Question about E-Machines eMachines Desktop PC
I need a diagram of how to set up power led a and power hdd set up with motherboard pins
  • 130 Answers
It should be in the Instruction guide of your motherboard.
If not take out the board and look closly till you find "PWR LED" (Under where the RAM is placed)
I build computers for a living, so I kind of used to just inserting it straight away.
Posted on Jul 14, 2009
Need help connecting power sw, power led, hdd led, reset switch
What manufacturer of motherboard?
What model of motherboard?
What revision of motherboard?
The pairs of gold pins on the motherboard should be labelled.
Or, access the manufacturer's web-site, and download the Installation Guide for the motherboard, to get diagrams of the layout of the pins.
Jun 26, 2011 | Computers & Internet
Accidently un-setaed three jump switches --Power EW,Power LED, HD
If your talking about the pins on the mother board for the on power switch, HDD LED, reset, power led, and system speaker you would need to note the make and model of *********** board. If you look very closely you should see little letters for example , PWS, HDD,RST,PCS,PLED, These mach up to the pins on the motherboard. also most commonly the PC speaker has an open pin so it will be 3 pins long and not just 2. To find the make and model of a motherboard you can find a name and a group of numbers something like " Intel A33Y97 " and then google for more information if needed.
Apr 11, 2010 | E-Machines eMachines Desktop PC
Need pin configuration for power switch, HDD LED, power LED, front USB, etc.
Hi, just like you I purchased two of these motherboards and I have very good news for you. Above the blue PRIMARY IDE ATA connector is a set of 18 pins labeled PB/LED P5 and pin 1 is labeled.
17 15 13 11 9 7 5 3 1
18 16 14 12 10 8 6 4 2
Pins 1 and 3 = HD LED
Pins 2 and 4 = POWER LED
Pins 6 and 8 = POWER SWITCH
pin 14 has no
pin
Feb 02, 2010 | Compaq (283983-001) Motherboard
Configuring motherboard powerswitch leds reset
u will find front pannel connection pins on mother board. its in 2 lines. in onle row there is one pin slot idle. next to that vacant pin slot u insert reset sw, next to it insert hdd led, behind hdd led insert power led, next to power led (behind reset sw) insert power sw. thats it done
Jan 06, 2010 | Dell Dimension 2350 PC Desktop
Hookup of front panel lights and reset switch
Look on your motherboard. the pins have very small writing so use a strong lite. Your motherboard manufactures web site should have the manual. The manual will give pin locations and how to install.
Jun 08, 2009 | Matsonic MS9337c Motherboard
No power and I need wiring diagram for jumpers
Hi !
Via VT8237R is a chip that is on your motherboard. It does not determine your motherboard, and this chip is used in many different motherboards and producers of motherboards.
Try to locate the model and producer of your motherboard.
Usually it is written between PCI SLOTS or close to the RAM slots or close to the VGA Slot.
Finally, there is also possible to find a diagram written on the motherboard or close to the pins, with description of +/- pins.
Regards.
Apr 28, 2009 | VIA ASUS A8V-E Deluxe K8T890 chipset...
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Dec 04, 2008 | Computers & Internet
How to connect the led wires in motherboard
hi use the motherboard manual for this and find front panal connector on motherboard
pin no. 1,3 is for hdd dark color wire is 1 anothee is 3 (hd)
pin no. 2,4 is for power led dark color wire is 2 another is 4 (p_led)
pin no. 5,7 is reset you can connect both side (rst)
pin no. 6,8 is for power on power sw (psw)
most of motherboard folow this diagram
Aug 15, 2008 | Intel Motherboard
Pinout diagram
Mail sent.
For anyone else.. Visit the motherboard's online manual via their website.
Nov 13, 2007 | Gigabyte GA-7IXE4 (GA-71XE4) Motherboard
Connecting hdd led lead and power led lead,where do they go ?
Hi, There are 3 versions of this motherboard; 1.0, 2.0 & 3.3, but the layout is identical. The general layout is shown in pins.jpg. For the power led, the white wire goes to the (-) terminal either pin 2 or 3, both are MPD- while the green goes to the ( ) or pin 1 (MPD ) as shown in powerled.jpg HDDpins.jpg shows the connection of HDD led, the white goes to pin 3 or HD- while the red goes to pin 1 or the HDD . I cropped these images from the manual which is also available at the gigabyte website. Hope this gives you some ideas and workout of you. Good luck and pls post again how things turn up. Kind regards.
Aug 15, 2007 | Gigabyte GA-965G-DS3 Motherboard
E-Machines eMachines Desktop PC Logo
143 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
