this sounds like the clutch slave is goin out, this unit is on the outside of the transmission. Possibly losing pressure!! Your transmission does not use transmission fluid, but instead gear oil. Have the following checked:
1. Clutch Slave (possibly worn)-this will cause soft or hard clutch pedal feel, slipping clutch, unintended clutch release, hard gear engagement, no/insufficient clutch movement.
*2. Clutch pedal Mounting Plate (possibly cracked)-this will cause improper gear engagement, hard gear engagement, soft pedal feel, insufficient clutch movement.
*this plate is located above the clutch pedal itself, apply pressure on the pedal with one hand while inspecting the plate for fatigue cracks(use a bright flashlight). This is very common on these models. This problem will eventually get worst and most mechanics never figure this out.
more questions email me at
[email protected]!!
