Question about Frigidaire GLEQ2152ES Electric Dryer
It wont start and beeps 3 times reading "DR" - Frigidaire GLEQ2152ES Electric Dryer
  • 230 Answers
Your door-switch is bad, needs to be replaced. done many of them. before changing the switch, have the technician make sure all the wires on the control board are plugged in.
Posted on Jul 15, 2009
LTF2140ES0 washer just beeps three times, wont start
Frigidaire engineers are so smart they programmed it to beep 3 times for door lock problem, draining problem and other problems in the internal electronics and didn't bother to give the users specific info to read off the machine.
Oct 30, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Whirlpool gold accubake system keeps displaying the message "Dr Lo". Every 60 seconds it will beep like 10 times and display the message then display "start?" Normal function dont work either I can push...
The Dr lo is for the warming draw. I assume you have a warming drawer. Page 17 of your manual describes how this function works. It also states on page 11 "The Off/Cancel pad stops any function except the WARMING DRAWER, Timer and Control Lock. If you have actually unplugged the stove and plugged it back in it should come on with a PF for power failure. You push the Off/Cancel pad to clear the PF and then you have to push start to do anything else. such as bake, etc. Have you pushed Drawer OFF? That should clear the dr lo message. If this message comes on as soon as you plug the stove in or just after you push the Off/Cancell pad or after you push start or bake try to push Drawer Off. If this does not work then it apppears you have a malfunctioning control panel.
Dec 18, 2013 | Kitchen Ranges
6 beeps what dose it means
Dell beep codes:
If your computer beeps during start-up:
Run Dell Diagnostics to identify a more serious cause.
Beep Codes Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. One possible beep code (code 1-3-1) consists of one beep, a burst of three beeps, and then one beep. This beep code tells you that the computer encountered a memory problem.
Contact Dell for technical assistance.
Code Cause 1-1-2 Microprocessor register failure 1-1-3 NVRAM read/write failure 1-1-4 ROM BIOS checksum failure 1-2-1 Programmable interval timer failure 1-2-2 DMA initialization failure 1-2-3 DMA page register read/write failure 1-3 Video Memory test failure 1-3-1 through 2-4-4 Memory not being properly identified or used 3-1-1 Slave DMA register failure 3-1-2 Master DMA register failure 3-1-3 Master interrupt mask register failure 3-1-4 Slave interrupt mask register failure 3-2-2 Interrupt vector loading failure 3-2-4 Keyboard Controller test failure 3-3-1 NVRAM power loss 3-3-2 Invalid NVRAM configuration 3-3-4 Video Memory test failure 3-4-1 Screen initialization failure 3-4-2 Screen retrace failure 3-4-3 Search for video ROM failure 4-2-1 No timer tick 4-2-2 Shutdown failure 4-2-3 Gate A20 failure 4-2-4 Unexpected interrupt in protected mode 4-3-1 Memory failure above address 0FFFFh 4-3-3 Timer-chip counter 2 failure 4-3-4 Time-of-day clock stopped 4-4-1 Serial or parallel port test failure 4-4-2 Failure to decompress code to shadowed memory 4-4-3 Math-coprocessor test failure 4-4-4 Cache test failure
Aug 12, 2013 | Dell Gx620 Gx 620 Sff P4 Ht 2.8ghz 1gb...
Cmos beep codes
do you know which bios your computer is running ?
AMI BIOS beep codes 1 beep - DRAM refresh failure
2 beeps - Parity Circuit Failure
3 beeps - Base 64K RAM failure
4 beeps - System Timer Failure
5 beeps - Processor Failure
6 beeps - Keyboard Controller / Gate A20 Failure
7 beeps - Virtual Mode Exception Error
8 beeps - Display Memory Read/Write Failure
9 beeps - ROM BIOS Checksum Failure
10 beeps - CMOS Shutdown Register Read/Write Error
Phoenix BIOS BEEP codes. 1-1-3 CMOS write/read failure.
1-1-4 BIOS ROM checksum error.
1-2-1 System timer failure. (Programmable Interval Timer PIT)
1-2-2 DMA (direct Memory Access) failure.
1-2-3 DMA page register failure.
1-3-1 RAM refresh failure.
1-3-3 64K RAM chip or data line failure.
1-3-4 64K RAM odd/even logic failure.
1-4-1 64K RAM address line failure.
1-4-2 64K RAM parity error.
2-?-? Any beep series starting with 2 beeps indicates a 64K RAM chip or data line error.
3-1-1 Master DMA register test.
3-1-2 Mslave DMA register failure.
3-1-3 Master interrupt mask register failure.
3-1-4 Slave interrupt mask register failure.
3-2-4 Keyboard controller failure.
3-3-4 Screen (video) memory failure.
3-4-1 Screen initialization failure.
3-4-2 Screen retrace failure.
4-2-1 Timer tick interrupt test failure.
4-2-2 Shutdown test failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure above address 0FFFFh (64K +)
4-3-3 Interval timer channel 2 test failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port test failure.
