Toshiba 40RV525R 40 in. HDTV Logo
P
Paul Jones Posted on Nov 18, 2015
Have a toshiba 40RV525R LCD tv, sometimes when you turn on get perfect picture/sound, turn it off then on then no picture/sound but have green light & toshiba lit up.
Unplug power then plug back up & works fine till you you turn off then back on & no picture & sound
JOSE DOMINGO MALTEZ V.
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Nov 18, 2015
Contributor
Level 1:
New Friend:
Answers
22
Questions
Helped
4565
Points
62
You probably have voltage problems , you might want to check the source, the componenes , such as capacitors and ic
40" Toshiba TV - Flashes on for a half second, then no picture
Sounds like main board fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
My toshiba tv has no sound,what is causing it to malfunction
I have a Toshiba 52HM95 the red light and the green light keep coming on but I get no picture but I can hear the sound very good what could it be please help
Toshiba 40RV525R screen has gone completly black
Do you have sound? What you are describing sounds like a fault in the back light circuit
1helpful
Toshiba lcd 52rv530u has sound but no picture completely black
Check its back light inverter board for the fault. This is a skilled work. Contact any experienced service technician to get this set repaired.
My toshiba 32av500u has no picture completely blak only power little lit in front . turns on green no kind of sound
I have the same problem with the black screen and no sound. Also the green light turns on and off while hitting the power button. Although if i turn it on then off multiple times it eventually turns on and works perfect... Could you do the same thing before it finally quit all together or did yours just happen over night?
-Kenny
TV model 40RV753. Brand new. Setting up problem. Red/green light goes green for a very short time, during which 2 short 1 second bursts of an image with sound. light then turns to a flashing orange...
Hi Gordon,
Did you fix this problem? I have exactly the same model with exactly the same problem. I've checked the capacitors on the PSU board (as suggested in one of the responses above) and they all seem OK. If you fixed the problem, I'ld really like to know the solution. Many thanks.
Regards,
Harry.
Toshiba 40rv525r LCD t.v. have sound but turned
Sorry, I donʻt have solution, but I do have this exact same problem, same model of TV! Iʻm wondering if youʻve had it fixed yet and if so, how did you do it?
6helpful
5answers
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
