Question about GE WSXH208A Front Load Washer
Water won't drain
Our washer is getting progressively worse at draining water from the load. It doesn't matter if it is a small load or a big one. I often have to drain and spin several times at the end of the cycle. We are inspected the drain, snaked it and used liquid plummer and it hasn't helped at all. Any thoughts?
    President:
  • 1,273 Answers
If it was your house drain line plugged, water would regurgitate onto your laundry floor. This is the most likely solution to me, as it sounds like the washer is slowly clogging up, as everything else is OK. Unplug the washer. Remove the front kick panel and gain access to the water strainer, which is in line from the tub drain to the pump. Open the strainer (there will be water). Remove and clean. Inspect for debris. Reassemble and try. Please repost if this didn't fix you.
Best regards, --W/D--
Posted on Jul 14, 2009
Maytag Neptune MAH8700A tha detergent drawer is filling up with water and running out of the drawer onto the floor not going into the tub.
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 11, 2012 | Maytag Neptune MAH7500WH Front Load Washer
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
CHANGE DRAIN PUMP WASHER
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
The washer broke filled with water and won't drain
Sep 28, 2012 | Kenmore Washing Machines
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
Going through full wash as normal but won,t go onto rinse or spin mode?
Most front load units must have two things, door must lock and must sense cold water for rinse. I would check the fill line for the cold water, if clogged with sand, it will not progress through cycle. If the unit doesn't drain it will not spin, is there water left inside the drum area?
I am here if you want more assistance
Aug 28, 2011 | Bosch Exxcel WFX 2467 Front Load Washer
Washer won't spin
Hi hometownrock,
The washing machine may have a problem draining the water, if it cannot drain the water, then the cycle will not progress to Spin. You may have a foreign object in the Drain Pump Filter, this must be checked.
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 15, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
The machine doesn't drain 100% of the water out. You can move the tub and hear the water sloshing around in the machine bottom and the moisture is now starting to form mold on the front seal
All the water does not drain. The front tub has ballance ring with water sealed in it to off set off ballance loads. The sump hose on the pumpwill also hold water. You can clean your pumps clean out trap to make sure the pump is working good. Also a drain hose higher than 6 ft off floor will cause pump not to drain all water. Front loaders all have a mold problem. no air gets in when your done washing because you close the door. If you dont use bleach and hot water washes it makes matters worse. Fabric softner is even worse.
You need to clean your washer with bleach in the front seal by hand some times.
Its the price you pay for saving water.
Nov 17, 2009 | Kenmore HE2 Plus Front Load Washer
Washer will hum and will not drain water out!
You will have to either look under the machine or take the back off.
You will see the big motor which does the washing.
You will also see a small motor which drains the machine.
Disconnect the power supply and remove the pipes from the small motor.
It could be blocked up from congealed washing powder.
Or something may have blocked the pipe from the drum to the drain motor.
If it all looks ok and still doesn`t work, then the motor has siezed.
Very easy to replace
good luck
Jan 25, 2009 | GE WBSR3140DW Top Load Washer
Ld error and now washer won't function
Yes at the 7 to 9 minute mark is where all the water should be out and the spin cycle progress to finish, sometimes water in tub causes vibration and error codes of oL and the like. Mostly with Oasis and with some front loaders the drain hose can set for a slow drain which is not detected until lint and other small particles start clogging the pump and sometimes the drain. I first check the drain hose to make sure I hear water gurgling as it drains ensuring no back pressure to slow drain. The second one is stuff in the pump and this machine has two pumps. Get a healthy gentleman to tilt the machine back for you so you can examine the pump on the right side. This is the drain pump and the larger of the two. Get a deep flat tray like a oil pan because were going to get wet pulling the hoses off and looking in the pump for debris. While we are here check the exterior hose going to the drain for lint build up.
Aug 01, 2008 | Kenmore Oasis HE 27082 Top Load Washer
GE WSXH208A Front Load Washer Logo
138 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