4-4-2 Parallel port test failure.
4-4-3 Math Co-processor failure.
BEEP codes may vary dependent upon the revision of BIOS. This list is for reference only
hope this helps
Oct 10, 2012 | Intel Mother Board S5520HCR (988889365963)...
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Everytime i start up the computer it beeps 3-4 times, and the monitor says vga input not connected...whats could be the problem?
here are the beep codes for your exact dell model. this should give you a starting point on finding out what the problem is.
Reseating the memory modules may fix the beep code errors in the following table. If the problem persists, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
Code
Cause
1-3-1 through 2-4-4
4-3-1
If you hear one of the following beep codes, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
Code
Cause
1-1-2
1-1-3
NVRAM
1-1-4
1-2-1
1-2-2
1-2-3
3-1-1
3-1-2
3-1-3
3-1-4
3-2-2
3-2-4
Keyboard Controller Test failure
3-3-1
NVRAM power loss
3-3-2
NVRAM configuration
3-3-4
Video Memory Test failure
3-4-1
3-4-2
3-4-3
4-2-1
No time tick
4-2-2
Shutdown failure
4-2-3
Gate A20 failure
4-2-4
4-3-3
4-3-4
4-4-1
4-4-4
Cache test failure
Jan 01, 2011 | Dell Dimension 4600 PC Desktop
Our bigfoot beeps 3 times and wont do anything else
We just got one yesterday and its doing the same thing. We charged the battery all day yesterday...it Finally turned green and still does the beep 3 times and nothing else. So i put it back on the charger and now the light has been red for the past 4 hrs...not sure why it would still need to charge for so long when we haven't even gotten to play w/ him??? Play let me know if u find a solution. Huge bummer for my son.
Dec 26, 2010 | Big Toys BIG-TOYS FACTORY Fisher Price...
I get beeping when I start the computer, and it wont start?
This is called a beep code. It is used for troubleshooting when you are unable to boot your computer. Here is a listing of the Dell beep codes, depending on the sequence of beeps that you are hearing, you will find the problem listed here. How many beeps are you getting and what model of Dell do you have?
1-1-2 Processor Register Failure 1-1-3 NVRam 1-1-4 ROM Bios checksum failure 1-2-1 Programmable Interval Timer 1-2-2 DMA Initialization Failure 1-2-3 Direct Memory Access Page Register Read/Write Failure 1-3-1 - 2-4-4 Memory/RAM Not Properly Identified or Used 3-1-1 Slave DMA Registration Failure 3-1-2 Master DMA Registration Failure 3-1-3 Master Interrupt Mask Registration Failure 3-1-4 Slave Interrupt Mask Registration Failure 3-2-2 Interrupted Vector Loading Failure 3-2-4 Keyboard Controller (Input) Test Failure 3-3-1 NVRam Insufficient Power 3-3-2 Improperly configured NVRam 3-3-4 Video Memory(RAM) Test Failure 3-4-1 Screen Output Initialization Failure 3-4-2 Screen Retrace Failure 3-4-3 Failure Finding Video Read Only Memory 4-2-1 Lack of Time Tick 4-2-2 Shutdown Failure 4-2-3 Failure in Gate A20 4-2-4 Unexpected Interruption in Protect Mode 4-3-1 Memory Address Failure above 0FFFFH 4-3-4 Non Functioning Time Of Day Clock 4-4-1 Serial And/Or Parallel Port Test Failure 4-4-4 Cache Test Failure
http://www.bioscentral.com/postcodes/dellbios.htm 1-1-2 Processor Register Failure 1-1-3 NVRam 1-1-4 ROM Bios checksum failure 1-2-1 Programmable Interval Timer 1-2-2 DMA Initialization Failure 1-2-3 Direct Memory Access Page Register Read/Write Failure 1-3-1 - 2-4-4 Memory/RAM Not Properly Identified or Used 3-1-1 Slave DMA Registration Failure 3-1-2 Master DMA Registration Failure 3-1-3 Master Interrupt Mask Registration Failure 3-1-4 Slave Interrupt Mask Registration Failure 3-2-2 Interrupted Vector Loading Failure 3-2-4 Keyboard Controller (Input) Test Failure 3-3-1 NVRam Insufficient Power 3-3-2 Improperly configured NVRam 3-3-4 Video Memory(RAM) Test Failure 3-4-1 Screen Output Initialization Failure 3-4-2 Screen Retrace Failure 3-4-3 Failure Finding Video Read Only Memory 4-2-1 Lack of Time Tick 4-2-2 Shutdown Failure 4-2-3 Failure in Gate A20 4-2-4 Unexpected Interruption in Protect Mode 4-3-1 Memory Address Failure above 0FFFFH 4-3-4 Non Functioning Time Of Day Clock 4-4-1 Serial And/Or Parallel Port Test Failure 4-4-4 Cache Test Failure
Oct 18, 2010 | Dell Dimension 3000 PC Desktop
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Frigidaire GLEQ2152ES Electric Dryer Logo
191 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
