Question about Tomtom GO 510 GPS Receiver
Unit frozen to white screen - cannot cold reset it
  • 2 more comments
  • Manie Nov 16, 2007
    tomtom go510
    Fixed thanks. Found the reset button on the go510's belly.
  • Anonymous Dec 07, 2007
    Unit is froze on with a blank white screen. I have tried to reset with a paper clip and a pin and no sucess. The green light is not on. Help.
  • Anonymous Dec 26, 2007
    tomtom will not turn on. Tried the reset button, no joy. Any other suggestions? Phil
If you hod the unit towards you wuth the sd card uppermost, you should see a small hole (set in a notch) slightly to the left and towards the circuit board of the unit. Pop a pin in there and it should reset itself.
Posted on Nov 26, 2007
Top and bottom screens are white
Sorry for the delay. If the dsi won't turn off when you first get the white screens, hold the power button for 8 seconds. The unit should go off. Take the game cartridge out of the unit and inside that cartridge slot, is a reset button. Using a toothpick or something, press it. Turn the unit back on and it should be fine. Hope this helps :D
Nov 13, 2011 | Nintendo Dsi Pink Console
Tip
How  OTRdriver's solution worked for me to clear up my StreetPilot C330 when it...
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
on Jan 09, 2008 | Garmin StreetPilot C330 GPS Receiver
My raymarine a50d frozen in the same page, i need to reset the unit, could you help me how to do it?
To reset the A Series unit... power down the unit. Then PRESS AND HOLD the #1 Soft Key (left most button on below the display window) while you power up the unit. The unit display will come up quickly... then will go to a white screen that says " RESET IN 3...2...1...". Screen will then kick off. That is the MASTER RESET of the unit.
If you continue to see the unit lock up after that, if you have a seperate chart card that you use (Navonics), try running the unit with and without the card. You may find that the Chart Card is causing the unit to lock up. If not, you likely will have to send in the A50D for repair to NH.
Good Luck!! :)
Dec 31, 2010 | Raymarine A50D GPS Receiver
How do you hard reset g1?
If your T-Mobile G1 Google smartphone is not responding or is frozen, you may have to opt for a hard reset. Here’s how:
1. Turn the G1 off. If it’s frozen on, take the battery out and put it back in the unit.
2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.
Now to wipe the device clean:
3. Press Alt+L.
4. Press Alt+W for a factory reset.
5. Press the Home and Back keys again for about 25 seconds.
The device should then reset again and the hard reset is complete.
Sep 24, 2009 | HTC G1
Frozen Screen
Mine does this from time to time. I pull the SD map card, power it off, and hit the reset button while the unit is unplugged. These units are notorious for this. But then again, they're inexpensive. No receipt ... well, you're pretty much stuck with it. No receipt, no return or repair.
Sep 15, 2009 | Nextar X3-02 GPS Receiver
When battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there....
when battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there. I've tried soft reset, system reset, and hard reset...nothing works.
Jul 18, 2009 | Palm Treo 650 Handheld
The screen is frozen and I cannot play music and i cannot find the reset button
If your Sansa Fuze MP3 player becomes frozen or unresponsive, you may need to reset the unit.
To do so, simply slide and hold the Power button on the side of the unit. Hold it for about 10 seconds and the player should reset.
If this does not work, I recommend plugging the device into a computer, or charger.
Jun 02, 2009 | SanDisk Sansa Fuze MP3 Player
Garmin c330
You will need to reset the device.
1. On the silver faceplat, under the word "Garmin", there is a tab. Remove the silver-ish fram carefully by pulling on the tab with your nail then by the sides.
2. once removed, press the reset button.
3. Once reset, the unit should work properly.
May 16, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
155 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
