Question about Microwave Ovens
How do you replace the lamp in a Kitchenaid Superba microwave convection oven combo? What type of lamp?
  • 180 Answers
Open the top cover then you can see the bulb on the right side of the oven, just remove the lamp and replace it by a similar one. you can try to get the lamp from any electrical shop with the same size and same rating.
Posted on Jul 14, 2009
ERROR CODE F6-EO
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 02, 2016 | KitchenAid Kehu309Sss 30" Microwave...
My Kitchenaid combo convection/mw works on convect but has a loud humming and no heat on microwave.
A loud humming noise in microwave mode will usually be a shorted high voltage diode or bad magnetron.
Sep 16, 2013 | KitchenAid Architect II KHHC2090S ...
I need detailed instructions on how to change light bulb on Kitchenaid microwave KBMC147HSS0
Please check the details of how a microwave works which will help you identify before the panel is removed and the lamp replaced.
The top cover of the unit can be removed after the screws can be removed with the power cord removed. The lamp can be seen fitted on the front side with the light to shine into the chamber, you can remove the buld from holder and replace with the same type .
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
Oct 27, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
There is a superba 27 Microwave/Convectionand U Oven Combo in my house. The Micro Convection part is Part 3179901 and the Model in the oven portion is listed a s KEMS376TWH1. I only have a cheat sheet ...
Mommakat45
You can find the manual at
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KEMS376TWH1&siteCd=KAD&userType=Consumer
Dec 12, 2010 | KitchenAid Microwave Ovens
Kitchenaid superba combo. Microwave gives
HI, this is an indication of a failed door switch. When the switch fails, the control cannot recognize the closed door signal. Simply replacing the door latch mechanism will solve this issue.
Replace the door latch assembly, asap.
Dec 22, 2009 | KitchenAid Microwave Ovens
My Kitchenaid Superba kaw38avm726 microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhjjd
Nov 20, 2009 | KitchenAid KEMC377K Convection / Microwave...
Burned out bulb on Kitchen Aid Microwave Model KBMC140
You will need to remove the oven from the wall and remove the outer cover.
If for some reason you don't have yours, you can download your owner's manual and installation instructions free from this page.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
You should be able to get one from a home center or local appliance parts store.
If you order it online (from the link above) it is part # 4375348.
Aug 04, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Mar 26, 2009 | KitchenAid Microwave Ovens
Microwave Ovens Logo
151 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
