Question about KitchenAid K45SS Classic Stand Mixer
My Hobart Kitchenaid K45 clicks when under load. Any thoughts?
  • Johnny
    Johnny May 11, 2010
    when its clicking is it still spinning?
    New Friend:
  • 87 Answers
It could be the worm gear has lost a tooth. It could also be tha tthe beater it hitting the side of the bowl and the head needs adjusting up a little bit using the screw on the hinge.
Posted on Jan 24, 2010
Kitchen Aid Hobart K45 T-77720-A tilt up,Can you help me? where can I can down load or purchase the manual owner for this model?
go google and type in--hobart food mixer manufacturer and there are pages of hobartfood.com.au and hobartcorp.com/products/food-prep/mixers /
all of these pages will have a contact us section where there will be phone numbers and e-mail addresses
contact them direct in a area /country near you and see what is available
Sep 14, 2015 | Hobart Food Mixers
K45 kitchenaid mixer quits working under load? When beating egg whites it works great but try to cream butter and the beater stops.
It will be a broken or missing pin through a gear or the planetary or something wrong with the fuse gear. It should be easy enough to find but you will need to split the gearbox cases to check.
Sep 17, 2014 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K45 (not solid state)
You have a Hobart K45 that was produced up to 1978 when the SS model was started. You will have to search on the internet to find the capacitor or one of equal value, Also try eBay. You will need the numbers of the capacitor to do your search, which means taking the machine apart. Several models and manufacturers were used during the production of the K45 as it was made from 1962 to 1978, so the values of the capacitor are the same but the maker and size would or might be different. I have found them as rectangles and cylindrical in shape. The other option is to find another machine at a yard sale and keep it for parts. You might also take the capacitor to a real electronics shop for help in locating a replacement, (Radio Shack will not be able to help) You need a shop that deals with the electronics of machines. like a ham radio or a cb shop that does modifications or the like. I know this sounds daunting but the search and repair will be rewarding as when you are finished and the machine is back up and running you can say "I did that". Also as long as you have the machine torn down I would replace the power cord your re-assembly will be easier to complete. Hope this helped.
May 29, 2013 | Food Mixers
Hobart k45 won't run
the K45 was introduced in 1962 and ran until 1978 when the K45SS was introduced. You have an open circuit inside, you need to open the machine from the rear and look to the power cord connections. make sure that the wires are connected and none are floating loose. the next step would be to replace the speed control switch. then check your carbon brushes if either one of the brushes are down to the nubs then it would cause a short when you turned it on, if that is the case then be glad that you have breakers and not fuses because you would have fried your motor. the speed control switch has no power attached to it. ifg the problem still exist after checking power cord, speed control plate and brushes then you have a fried armature or stator either can short the system if they have a burned wire inside especially the stator.
let us know how you fare on this after you check out the first easy steps, we can help with the harder fix also.
Mar 23, 2013 | Food Mixers
Kitchenaid K45 Mixer will only run at one speed, fast
is it a K45 or a K45SS? If it is a K45 you will have to replace the filters inside and probably the speed control plate, if it is a K45SS then you need a new phase control board. The K45 is pre 1978 and the K45SS is post 1978. Your information is correct on pre 1978 K45 models that the capacitor is bad, but it might be cheaper to go garage sale hunting and find a second machine as the parts are no longer made and having spares on hand may be a significant advantage in the future, also there are a great many of the K45SS parts that will also repair the K45 mixer so it may not be a practical solution. Watch ebay regularly for K45 parts, they come up every couple of months. On the parts diagram also look for the K5 diagram as it is identical to the K45, one is a 5 quart mixer and the other one is 4.5 quart, same parts same motor same everything.
Jan 30, 2013 | KitchenAid Food Mixers
Where can i find a hobart k45 replacement cord
You can purchase a replacement power cord from Amazon.com. It is part number 9701025 and includes the grounding style plug which the original did not have. It can also be purchased from your local Sears parts store but it will be much more expensive
Apr 26, 2012 | KitchenAid K45SS Classic Stand Mixer
Which is the better mixer of these old models: K5A K5-A or K45 SS and what is the difference? KITCHENAID HOBART K5A K5-A 300 WATT MIXER and the KitchenAid Hobart Vintage K45 250 WATT. Thank you
Hello ajlina,
All of these are great home use units, all the attachments are interchangeable between these. The difference between these mixers is the K5 is a 5 quart mixer and the K45 is a 4.5 quart mixer. As I own both of them they are great in the kitchen and have the same durability.
Have any more questions please post to this thread and I will be happy to assist. Thank you for using FixYa.
Dec 09, 2010 | KitchenAid K45SS Classic Stand Mixer
Need to replace brushes for hobart k45ss mixer. Where can I find the parts
Hello Tony,
I have located the brushes for your K45 mixer, the Repair clinic has them in stock for $4.38 each, the Item # 1549909, and you may use the link below:
http://www.repairclinic.com/Kitchenaid-Motor-Parts?z=100&gclid=CKSD5NriuKcCFUVqKgodIE2b_g
You will also want to pay attention to the side of the brushed that are angled as they only go in one way. You will have to look inside the brush hole and make sure you put the angle to the same side as the angle on the inside of the hole and everything should work just fine.
Thank you for using FixYa to find your solution.
Nov 24, 2010 | KitchenAid K45SS Classic Stand Mixer
I took a KitchenAid K45 apart to clean (made in
What everyone is forgetting or they just don't know is that...The K45 introduced by Hobart in 1962 and was replaced in 1978 by the K45SS are two completely different machines. With completely different wiring systems. The K45 is wired together with wire nuts and the K45SS used connectors on the Speed control switch. All of the websites posted above are for the K45SS (Stands for Solid State) The manual for he K45SS is easy to get from Kitchenaid as the mixer electronics did not change from it's introduction in 1978 to 1986 when Hobart sold the Kitchenaid division to Whirlpool. The K45 on the other hand is a product and property of Hobart NOT Whirlpool or the Kitchenaid division of Whirlpool. The K45 Manual ... well I just can't find one! They way wires are routed is totally different in the K45 from the K45SS so the diagram in the K45SS manual does not help. Also the brushes in the K45 were square not camphor-ed like they are in the K45SS so there is no right or wrong way to insert the brushes in a K45. Whereas; in the K45SS there are four ways to insert the brushes in their holder and three of them are wrong. The K45SS brushes go into a completely different brush holder than the K45. The K45SS is the same today in 2012 as it was in 1978. The K45 is the same only from 1962 when Hobart introduced it to 1978 when it was replaced with the new Solid State model. prior to 1962 it was the K4-A model and it was different entirely. So if the people asking for help say their mixer is a K45 we should be asking for clarification as to a K45 or a K45SS.
Mar 22, 2010 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K45SS Classic Stand Mixer Logo
239 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
