Question about D-Link Xtreme N DIR-655 Wireless Router
Installed dlink, says hardware is not found. power light is also off.
    Scholar:
  • 103 Answers
If all lights on dlink are off, start by check the power supply. If its connected from the wall to the dlink and still the light are off.
  1. The power supply is bad
  2. The AC from the wall has no current. Check for these.
When you succesfully turn on the dlink, connect the cables as directed. by the manual.
Posted on Jul 14, 2009
Windows won't even recognize my dlink dwa 125 wireless adapter when I plug it in. I do not understand why?
same issue here on a winxp machine with sp2
having hard time to update to sp3 as the dlink DWA 125 requierments ask ...
so i tested the DWA 125 usb on a windows 7 machine and Iam having the same issues, windows not finding the adapter ....
Dlink guys post a link for solution ...?? not recommending otherwise
May 14, 2011 | D-Link DWA-125 Wireless 150 USB Adapter...
After running add hardware wiz on DWL-G630 wireless adapter, the message came out with hardware can not install CODE 10, I am not sure if this is the hardware problem or the driver issue, only one light...
Go to device manager and uninstall device. Then remove card.
Download driver from here http://www.dlink.com/products/?tab=3&pid=DWL-G630&rev=DWL-G630
after installing driver plug the card back in.
Feb 23, 2011 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Reformatted Windows XP does not recognize D-Link wireless adapter
I ran recently across the same problem and solved it by changing the PCI slot where the card was installed... it makes little sense to humans, but apparently make a world of difference to the PC hardware ;)
Assuming you had installed unsuccessfully both Card and Driver you have them (like I did) both on your PC. In such ase, the solution for me was as follows: 1) Turn Off PC 2) Remove the card from the current PCI slot 3) Turn PC back On and remove driver 4) Turn Off PC, remove power cord and wait a minute or two 5) Do not install card yet 6) Turn PC back On and install the driver 7) Turn Off PC remove power cord 8) Install the Wireless card in a different PCI slot THIS IS VERY IMPORTANT!!! Can't be the same slot as where it was installed before!!! Note: If you have none available swap PCI slots or remove a PCI card to free up a different slot for the wireless card... remove a card you need the least and in its place install the Dlink Card. You may want to hold off on installing in a second step the card you have just removed, to be on the "safest" side.
9) Once the card is installed, Power up your PC 10) Once windows will be back up and running the hardware wizard should kick in and tell you that new hardware was found. 11) Follow the on-screen instructions 12) click "Continue Anyway" when XP will warn you that the driver hasn't been signed 13) Installation should be completed after you click Finish at the end of the New Hardware Wizard process 14) Simply go to your wireless networks and make sure all works in order
(I know that this process may sound a bit "anal" in some steps, but I was no longer willing to deal with any possibility of problems of any kind as I was ready to rip that wireless card to shreds!)
I hope this will help those who struggled with reviving an old PC to give to a friend!
Aug 02, 2010 | D-Link AirPlus G DWL-G510 802.11g/b...
Reinstalling the wireless adapter
vista have this problem...
first, switch off computer and remove physically card from the computer, then de-install all possible traces of it, run ccleaner and clean the computer as well as registry.
go to d-link site and download newest drivers for your adapter, and os (vista). unfold software to c:/dlink
switch off computer again, re-install card and re-power the computer.
when automatic software install start, select manual install, point to newly created folder c:/dlink and select appriopriate driver from there, install.
this procedure usually solves the problem, vista try to instal generic windows drivers not specific hardware drivers, to prevent occurence of that, disable automatic updates in vista, and once a month or so, do only and only security updates from windows, never, ever update your hardware drivers from windows as these are just generic drivers generating more problems than solving. hope this help.
Jul 26, 2010 | D-Link WDA-2320 (ASKU54036) Wireless...
DLINK - DCS-900w Firmware Update needs install software?
Go to dlink.com. Select IP cameras. At the top is a search using Product Quick Find. Find the 900w and click on it.Select Support Resources. All the firmware and software is there.
Apr 10, 2009 | D-Link DCS-900W Network Camera
Install driver of dlink dfm 562is on vista
can you help me to install d-link dfm 562is on vista ultimate 64bit
Jul 01, 2008 | D-Link DFM 562IS (DFM-562IS) Modem
Glb-502t driver of Dlink compatible with vista
The Dlink device came with drivers which works in Windows XP.
I installed vista driver from dlink website, but its of no use, it still doesn't work in Vista.
Well Dlink WORKS BEST in Ubuntu (Linux), without any driver installation. Either USB or LAN.
Use Ubuntu Linux.
Dec 20, 2007 | Microsoft Windows Vista Ultimate Edition
No Card
http://support.dlink.com/faq/view.asp?prod_id=923&question=dwl%2D520
After installing the wireless card into a PCI slot, when you booted the pc, did you get a New Hardware Found message? If not, try another PCI slot.
Nov 08, 2007 | D-Link DI-514 / DWL-520 Kit...
No amber light
I think ya gonna find ya modem has gone "toes up"... It may well be in the power supply section (PSU)... I guess ya could try a "Shotgun" replacement of all the PSU components.. If this don't "Fix" it.. then I am sorry but ya up for a replacement.. which may be the best option in any event?
Aug 30, 2007 | D-Link DI-704P Router
D-Link Xtreme N  DIR-655 Wireless Router Logo
71 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
