computers & Internet
No sound from main left and right speakers
no, the yamaha system would shut down if the amplifiers had a problem. I would check the bose system, try directly hooking the speakers to the mains in stead of thru the bose system if you can. the easy way to check the amps is to plug in a set of head phone in they are directly tied to the mains.
Mar 23, 2008 | Yamaha RX-V2092
LG L1915S 19" LCD Monitor Logo
123 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
