Our NewAir ACP-1600E is blowing but not putting out cold air. Is it out of coolant? If so, how do we replace coolant? What kind of coolant to buy, where to buy it, how to put it in machine? Or, what else should we do? Thank you!
    President:
  • 3,433 Answers
Needs to be professionally serviced. Not consumer fixable.
Posted on Jul 14, 2009
  • Ned C Cook
    Ned C Cook Jul 14, 2009
Mod# ACP-1600E/H NEWAIR
http://www.air-conditioner-home.com/product/ACP-1000Hportableac.aspx
Hello, I would call the place that makes this, if there is something wrong with it, they can replace it at no charge.
Please just me a fixya. Thanks Farren
Dec 24, 2007 | Computers & Internet
Need to locate a operations manual. Moved into a house that has unit but no instructions
Could this be what you're looking for: http://www.newair.com/manuals/newair-ac-14000h.pdf
Jan 14, 2013 | NewAir ACP-1400H Portable Air Conditioner
My NewAir ACP-1400/H air conditioner freezes up. I have cleaned the filter and check the air flow. Everything seems good, but it still freezes up.
Its sounds like a refrigerant leak from the factory if you just got it. Check your warranty and call the manufacturer for repairs. Unfortunately there is no simple fix.
May 17, 2011 | NewAir ACP-1400E Portable Air Conditioner
The air conditioner is blowing hot air, there is no water to drain
if it is also blowing cold air out of the other vents you need to vent the hot air its blowing outside
Sep 30, 2010 | NewAir ACP-1000E Portable Air Conditioner
Loud rattle in a new newair ac-1000e bt
Buy some 1/2 thick rubber pads and put it under the unit, I am assuming it is on rollers or has feet. This should eliminate some of the problem
Jul 14, 2010 | NewAir ACP-1000E Portable Air Conditioner
Water full light wont go off even after water drained
There should be some kind of float switch that senses water level. It sounds like it's stuck.
May 02, 2010 | NewAir ACP-1400H Portable Air Conditioner
The Newair acp 1400h puts out a lot of heat and the manual says not to extend the exhaust hose. Is there any way to extend the hose so that I can exhaust where I want to?
The longer hose will increase the heat in the room and that is why they recommend the short hose…addition to that it may overheat…if you are going to extend the hose you must use one as the dryer hose that insulated and fire proof…let me know if that help
Please do not forget to rate my service for the site to continue helping everyone and improve on it.
Sep 17, 2009 | NewAir ACP-1400H Portable Air Conditioner
Not blowing cool air
Likely needs freon has leak needs repair local hvac contractor can help. T
Jun 16, 2009 | NewAir ACP-1600H Portable Air Conditioner
Newair mod# ACP-1600E/H Series
Because it's not a heater. Don't ask me why the thermostat goes to 90, probably because it's an import from a country with no quality control. But I haven't found any supporting literature that says it operates in anything more than cooling mode. You can split the case and see if there's a crossover valve (where three lines go into a sideways cylinder with a solenoid on one end) near the compressor which means it's a heat pump or if there's an electric heating element near the evaporator which means it's standard heating. If so, then get back to me, but if not, you only have an air conditioner.
http://www.airconditionerstips.org/newair-ac-1600e-portable-air-conditioner.html
Dec 24, 2007 | Heating & Cooling
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
