Question about Scotsman Ice Maker CM3 30inW Cubed Ice Machine 900LB
Scotsman Ice Maker CM3 - ice not falling
Hi... my ice machine... Scotsman Ice Maker CM3 produces ice but it falls right back into the water area, and not into the bin... then after a while the refrigeration red light comes on... water is ice cold however
  • light_bar Jul 14, 2009
    hi there
    thanks for the response
    the cubes are full size and they almost completely all fall into the water tray, except for maybe a couple cubes of ice
  • ndbooster May 11, 2010
    I need a little more info. Are the cubes full size when they fall into the water tray, or are they just slivers of ice?
SOURCE: scotsman EC 105 - Bin full!
change the sensor ................
Posted on May 14, 2008
  • 102 Answers
SOURCE: Brand new Scotsman DCE33 ice maker melts ice
Check that the condenser is clean, the plastic sheet is hanging over the opening and trhat both spray nozzles are in place.
Posted on Aug 06, 2009
  • 102 Answers
SOURCE: Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
  • 33 Answers
SOURCE: Scotsman Ice Maker CME 256
descale bin level sensors, check for corrsion on wire harness. if does nt work. replace . bin level sensors
Posted on Aug 26, 2009
  • 7 Answers
SOURCE: Scotsman DCE33A-1WB Residential Ice Machine Problem
Making good ice. Could be cube size control. Could be a weak compressor. Also these machines are household and meant to run in air conditioned space.
Posted on Aug 23, 2010
Scotsman ice machine
Check the water inlet valve water seeping through valve should be running over into bin. Replace or rebuild valve. the machine should have slowed down on production of ice also.
Jul 17, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Cant get cubes will not fall of evaproator
CHECK HOT GAS VALVE TO SEE IF IT IS GETTING POWER OR IF THE VALVE OPENS AND CLOSES WITH A MAGNET
Jul 01, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Why Scotsman CM3 ice machine shows diagnostics water problem?
should you have any questions, Thanks John Tripp Appliance 911
First let's look through the different service manuals. CM3 Water level sense diagnosticsDOWNLOAD
Head Pressure Control Kit - CM3DOWNLOAD
Reduce Air in CM3 ModelsDOWNLOAD
Replacement of the CM3 controllerDOWNLOAD
Service Handbook to 2007 - CM/CM3DOWNLOAD . I am here should you have any questions, Thanks John Tripp Appliance 911
May 15, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
How do i get a service manual?
The bin sensor eyes need to be cleaned or replaced. First remove the front cover then remove the white plastic ice deflector shield. Now you should be looking at the evaporator plate look down you will see the water sump tray full of water in that tray is a black plastic grate that when the ice is harvested it drops and hits the tray keeping it from falling in sump tray PULL it OUT. now just behind the sump where the ice falls through opening on the left and right sides is where the ice full bin eyes are you can pull them out side ways there is plenty of wire so you can pull them up to where you can clean them with a soft cotton cloth with scotsman cleaner. Now for a manual goggle scotsman service manuals you can get a PDF file.
Apr 28, 2014 | Scotsman Ice Maker 600LB CM3 30inW...
Cant find eyes that sense when the bin is full
Pull front cover off, pull the white plastic deflector off which covers the cube plate, pull the gray plastic ice deflector which sits in the water sump tray. now reach back and down where ice falls through into bin on each side and pull them straight out to the side. You can locate them buy following the wire from the controller to the bin eyes.
Sep 28, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Where are the bin full sensors located for cme256ws-1c full light on will not make ice
The bin full sensors are located behind the water sump tray. Pull the front cover off remove the white plastic guard. Remove the ice deflector grate that is in the water sump tray. Now look where the ice falls down into the bin to the right and left side there is where the bin sensors are you have to pull them sideways you can also open the control panel and look where the bin sensor wire runs and follow it. pull the bin sensors and clean the eyes or replace them.
Jan 03, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
How do I fix the max harvest time shutdown
The ice sensors are not sensing the ice fall.Wave your hand in front of them the bin full light should blink.If it doesnt clean eyes and conectors.If it still doesnt blink change them they are bad.
May 21, 2011 | Scotsman Ice Maker 600LB CM3 30inW...
The ice machine continues to leak water into the area that the ice falls into
If the model is correct in the heading CM30? The problem is the water curtain. These are around $10 at the Scotsman parts house. When installing one always reuse the stainless steel piece that goes to help keep the curtain closed. Look at your old curtain for holes near the top, a deformed end not flapping back to cover the spray area.
The spray under the - behind the curtain should be in the shape of a cone.(Total of 2 nozzles). If not remove the nut and you will find a "spinner" it may have sediment inside it. The nut is knurled and hollow so the the nozzle unscrews with the knurled nut you'll have to hold the nozzle with a wrench and unscrew the nut with a pliers or other gripper. Don't deform the nut though.
If this helps you get the confidence to repair or the knowledge that you need a tech to help you please rate me as high as you can and thank you for using fix ya.
Mar 28, 2009 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Kitchen Appliances - Others Logo
81 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
