Question about Radio Shack TRC-503 CB Radio
I'm Thinking About a CB Radio
I plugged in my cell phone, to the cigarette lighter of my 1993 Dodge van. It didn't seem to charge. Now I'm thinking about buying a CB Radio. I don't know anything about them. I thought maybe I could get one for my son too, but he doesn't have a vehicle. Do C B Radios work from electricity, too, or just from a vehicle? I don't know what brand of C B Radio to get. I'll need one with tech support. Thanks, Donna
  • 1,139 Answers
Hello Donna,
I do a line by line reply to your questions:
Q) Do C B Radios work from electricity, too, or just from a vehicle?
A) You will need to buy a 12volt power supply to power the CB if you are using it in your home. Also you will have to have a house mounted antenna.
Statement) I don't know what brand of C B Radio to get. I'll need one with tech support.
Reply) For simplicity, I would suggest getting a Realistic brand CB from Radio Shack, they will also have the antenna and installation hardware (for home and vehicle) along with a SWR meter (you will need this, trust me). As for tech support well any brand you go with will be a problem in the area of tech support, most of the time you will have to find a CB shop or some that is CB savvy to act as your tech support.
I hope this helps
Posted on Nov 19, 2007
    New Friend:
  • 160 Answers
There's cb radios that work in the house with out a power supply like and for a base antenna
Posted on Jul 07, 2008
Where is the cigarette lighter fuse located in a 97 buick century?
GOOGLE is your friend! Open up Google then search for this exact phrase (without the quotes)
"97 buick century cigarette lighter fuse location"
Aug 05, 2014 | TRUCKSPEC TSP-311 12-Volt 2 Outlet Fused...
Which fuse controls the cigarette lighter and radio, mine are not working
In the integrated power module, find 20A fuse 5. Replacing it should get both the cigar lighter and radio operating again
Oct 12, 2012 | 2005 Chrysler Town & Country
Cigarette lighter on 2007 dodge caravan burns out cell phone chargers
hey ronkardos,
did you find a solution? My caravan started developing similar issue.
Jan 08, 2012 | 2007 Dodge Caravan SXT Minivan New Cars
How do I replace the cigarette lighter and where is the fuse located?
I had got its manual from online store Here's the site link I am sure they will help you
Mar 01, 2018 | 1993 Toyota Previa
Had cell phone and computer plugged into dual cigarette lighter unit and cigarette lighter overheated and quit working - we checked the fuse - it seems fine.Just want the cigarette lighter socket to work...
More than likely overheated the wiring going to the lighter as well and burned it off. If you pull the lighter socket out you should see if it did. Simply solder it back on and be careful not to overload it again.
Jan 29, 2011 | 2000 Oldsmobile Silhouette
I just got my first cb and am trying to install it. I have connected the red wire in the fuse box( to the radio) and grounded the black wire. turned the car on and I cannot get any power to the CB, but the...
Take a deep breath and start over! The best way to power this little radio is probably through the cigarette lighter or 12vdc accessory jack. It is simple and straight forward and no fuse box or negative ground wires to worry about. Go the Radio Shack, purchase an adaptor (cig lighter type) and hook it up to your radio wiring being careful to watch polarity. You may have to have your ignition on to run the radio, but that is much safer that maybe blowing up the unit.
Unless you are running a larger more powerful unit or an amp, there is no added benefit to hooking the radio into the fuse box.
Dec 16, 2010 | Cobra 19 DX IV CB Radio
Cig lighter, radio, etc wont work after plugging in cell phone to charge
it sounds like you blow up a fuse,check your fuse box,
check your manuel for locations
gl G
May 04, 2009 | 1998 Toyota Camry
Radio CD not working & lights don't flash remote keylock
Sometime the computer in car will shut down a circuit when it sees a problem even if it only occure once. You can try to disconnect the battery for at least 2 min so all sys power off (some have capacitors that mantaine a charge for short time). If a battery disconnect does not clear problem you have go to dealer and have them to clear codes and reset you modules and your preferences
Feb 15, 2009 | 2004 Dodge Caravan
Car Charger Won't Charge, And Phone Doesn't Work In Most Areas, In The Woods, Northern CA
most car chargers have a fuse in them usually 2amp.
it is possible this fuse has blown.
if you can unscrew the end of your charger you will find the fuse
BE CAREFULL the tip is spring loaded and will shot apart so make sure yoou keep it under control
Nov 16, 2007 | Pantech C300 Cellular Phone
Radio Shack TRC-503 CB Radio Logo
183 people viewed this question
Top Radio Shack Radio Communications Experts
Greg Cann
Greg Cann
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
