I have a 17",2007 TRUTEC in our trailer. do I need a converter?
  • 975 Answers
This television receiver has only an analog broadcast tuner and will require a converter box ,thanks AJ
Posted on Jul 14, 2009
I have a 2015 Goldwing and trying to install a trailer light converter. Does the 2015 Goldwing use high-side or low-side turn signals indicators?
Hi, D not too sure, for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Trailer Light Harness Install GL1500 Information Questions goldwingdocs com
http://www.bushtec.com/fckimages/Honda-Goldwing-GL1800-Hitch-Installation-Guide-Bushtec-Motorcycle-Trailers.pdf
Vehicle to Vehicle Tail Light Converter
Plug and Play Isolating Trailer Wiring Harness for the Honda Gold Wing
Aug 26, 2016 | Honda GL 1800 Gold Wing Motorcycles
2004 Chrys Concorde, new utility trailer, tail light converter. Problem: There is output from conv box in yellow wire, when turn signal is on, but when it is connected to the trailer harness, no output...
Your vehicle CANNOT be wired for a trailer without using the converter box. The only vehicles that do not require a converter box are the vehicles that use the stop lamp bulb as a turn signal. Your vehicle is equipped with SEPARATE stop lamp and turn signal bulbs.
To make the converter box work correctly, it must be wired according to the instructions to BOTH the stop lamps AND the turn lamps. The tail (or PARK) lamps DO NOT go through the converter box.
Your trailer uses the SAME bulb for stop and turn - THIS is the reason you need a converter.
The wire color for both your LEFT TURN and your RIGHT TURN are LIGHT GREEN/TAN. Although the wire colors are the same at the bulb sockets, these are SEPARATE circuits and must be wired to the correct wire at the converter box. (LEFT and RIGHT) The converter box will have an INPUT connection for EACH of these.
The wire color for your STOP lamps is WHITE/TAN. The converter box should only have one INPUT wire that connects to this. It doesn't matter which side of the vehicle you connect this wire to. All of the stop lamps are on the same circuit.
The converter will then have only one wire for LEFT turn and stop (usually YELLOW) this is the wire that needs to go to your trailer connector for left turn and stop.
The RIGHT turn and stop will most likely be GREEN coming out of the converter.
Sep 05, 2011 | Chrysler Concorde Cars & Trucks
04 toyota corolla how to wire trailer lights without using one of those fancy adapters as i cannot afford it . Just a small utility trailer and will i need 1 or 2 lights per side THANX IN ADVANCE
Unfortunately you will need to buy some form of wiring converter. To work with your trailer lights. The problem is that your Corolla has a separate turn and stop signal, Trailer lights have one wire for turn and stop. I suggest the CURT 56175 3-2 converter. You should be able to find it around 20 dollars.
May 26, 2011 | 2004 Toyota Corolla
I have a 2001 Ford Explorer sport tac. I am hooking up a small fishing boat trailer to the truck ( the wiring on the trailer is new and installed correct). The problem: When I turn on the left or right...
You have one of two problems. Either there is a bad ground on your tailer, or the vehicle side trailer connection is bad. The Sport Trac is a 2 wire system and does not require a converter it would only need a 4-flat hardwired in. If you have a 3-2 converter installed good chance that is the problem seeing that the stop and turn wires on the input side would be wired to the same wire, which would explain the turn signals going off when the brake is depressed. If you have a converter installed simply ground the brake lead on the input side of the converter and your problem should be resolved.
For more hitch and wiring information please click here.
Feb 18, 2011 | 2001 Ford Explorer Sport
How to wire a trailer for a 1998 toyota tacoma
you will need a converter box,..... because a trailer uses the same bulb for the tail/turn signal/brakes where as your truck uses seperate bulbs for turn/brake. Any parts store will have what you need and a diagram to wire the trailer.
Jul 24, 2010 | 1998 Toyota Tacoma
Hi, I had a hitch installed on my tucson 4 years ago at uhall.tried hooking up trailer yesterday for the first time but all lights wont work.park lights find.signal lights and break lights won,t work.if i...
yes it sounds like the converter is no good,the converters purpose is, when you have a trailer it uses the brake and signal on the same bulb, so if you were to step on the brake and have the left signal on, then the left brake light would turn into the signal,on your truck it has sperate lights for signal and brake, the converter converts this into one light for the trailer, so just replace the converter and everything should work fine, hope this helps.
Apr 08, 2010 | 2005 Hyundai Tucson
I have a 2008 Toyota Highlander with the TO factory option. I installed an aftermarket trailer hitch. Do I just need a trailer light pigtail (to connect to the connector in the rear) or must I also...
I believe the box also is a safety feature in case of a wiring problem from some event, like an accident.
You need a converter to convert the turn signals and brake lights to run off the one bulb on the trailer. A flat 4 pole connector is the usual connection. A 4 to 5 pole converter may also be needed to add the backup light power to disengage the surge brakes while backing up If your trailer has that option. 4 to 5 is not really necessary but it eliminates having to get out and move the connector or insert the brake bypass key.
Aug 14, 2009 | 2008 Toyota Highlander
Towing light problem on wiring them up.
It looks like there could be a service bulletin to fix this.
TO: ALL TOYOTA DEALER PRINCIPALS,
SERVICE MANAGERS, PARTS MANAGERS
SUBJECT: SPECIAL SERVICE CAMPAIGN 10H
(2000 TUNDRA AND 1999 - 2000 TACOMA TRAILER TOWING WIRE HARNESS
CONVERTER REPLACEMENT)
Toyota will initiate a Special Service Campaign to replace the Toyota Trailer Towing Wire Harness
Converter (converter) on certain 2000 model year Tundra and 1999 - 2000 model year Tacoma
vehicles equipped with a genuine Toyota Trailer Towing Hitch or Bumper Hitch. This accessory
is included in the Towing Hitch Kit installed at ports (PIO) and by dealers (***); it is also sold by
dealers as an over-the-counter or service part.
An electrical short or open circuit can cause a fault in the genuine Toyota Trailer Towing Wire Harness
Converter (converter). This can cause a failure of the converter, and if a trailer is being towed at the time,
non-operation of the trailer lights. In limited cases, the converter housing could become heat-deformed.
In the case of the Tundra, the circuitry utilized in the converter was inadequate to properly manage
vehicle and/or trailer-side voltage spikes. If the converter is exposed to a voltage spike it may cause an
electrical short or open circuit within the converter.
As for the Tacoma, due to deficient waterproofing and improper installation location of the converter,
which is mounted in the lower portion of the taillight cavity of the vehicle, an electrical short circuit will
occur if water enters the converter housing.
The following vital information is provided to inform you and your staff of the campaign notification
schedule and your degree of involvement.
1. Owner Notification Letter Mailing Date
The owner notification will be conducted in two phases:
• The first phase will be launched in late August and involve vehicles equipped with port
installed (PIO) genuine Toyota Towing Hitch Kits.
• The remaining vehicle owners, whose vehicles may be equipped with a dealer installed (***)
genuine Toyota Trailer Towing Wire Harness Converter, will be notified in the second phase
to be launched in early September.
We have attached copies of the owner notification letters for your reference.
If you are contacted by an owner of an involved vehicle, who has not yet received a notification,
please verify eligibility through TDN or TIS, inspect the vehicle to assure it is equipped with the
affected part, and perform repairs as outlined in the attached Technical Instructions.
Jul 12, 2009 | 1999 Toyota Tacoma PreRunner
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
