The fan stops when the door is opened and the switch on the door is not pressed down by the door. Could it because of the oven thermostat fails or the relay on the control board that regulates power to the fan circuit fails?
Check the switch that power it on. Probably stuck in "on" position.
Testimonial: "If I leave the door on open position, meaning the switch on the door is not pressed by the door, the fan will stop. Could be the thermostat failed or the relay on the control board that regulates power to the fan circuit?"
Obviously, the switch by the door is working properly if it shuts off when you open door. So why are you concerned with a "relay that regulates power to the fan circuit?" U make no sense what so ever, and if you really want help I respectfully suggest that you clearly and accurately describe the nature of the problem that you are having.
