Question about Belkin (F5D5231-4) Router
Belkin wireless G router conection problem
Hi There, I am using a Belkin wireless G Router but i use a cable from the router to the laptop. it seems that the connection is very unstable especially when i use skype voice...
if i connect the laptop directly to the modem the connection is fine...
any advice please...
thanx a lot...
If I do not know the ip address for the router, how do I log into it? The usual ip addresses are not working and I would like to know a procedure to access the router ip address from the pc?
Posted on Dec 01, 2007
    Novelist:
  • 85 Answers
If you are connecting the laptop directly to the router with a cable, that is good in this case because wireless connections are harder to troubleshoot. If the connection is fine when you connect directly through the modem, it pretty much has to be either your network connection settings on your laptop or (more likely) some settings on the router. I'd check the Belkin web site for the latest firmware and upgrade the router using the web access/update routine (often through 192.168.1.1 or 192.168.0.1), and then do a full router restart to the default settings and try that. This usually works.
If all that fails, I bet you have some settings on the router that are causing network trouble. Try going through the router settings and turning off (or on) each of the many confusing variables until you hit on the one that is causing the trouble.
PS: If the router is also acting as the modem, then the router will have a whole galaxy of settings for running the modem, and I bet it is them that are the culprit - I have been assuming above that you are using the same modem, but plugging it into the router.
Good luck...
Posted on Nov 17, 2007
    Scholar:
  • 193 Answers
Login to teh router and disable the fire wall and enable QOS under QOS u can upstream ur band width for the LAPTOP MAC address>and restart the router and laptop if u r not using wire less then turn off the SSID broad cast also rate me solved if its helps thx
Hi, reallly dunno,l i just conect my belkin router how i should conect and what is the problem. my belkin cant find a connection to computer, but i still have a connection. thanks for any solution
Connect a LAN cable from Belkin to your laptop/computer'sLAN port, open a browser on your laptop/computer and enter the Belkin'sconfiguration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
May 23, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do i conect another laptop to wireless
You need to know the password for your wireless signal. If you do know it, use the second laptop to search for your wireless name. Click on your wireless signal, and click join or connect. When prompted, type in your wireless password. If you don't know your wireless password, you are going to have to reset your router. Instructions on how to do that are here:http://en-us-support.belkin.com/app/answers/detail/a_id/48/~/performing-a-hardware-reset-on-the-router.
Then you will have to connect a ethernet cable between the router and a laptop to access the router's menu to create a new wireless name and password. Open your web browser (like Internet Explorer or Mozilla Firefox) and go to the address Http://192.168.1.1 The password should be blank.
Mar 08, 2011 | Belkin Wireless-G Plus MIMO Router
Hi I have recently purchased the belkin wireless surf router and I am not sure if it is working correctly or not, as the light on the front of the router is currently blinking red.. and red doesnt really...
hi
IS THE LIGHT IS BLINK RED MEANS YOU DONT HAVE A PHYSICAL CONNECTIVITY.
PLEASE CHECK YOUR MANUAL AND YOUR CABLE CONECTIONS.
STEP1
TURN OFF ROTER AND MODEM
STEP2
CONNECT MODEM CABLE TO WAP PORT ON ROUTER AND LAN CABLE TO PC OR LAPTOP
STEP3
NOW TURN ON FIRST MODEM AND AFTER A 5 MINUTS TURN ON ROUTER, YOU WILL SEE LIGHT IS TURNING ORANGE AND AFTER THAT GREEN
READY NOW JUST ENJOY YOUR ROUTER.
ADVISE:
DONT INSTALL THE CD SOFTWARE DO ALL MANUALLY.
FOR GO IN TO YOUR ROUTER SETTINGS PLEASE LOG IN IN THE INTERFACE USING 192.168.2.1 OR JUST WRITE HTTP:// ROUTER
ANY QUESTIONS PLEASE TX ME .
TECHBELKIN
Jan 25, 2011 | Belkin Wireless Surf Router (F7D2301)
Robotek
it means that if using the dhcp option then he send the ip address to your pc or laptop but you give the static then this problen will not get it
Apr 17, 2009 | Gateway 802.11g Wireless DSL/Cable Router...
How to conect a wireless router to a regular modem
If your modem/router has a USB connectivity, you can connect it via USB. Else you will have to buy an Ethernet PCI Card, which wont cost you much.
I hope this solves your problem. Good Luck ! Kindly Accept my Solution.
Regards, Arjun
Apr 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
LOST THE CD FOR MY WIRELESS ROUTER
Belkin dosent seem to have your model (anymore??)
But here is the link to contact them:
http://www.belkin.com/support/contact/email/technicalsupport/
Bye the way, I WOULD NOT install the wireless software on a wireless pc, as configuring a Router with a wireless conection is bound to create problems, - take it from someone who KNOWS.
Nov 29, 2008 | Belkin (F5D7633UK4A) Wireless Router
Wireless connection
http://www.belkin.com/support/article/?lid=en&pid=F5D7230-4&aid=1564&scid=0 reset to factory defaults and reset up your laptop All info at factory website here at this web address.RICHARDM69
Nov 23, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin g4 router
Use WPA encryption . there will be an option in your router interface for this.
Jan 25, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin (F5D5231-4) Router Logo
706 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
