Question about Insignia LCDTV26 26 in. Television
Clear picture, no sound on my insignia product NS-LTDVD26-09.
SOURCE: Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Posted on Aug 26, 2008
  • 11 Answers
SOURCE: insignia ns-lcd32
You can download the manuals from the Insignia website at:
http://www.insignia-products.com/c-14-lcd-televisions.aspx
Jerry
Posted on Dec 08, 2008
  • 814 Answers
SOURCE: Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
Posted on May 23, 2009
  • 2335 Answers
SOURCE: No picture, no sound, does light the insignia sign. Why?
In about 90% of the time the power supply is defective if the TV fails to power ON.
I repair these power supplies, if you need further assistance write to jah2mil@homtail.com
Posted on Jun 29, 2009
ginko
  • 19396 Answers
SOURCE: Insignia NS-32LCD has sound but no picture -
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
Theinverter is the high voltage board that provides variable power to thebacklight lamp. This is the most common. When inverter is faulty youcan get no picture, or a very dim picture that can only be seen bypointing a torch light with a 45 degree angle on the LCD surface fromvery near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
Thisis quite uncommon, but happens. If the TV had been hit or moved the LCDcable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
Thisis the board that controls the video signal, it is difficult to test,as there is need to read determined values on IC pins. To test thisboard you need to purchase a service manual and follow thetroubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where youconnect the video and audio cables, if a signal board is defective,then you may get no picture on particular inputs located on faultyboard.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on Jul 18, 2009
How can I get a manual for NS-40D510NA15
Insignia has the manuals for most of their products on the product page. Click on the Support/Downloads tab. For the NS-40D510NA15, see http://www.insigniaproducts.com/products/televisions/NS-40D510NA15.html . The direct link to the User's Guide (as a PDF) is http://www.insigniaproducts.com/cms/documents/manuals/NS-40D510NA15_14-1088_WEB_V3_ENG_Final_lr.pdf . There is additional documentation available and there is an HTML version of the user's guide as well.
I hope this helps.
Feb 01, 2016 | Insignia Solutions Original INSIGNIA TV...
Insignia NS-LCD42HD 2+ years old - color problem (getting lots of green, both composite and hdmi) - had been VERY happy with picture quality. Question should I repair or replace? (have done computer...
The TV is very low Grade considered a cheap china knockoff and the panel has gone bad as expected you need t replace the TV and next time steer clear of the non brand products (aka walmart)
Feb 12, 2018 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
I OWN A INSIGNIA CAMCORDER PRODUCT NS-DCC5SR09
There is an install disc that came with the unit. On this disc is the FFDshow application. This application is necessary to properly playback the video files from the NS-DCC5SR09.
Once FFDshow is installed you should have no problems with playback or editing of the video clips.
Hope this helps!
Dec 07, 2009 | Insignia NS-DCC5SR09 Flash Media Camcorder
Insignia ns-32lcd. picture scrolling and no sound
Hi, I was waiting your response in chat session but didn't get any.
Jun 11, 2009 | Televison & Video
Frozen
It sounds like you are having a firmware issue.
Easiest solution is to connect the NS-DV2G to your computer and place the firmware file on it. When you disconnect, the firmware will install. You'll loose all your settings and probably all your songs, but it should correct your player.
This is for the NS-DV2G:
http://www.insignia-products.com/t-New%20Video%20Player%20Firmware.aspx
This is for the NS-DV2GC:
May 21, 2008 | Insignia NS-DV2G MP3 Player
Insignia LCDTV26 26 in. Television Logo
132 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
